MAX Burner Posted October 10, 2023 Share Posted October 10, 2023 Installed new carpet treads a couple days ago and planned to clean and lubricate the step mechanism with CV-2 grease. FYI: Just a small amount of CV-2 applied to the rail slots make deploying/retracting the steps quieter and much easier with a lot less effort. Noticing that the leading edge/forward aluminum step frame had been quite hammered by road debris after 6+ years of usage, we decided to address this situation with an angle grinder fit with a polishing wheel and green rouge. Here's what happened after about 30 minutes of effort: We're liking the results and should allow being able to keep this area cleaner over time... Cheers! 1 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted October 10, 2023 Moderator+ Share Posted October 10, 2023 1 hour ago, MAX Burner said: We're liking the results and should allow being able to keep this area cleaner over time... Cheers! It appears the steps are currently being made from tread plate rather than flat plate aluminum. Steve, Tali and our dog Rocky plus our beloved Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
Steph and Dud B Posted October 10, 2023 Share Posted October 10, 2023 Our 2022 is flat plate. Must have been an interim thing. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted October 10, 2023 Moderators Share Posted October 10, 2023 Our old (2010?) steps are flat plate, plus nonskid strips. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
MAX Burner Posted October 10, 2023 Author Share Posted October 10, 2023 2 hours ago, Steph and Dud B said: Our 2022 is flat plate. Must have been an interim thing. FYI: The plates are in fact flat aluminum, they look like diamond plate because they're reflecting the diamond plate floor mat that the trailer is positioned on. The second photo shows the plate finish without the reflection. 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
Wandering Sagebrush Posted October 10, 2023 Share Posted October 10, 2023 12 hours ago, MAX Burner said: Installed new carpet treads a couple days ago and planned to clean and lubricate the step mechanism with CV-2 grease. FYI: Just a small amount of CV-2 applied to the rail slots make deploying/retracting the steps quieter and much easier with a lot less effort. Noticing that the leading edge/forward aluminum step frame had been quite hammered by road debris after 6+ years of usage, we decided to address this situation with an angle grinder fit with a polishing wheel and green rouge. Here's what happened after about 30 minutes of effort: We're liking the results and should allow being able to keep this area cleaner over time... Cheers! Art, it appears you still have a bit of aluminitus left over from the Airstream days. I like it. 5 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted October 10, 2023 Moderator+ Share Posted October 10, 2023 8 hours ago, MAX Burner said: FYI: The plates are in fact flat aluminum, they look like diamond plate because they're reflecting the diamond plate floor mat that the trailer is positioned on. The second photo shows the plate finish without the reflection. My bad, I see it now, Thanks! Steve, Tali and our dog Rocky plus our beloved Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
Jim and Frances Posted October 10, 2023 Share Posted October 10, 2023 (edited) While I love CV@ grease, you might want to consider either a dry spray PTFE or white lithium instead on exposed applications like your steps. While I am no grease expert, some suggest that since dry spray PTFE or white lithium is not as tacky or sticky as CV2, it will not keep as much road grime. For this reason, I use CV2 in non-exposed areas (like bearings, wet bolts in suspension, etc.) and I use white lithium on exposed areas like hitch ball, rear bumper pins, etc. I use a dry lube PTFE spray for steps, door latches, etc. I have even switched to PTFE dry spray for jack struts as normal grease (even lithium) was getting nasty with road grime. The downside to the PTFE is having to apply is more frequently, but it is very easy to do. I use the 3-in-1 RVCare Window Track Dry lube spray for my window tracks. I am sure there are others much more experienced with grease applications and I would defer to them. Edited October 11, 2023 by Jim and Frances typo 1 2 SE Texas | 2021 Elite II Twin Bed # 927 "Lucy" | 2019 F250 FX4 6.7 Link to comment Share on other sites More sharing options...
Ronbrink Posted October 11, 2023 Share Posted October 11, 2023 On 10/9/2023 at 8:06 PM, MAX Burner said: Just a small amount of CV-2 applied to the rail slots I got this for the hitch ball, gonna give it a try on the steps! Amazon purchase, per product info: “Say goodbye to white and black grease stains. This multi-use, non-melting, waterproof grease is fortified with PTFE, the ultimate in nonstick technology.” I’m also a fan of their Silicone Paste dielectric grease. 1 2020 OLEll, Twin, 579 2012 Silverado 1500 4x4 No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables Link to comment Share on other sites More sharing options...
