johnwen Posted October 11, 2023 Posted October 11, 2023 We have 320 watts of panels on top of our E2 and have the Zamp external port on the side of the trailer. Does the Zamp charge controller, inside the trailer, control the external plug? Currently I have a portable Renogy 100w suitcase panel going through its own pwm controller that is mounted on the suitcase. Then I go through the external port, using a reversing plug (because of Zamp's design) to augment the Zamp panels on top of the trailer. It has been helping by reducing the charging time and I'm able to easily aim it at the sun. I'm interested in replacing the suitcase with a 200w flexible setup with an nppt controller, that's much lighter and more helpful. I'm guessing the Zamp port on the trailer is a direct shot to the battery, uncontrolled, and the Renogy pwm controller is doing what it's supposed to do. Can I just put a 200w panel in the place of the Renogy, go through the reversing adapter (if necessary), set up the new panel's controller for my 440ah AGM 6 volt batteries and ... that's it? Thanks for any help, John 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Moderators SeaDawg Posted October 11, 2023 Moderators Posted October 11, 2023 The zamp connector, as installed by Oliver, requires input from a separate controller. It's set up for "suitcase solar", ie, panel(s) with their own separate controller. The zamp connector connects directly to the battery bank, via an inline fuse to protect against over-voltage. If you want to upgrade your portable panels, you must provide a separate, appropriate controller between the panels and the batteries, in the standard configuration. So, yes, you can upgrade to 200 watts, add a controller that accommodates the new panels, and you'll be fine. What you CAN'T do is send unregulated power from panels without a controller to the port. 2 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators topgun2 Posted October 11, 2023 Moderators Posted October 11, 2023 16 minutes ago, johnwen said: Can I just put a 200w panel in the place of the Renogy, go through the reversing adapter (if necessary), set up the new panel's controller for my 440ah AGM 6 volt batteries and ... that's it? Yes...that's it. Just be certain that your new panels have their own solar controller and that the polarity (reversing adapter (if necessary) are there. Bill Just to be safe - you might also want to check the fuse on that Zamp external port. 1 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
johnwen Posted October 11, 2023 Author Posted October 11, 2023 2 minutes ago, SeaDawg said: standard configuration As in the "AGM" mode as selected on the new panel's controller? Ultimately I'll want to use the new 200w panel to also charge a portable power station, as in a Jackery, etc. 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
johnwen Posted October 11, 2023 Author Posted October 11, 2023 Thanks, Bill 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Moderators topgun2 Posted October 11, 2023 Moderators Posted October 11, 2023 16 minutes ago, johnwen said: As in the "AGM" mode as selected on the new panel's controller? Ultimately I'll want to use the new 200w panel to also charge a portable power station, as in a Jackery, etc. Does the solar controller on the 200 watt panels allow for different batteries? Mine does not - therefore I can not change anything on my solar controller. If yours does allow changes then I'd set it to whatever you have in your Ollie. The Jackery has a lithium battery which (as I understand it) can be charged at AGM setting but the lithium will simply either not fully charge and/or it will not be charging at the optimum rate(s). Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
johnwen Posted October 11, 2023 Author Posted October 11, 2023 1 minute ago, topgun2 said: Does the solar controller on the 200 watt panels allow for different batteries? Mine does not - therefore I can not change anything on my solar controller. If yours does allow changes then I'd set it to whatever you have in your Ollie. The Jackery has a lithium battery which (as I understand it) can be charged at AGM setting but the lithium will simply either not fully charge and/or it will not be charging at the optimum rate(s). Bill I don't know, Bill. I've not decided on the panels yet. Originally I was trying to take advantage of Amazon's price breaks today but have decided to not make any rash decisions, as I want to make the best possible decision with this. My OMMO solar battery will not complete its charge as I think it has its own controller internally and when charging it I've been using Renogy's controller also and I think that's what's preventing a full charge.....but then again, I really don't have a clue. I think 2 controllers are creating the problem with completing the charge. 1 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Moderators topgun2 Posted October 11, 2023 Moderators Posted October 11, 2023 1 minute ago, johnwen said: but then again, I really don't have a clue. I think 2 controllers are creating the problem with completing the charge. What batteries do you have in your Ollie? 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
johnwen Posted October 11, 2023 Author Posted October 11, 2023 4 x 6 volt Bright Way Group 220ah AGMs for 440 ah capacity. 1 1 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Moderators SeaDawg Posted October 11, 2023 Moderators Posted October 11, 2023 Jackery units have their own internal controllers, and use unregulated/uncontrolled voltage input from the portable panels. . So yes, that's likely a problem. You could install a switch before the controller, and a separate lead to thr jackery. And you'd likely be fine. Look at the specs on jacery panels. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
John E Davies Posted October 11, 2023 Posted October 11, 2023 FYI, it might give you some ideas: https://olivertraveltrailers.com/forums/topic/5478-how-to-remote-mount-the-controller-of-a-suitcase-solar-panel-not-inside-the-trailer/ John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
johnwen Posted October 12, 2023 Author Posted October 12, 2023 TY, John 1 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Moderators SeaDawg Posted October 12, 2023 Moderators Posted October 12, 2023 @johnwen, how old is your OMMA unit? Does it charge on ac, but not on solar? I've read some mixed reviews on longevity. On OMMA. Are you planning to replace it with a jackery unit? 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
johnwen Posted October 12, 2023 Author Posted October 12, 2023 About 4 yrs but still behaves as if new. Yes, it charges to 100% on a/c and approx 70% on solar. Haven't decided on replacement. 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Moderators topgun2 Posted October 12, 2023 Moderators Posted October 12, 2023 Are you certain that your charge controller is set properly? 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John E Davies Posted October 12, 2023 Posted October 12, 2023 10 hours ago, johnwen said: About 4 yrs but still behaves as if new. Yes, it charges to 100% on a/c and approx 70% on solar. Haven't decided on replacement. Wait for the upcoming larger EcoFlow River 2 Max, I have the 600 and it is stellar but a little too small in capacity. A larger one of around 1000 or 1200 watts is expected. I will buy one and gift my 600 to a relative. They are blowing out their older models with regular fire bomb lithium batteries and soon I expect to see all of their products to have LiFePO4 battery technology like the Olivers have. Sign up for emails and they have excellent special member deals. https://us.ecoflow.com/ https://thetechnologyman.com/ecoflow-river-2-max-review-best-500w-portable-power-station/ John Davies Spokane WA 1 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Galway Girl Posted October 13, 2023 Posted October 13, 2023 Zamp connector compatible solar panel suitcase build here: https://4-ever-hitched.com/ggs-blog/f/here-comes-the-sun 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
johnwen Posted October 13, 2023 Author Posted October 13, 2023 6 hours ago, Galway Girl said: Zamp connector compatible solar panel suitcase build here: https://4-ever-hitched.com/ggs-blog/f/here-comes-the-sun Thanks...I really like your setup. I've been looking for a way to move my Renogy controller from the 100w panel to a place close to my trailer batteries, and the portable, waterproof case seems a good portable solution John 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Geronimo John Posted October 16, 2023 Posted October 16, 2023 On 10/11/2023 at 5:16 PM, SeaDawg said: The zamp connector connects directly to the battery bank, via an inline fuse to protect against over-voltage. The inline fuses I know about protect from over amperage, not over voltage. By simple math, to a point, that can be interperted as a power control method, as Power = V * A. But the failure it protects is amperage. Also, the typical inline fuses often have a 250 max voltage limit. Not a level we want to see anywhere in our OTT's. GJ 2 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators SeaDawg Posted October 16, 2023 Moderators Posted October 16, 2023 Thanks, gj. I had a brain fart. The fuses are amp rated. My Furrion port has a ten amp. I've read that the zamp port has a 20 amp inline fuse. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
