MAX Burner Posted July 28, 2023 Posted July 28, 2023 I got this idea from a social media posting, but here's a quick mod that makes the "secret compartment" below the Pantry easier to access: 1. Pulled off VELCRO from cabinet. 2. Installed a couple 8" drawer slides from Amazon: 3. Replaced the VELCRO onto the drawer slides: 4. One and done, can't even tell the difference; except for the convenience factor - time for a cold one. Cheers! A & D 13 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Katjo Posted July 28, 2023 Posted July 28, 2023 I love this mod! It is on our to do this. 2021 Dodge Ram 1500 2021 Oliver Elite ll Hull #732 Michigan
Gliddenwoods Posted July 28, 2023 Posted July 28, 2023 How do you stop it from sliding open when traveling down the road? 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Gliddenwoods Posted July 28, 2023 Posted July 28, 2023 What brand & model # did you use? Thanks. 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
MAX Burner Posted July 29, 2023 Author Posted July 29, 2023 43 minutes ago, Gliddenwoods said: How do you stop it from sliding open when traveling down the road? The glides are soft-close style with a detent in the retracted position, just like the Oliver kitchen drawers... We ordered the slides yesterday, they arrived here this morning, it's an easy/quick DIY mod for less than $12: Cheers! 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Gliddenwoods Posted July 29, 2023 Posted July 29, 2023 Thank-you MAX Burner. 1 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
jd1923 Posted July 29, 2023 Posted July 29, 2023 17 hours ago, MAX Burner said: We ordered the slides yesterday, they arrived here this morning, it's an easy/quick DIY mod for less than $12. Wow, very good idea and start-to-finish in 24 hours is impressive! Just put these slides on my Amazon Wishlist (for after we get a handle on the big jobs, on our very new-to-us Oliver). Thanks, Art & Diane! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
MAX Burner Posted August 2, 2023 Author Posted August 2, 2023 ...follow-up info: @Gliddenwoods: We installed that mod 3 days before leaving on the road trip we're currently on now. After the first leg, about 275 miles, checking the pantry compartment sliding top a few times - no issues. The "soft-close" slides hold fast. Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
NandNPNW Posted September 30, 2023 Posted September 30, 2023 We did this mod without knowing it was already posted! Our exception was utilizing 12lb double sided tape and black 10" locking drawer slides. The tape (from local ACE Hardware) was the thinnest we could find in the weight capacity I was looking for. It's installed on both the slide base and the bottom of the countertop. I was concerned about it floating too high above the base but it closes up nicely and is not noticeable. Not concerned about pulling them off as all the force is lateral and not expecting any weight bearing for the tabletop once slid out. https://www.amazon.com/dp/B08GJMLDPL?ref=ppx_yo2ov_dt_b_product_details&th=1 1 5 #266
jd1923 Posted October 1, 2023 Posted October 1, 2023 Bravo @NandNPNW for installing this without drilling mounting holes! This is great. The Ace Hardware product is likely good, I loved Ace in the day, back in Chicagoland, where Ace started! Next time, or if your install loosens up, go with 3M 4950 VHB tape. Instead of 12 LB you get 80 LB / SQ IN, so you could lean on the counter fully extended to get off the floor, been there Ha-Ha. This product is amazing! I'm an engineer and over-engineer about everything! I used to bolt down everything, but not anymore. I used this product to mount 2 large heavy solar panels on a fiberglass roof with only 20 SQ IN of tape each. This is an amazing product! Amazon.com: 3M Double Sided Mounting Tape 1” x 120” 4950 Foam Tape Heavy Duty Adhesive Waterproof for Car Home Office Deco Color White : Office Products 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ty J Posted February 19, 2024 Posted February 19, 2024 Thanks For posting this mod! Finished mine Today 3 2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout. 300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt Nova Kool refrigerator. Tosot A/C. Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
John and Jodi Posted Monday at 12:22 AM Posted Monday at 12:22 AM I'm glad a lot of people have had success with this mod, but we haven't. One variable that seems to be different is that we have Foy's extended pantry countertop. I don't know if it's heavier or what, but every time I take the trailer somewhere, the countertop slides open; it doesn't stay closed. Now I have to use a hook-and-eye fastener to secure the countertop since un-doing the mod is not an option. 1 John and Jodi San Antonio, TX 2022 Elite II - Hull #1126 being pulled by a 2022 F-150 Powerboost. Map Legend: Red - Driven Through; Orange - Stopped In; Blue - Explored Parts; Green - Explored Whole
Galileo Posted Monday at 02:46 PM Posted Monday at 02:46 PM We actually like the Velcro. I don’t know if others had this small storage area shown to them as a “secret compartment” - but I think the Velcro is more apt to keep it that way. Anyway - we go in that compartment so seldom that there’s not a huge convenience or time saving benefit for us. I’m also fond of leaning on that surface or putting quite a bit of body weight on it while extricating myself from the (king layout) bed. So making it readily movable will make it easy to bend those slides at least, and likely to send me crashing to the floor in the middle of the night at worst. 1 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Ronbrink Posted Tuesday at 12:39 PM Posted Tuesday at 12:39 PM (edited) 21 hours ago, Galileo said: We actually like the Velcro. Same here! My pantry shelf mod involved extending it out to make it even with the adjacent twin bed with heavy duty Velcro for securement. The additional length provides more counter space/staging area. I also extended the dinette table an additional 7” for an equivalent bump out; making its utility for dining much better. I previously installed sliding Lagun tables for each of the twin beds and used the original Lagun tabletop for the pantry extension, likewise the original pantry shelf for the dinette table extension. We’ve been very pleased with these mods. Here’s a pic of the two Lagun tables, a much more challenging mod I must say! For those that have the Lagun option, you know the nightstand drawer is restricted when this table is in use. In my year model the nightstand tabletop can be lifted off, allowing access to the drawer content from atop; which was acceptable, since I preferred the leave the Lagun mounted for daily use and stowing it was a PITA. By design, I can now open the drawer even with both Laguns permanently mounted; and the wifey is now happy to have her own bed table, being I tended to ‘hog’ the original one for self use! There have been a few mods featured in this forum on relocating the Lagun mount to the side of the nightstand to enable front drawer access and my mod, as well. Edited Tuesday at 12:49 PM by Ronbrink 1 4 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Galileo Posted 20 hours ago Posted 20 hours ago On 7/14/2026 at 7:39 AM, Ronbrink said: My pantry shelf mod involved extending it out to make it even with the adjacent twin bed with heavy duty Velcro for securement. The additional length provides more counter space/staging area. I also extended the dinette table an additional 7” for an equivalent bump out; making its utility for dining much better. I see the added piece behind the dinette tabletop, but where get you get the deeper pantry shelf - as well as the matching pattern for the dinette? 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD (17.9mpg towing, 35mpg clean) RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Ronbrink Posted 4 hours ago Posted 4 hours ago 14 hours ago, Galileo said: I see the added piece behind the dinette tabletop, but where get you get the deeper pantry shelf - as well as the matching pattern for the dinette? I originally ordered the ‘Black Samba’ fiber-granite for our 2020 OLEll and also opted for the Lagun table in matching color. The Lagun table was only offered with the twin bed floor plan and was factory-mounted on the front of the nightstand, which blocked the nightstand drawer when in place (see pic). I kept the Lagun table permanently mounted even though it hindered access to the nightstand drawer and overhead attic. After a few years I decided to reconfigure the Lagun mount and add a second bed table for independent use by each of us. However, upon contacting Oliver to purchase another ‘Black Samba’ Lagun tabletop I was told that color was discontinued. I ended up buying two in a contrasting gray color that closely matched the vinyl flooring, ‘Monte Blanc’ fiber-granite. After developing a sliding mount and installing the two new Lagun tables, I decided to make use of the original Lagun tabletop by replacing and extending the pantry countertop. The original pantry countertop was then used to extend the dinette table. I previously stated that heavy duty Velcro was used to secure the extended countertop, but 3M Dual Lock Reclosable Fastener was actually the product used, Velcro on steroids! Original pantry countertop used to extend the dinette table. 1 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
