Mike and Jill Posted January 1, 2024 Posted January 1, 2024 We're currently out camping with our 2 month old Legacy II, when our Truma varioheat furnance went out and started putting out codes. When I set a temp calling for the furnance to come on, a small audible click can be heard about 10 seconds after setting the temp and then error code "E 13 H" will show on the cp plus display. I've searched the everywhere I can think of on the internet including the truma site for a explaination for this code, but haven't been to find this particular code listed in any of the troubleshooting guides including the manual for the furnance on Truma's website. Tomorrow (after the new year holiday) I'll give Oliver a call, but today being the holiday everyone is closed. I have tried to reset the code on the display, however, it keeps returning (the error code) on each new attempt to start the furnance. I also pulled the 10A fuse for the furnance to get it reset as well, but this didnt fix it either. The return for the system is also clear of any obstructions. It's not the end of the end of the world but its getting down to the 40's tonight so some heat would be nice if anyone has a thoughts or has dealt with this code before Thanks 2023 Legacy II hull # 1446 "The Scout" . Lithium Pro Solar Package, twin bed 2020 Ram 3500 4x4 dually w/ 6.7 Cummins, Ham radio callsigns N4BBQ and KO4KSU (Jill)
Steph and Dud B Posted January 1, 2024 Posted January 1, 2024 Couldn't find that error code either. Did find a couple of British YouTubers showing how to reset the control panel to clear some errors. Not sure if the American version is the same. Here's one: https://youtu.be/Xzo9tTWB7T0?si=OH-eBlG8-nNGb4UY 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderator+ ScubaRx Posted January 1, 2024 Moderator+ Posted January 1, 2024 2 hours ago, Mike and Jill said: It's not the end of the end of the world but its getting down to the 40's tonight so some heat would be nice if anyone has a thoughts or has dealt with this code before Thanks You didn't mention the conditions under which you are camping. Are you boondocking or in a campground with full hookups? If you have electricity, I would suggest going out and buying a small electric heater. It will easily heat your trailer to 70 degrees or more. We keep one with us at all times. If you are boondocking, just put on some extra cover or clothes. You could still buy the electric heater and run it off your generator or for short stints off the batteries. How long you can run the heater is dependent of the type batteries you have. We even carry a Mr. Heater Portable Buddy gas heater that runs off a small propane bottle or a larger tank with an auxiliary hose. We like to have every eventuality covered. I don't like being inconvenienced by something breaking down on the road. 5 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderator+ ScubaRx Posted January 1, 2024 Moderator+ Posted January 1, 2024 Could you have accidentally posted the error code incorrectly? Error Code E513H Fault E513H This is a fault with the Over heat thermostat. It normally occurs when the heater is asked to heat the water on the HOT setting, and may be intermittent, but the system may be fine on the eco water heating setting or if the heater is just being used for space heating. 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Mike and Jill Posted January 2, 2024 Author Posted January 2, 2024 Thanks ScubaRx and Dud B. Dud B, I did try the reset in video you replied with and the same condition or code returned. ScubaRx, thanks for ideas and yes we do need to bring a secondary heat source in the future. Tomorrow we're pulling stakes and heading home from this little shake down run with our Ollie. I did see the 513 code and thought the same as you, but it I tripled checked it and it does say E 13 H. Thanks to both of you all. Tomorrow when everything opens back up I'm sure between Oliver and Truma we'll be able to get this figured out. 1 2023 Legacy II hull # 1446 "The Scout" . Lithium Pro Solar Package, twin bed 2020 Ram 3500 4x4 dually w/ 6.7 Cummins, Ham radio callsigns N4BBQ and KO4KSU (Jill)
Ronbrink Posted January 2, 2024 Posted January 2, 2024 12 hours ago, ScubaRx said: We even carry a Mr. Heater Portable Buddy gas heater These are great heaters, but come with many precautions; so anyone using them should be well versed. Proper ventilation is key, but even with that I experienced humidity issues when using; condensation on the interior windows would form and run down the wall onto the bedding. Breathing alone can create this condition, but the Mr. Heater seemed to worsen the problem and thus, no longer carry with. However, Mr. Heater is a great alternative to a gas fire pit! 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators topgun2 Posted January 2, 2024 Moderators Posted January 2, 2024 1 hour ago, Ronbrink said: the Mr. Heater seemed to worsen the problem Yep - water vapor is a by-product of burning propane. Thus, unless vented, the Mr.Heater will simply add moisture to the interior of the Ollie. I always have the bath door open with the bath vent open plus have either a window cracked or have the main ceiling vent opened when using my Mr.Heater. As Ron states - 2 hours ago, Ronbrink said: Proper ventilation is key Bill 5 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators SeaDawg Posted January 2, 2024 Moderators Posted January 2, 2024 22 hours ago, ScubaRx said: Could you have accidentally posted the error code incorrectly? Error Code E513H Fault E513H This is a fault with the Over heat thermostat. It normally occurs when the heater is asked to heat the water on the HOT setting, and may be intermittent, but the system may be fine on the eco water heating setting or if the heater is just being used for space heating. That's a code for the water heater/combi. I saw the same. I'm not sure if they're the same, on the varioheat furnace. Good try, though. @Mike and Jill, any updates, now that everyone is back to work at Truma? 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Mike and Jill Posted January 3, 2024 Author Posted January 3, 2024 13 hours ago, SeaDawg said: That's a code for the water heater/combi. I saw the same. I'm not sure if they're the same, on the varioheat furnace. Good try, though. @Mike and Jill, any updates, now that everyone is back to work at Truma? Yes, I talked with the Truma center in Lakeland Florida yesterday and they stated that code is "fan speed too slow". In conversation, the tech stated that more than likely I had a mechincal fan failure and the unit would need to be replaced. Being that their repair center is only 2 hours from us, we are scheduled in Feb to have looked at or replaced. So a little bit of a wait but very happy to have Truma actually doing the work. 6 2023 Legacy II hull # 1446 "The Scout" . Lithium Pro Solar Package, twin bed 2020 Ram 3500 4x4 dually w/ 6.7 Cummins, Ham radio callsigns N4BBQ and KO4KSU (Jill)
Moderators topgun2 Posted January 3, 2024 Moderators Posted January 3, 2024 Mike and Jill - Thanks for the update! Hopefully Truma will take good care of you. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Geronimo John Posted February 28, 2024 Posted February 28, 2024 If you have children or curious pets, an oil filled space heater is much safer to wandering hands or tongues. But they do weigh a bunch more than the typical 2 pound space heaters sole at Walmart. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
