  2. @2008RN Sounds like our travel patterns are very similar. We have lithium and prefer to stay at harvest hosts so I expect this year we will get plenty of use out of the DC - DC charging. Great idea about adding the connector on the front and a pair of jumper cables. I definitely will put those on my list. 👍
  3. Good call on those plug covers @Patriot. I just ordered them. 👍
  4. Very wise install @Olive2Roam and @2008RN. I also had the “pig tail” detachable or “break away” DC-DC 30 amp cable installed. I have silicone weather caps installed on both my Andersen plugs. Inverter Services which is the company that I had do our turn key Lithium conversion on XPLOR highly recommends the break away pig tail for “safety concerns”. 👍🏻😊 Link to the Andersen plug covers if anyone should need a set- https://www.amazon.com/dp/B0DFPXKKLV?
  5. Today
  6. We also have a TST and plug the signal booster into the 12v cigarette lighter outlet above the cooktop. Not sure how the Tireminder works but honestly the few times we forget to plug in the booster, the TST seems to work fine.
  7. Wow, what a bummer, but lucky landing. I'd much rather spend on replacing the fan, a simple installation, than have any fiberglass/body damage! It seems weather in the east has been on-n-off bad ever since hurricane Helene! Prayers and best wishes for an early spring and better weather going forward!
  8. Good idea, if you're not using it. That's what I did from day one, since I stopped riding bikes (except dirt bikes 🤣) when we moved from Texas to the mountains. You have to be young and STRONG to ride road bikes out here! Recently when I got to my final big Oliver project, cleaning up the exterior, I decided to also remove the mounts which are NOT pretty! (see picture above)
  9. Agreed, but... I also replaced the OEM China-made with Timken Bearings and new seals. Do NOT buy on Amazon or eBay! BTW, I forget to mention new bearing seals in my last post which you need regardless of replacing or re-packing bearings. But after spending $200-300 and hours of my labor, next thing I replaced the D35 axles with D52 and Nev-R Lube bearings. What a waste of my money and time! If you're going to keep the D35s, then do what GJ suggests. If you think you will upgrade and soon have Nev-R-Lube bearings, made in USA, that should last 5 years without maintenance, then just re-pack now. Something else to consider at this point in time, with spent brake shoes and needing other service, if you have any thoughts of upgrading axles, this is the time to do it. Should you spend $1000 +/- now or spend $2K plus labor on brand new upgraded axles with all new 12" brake assemblies, drums, bearings, etc? Following are my two posts where first I replaced OEM bearings with Timken and second where I replaced the entire suspension, D52 axles with Alcan Springs.
  10. Yes, if they're able to be resurfaced. I just wouldn't ever relocate the bearings to a new set of drums.
  11. I went the same way you did. I put Andersen connectors under the reat bumper and under the front of the Oli. I use it when we travel day after day boondocking. If I stayed somewhere with power, or will be staying the next night with power I probably won't use it. We have a trip coming up to Yosemite, Arches, Dinosaur National Parks, and using harvest hosts whenever possible; We will depend on the DC-DC charger much more. Have an August trip, and it should be around 100 degrees everyday, We will be on shore power most of the time and will probably not use the DC-DC charger much if at all. Maybe when we go to Lithium we might use it more often. We are pretty conservative with power on the AGMs. If we boon dock for several days in one spot we use Generator at dinner time to top off the batteries. Except In Wisconsin State parks generators are not allowed so we supplement with the DC-DC charger and the Ford Diesel when staying multiple days. I am going to install an Andersen Cable on the front of the truck this spring. So I can attach from either end of the truck. I am planning on making a Jumper cable with an Andersen connector on one end. so I can jump start or get jump started from either end of the truck.
  12. I agree with both of the above. With a 5 year old trailer, replacing the OEM bearings is suggested. A difficult task if not experienced in doing so. But with some mentoring it is actually not all that difficult. Temken bearings and National/Temken races are the preferred choice here in Ollie Land. Here is Frank C post with the same mileage as yours and likely the same OEM bearings: GJ
  13. Of course, since you would not hammer out bearing races and reinstall them after being damaged merely by removing them. Unless the shoes were down to metal on the drums, the bearings should be removed (races stay), all old grease removed from hubs and bearings, get the drums turned and repack bearings. The complete braking plates with new shoes, springs and magnets are the way to go. Investing in new drums and bearings would about triple the parts cost!
  14. Lot's of good replies here already! Am I correct in thinking new Oliver TTs now come with the Dexter D52 (5200 LB) Nev-R Lube axles? Some of us with older hulls had D35 axles installed and like Mike mentioned, have upgraded. So, you should be good here. Either way, OTT installs Dexter Chinese made leaf springs rated at 1750 LBS each. Although, we've heard rumors OTT is talking with Alcan Springs for USA made springs. Given you're buying new in 2026, you could ask them about this! Search for keyword 'Alcan' for more information. Many of us think 1750 LB springs are under-sprung (200 Oliver owners have installed Alcan Springs rated at 2750 LBS each), and there have been several failures of these springs documented. Our Oliver used to waddle like a duck when crossing bridge seams, gas station entrances, or speed bumps on an angle. Not anymore, and since our Oliver suspension is now handling itself, the truck tows better and I was able to remove the Andersen WDH. The Alcan Spring upgrade is a little over $1K plus labor.
  15. I never use the hitch coupler. I may just leave that bar off.
  16. Hey John. Our DC to DC charging system is the detachable cable. There is a receptacle under the bumper at the back of the Pathfinder and there is a receptacle under the cargo box at the front of the trailer. We don’t leave that connected all the time so we made it detachable at both ends. Hope that makes sense.
  17. If I'm replacing the drums I never re-use the bearings. Maybe unnecessary overkill, but I just never felt comfortable doing so.
  18. Bob, I was wondering why do you have detachable cables? In most installations, like ours, there is a receiver installed under the truck bumper and the power cord on the Oliver side is permanently attached (not needing storage space). The DC-to-DC charger is such a great feature. Like you, we only stay a few nights at each location. We consistently get 40+ Ah charging every hour towing on the road. Please look us up when you travel southwest!
  19. We had no power for6 days here in Nashville. Our camping skills came in handy, but there was ice storm damage everywhere around us. We were trapped when one of our 160 year old Red Oaks fell across our drive. Thankfully, My Nephew brought a crew and we sawed a gap to drive thru. The Ollie took a direct hit right on the Maxx Fan (toast), but thankfully the gel coat was unhurt. I have been moving branches and sticks for a month to the street. Things are slowly getting back to "normal".
  20. The stock suspension is fine. We replaced everything after 9 years and a lot of miles (100K+). There have been some cases of leaf spring failure, but when I had ours replaced they looked fine. I’m just a believer in preventive maintenance (too many years in the Army). There was no reason to replace my axles, except to upgrade from the 3500 lb axles and also get bigger brakes and never lube bearings. Our camping is a combination of nice roads and not so nice roads. Mike
  21. The first time I replaced brakes was just a couple of years ago, I’ve got 110Ksih miles on the trailer now. 24K is way too soon for normal braking. I also agree with the comments on bearings, they should not need replacing, just repacking. Mike
  22. @Olive2Roam Great post and photos! We are big fans of our friends David and Kristine Hess owners of Sea Biscuit. You won’t meet a finer couple who fully support the RV industry with their products. My wife and I have been to their factory where they craft their products. Our front cargo box is has been one of our top mods. We store our chocks, blocks, 30amp cord and all other “possibles” for a quick set up and take down of our campsite. I installed a sheet of XPEL PPF (paint protection film) to the front of the cargo box of XPLOR to keep it protected from the blast zone and road missiles when in tow behind our TV. Your LE1 looks amazing, congrats on your mods! Beauty and the Beast - camped inside Yellowstone NP 🇺🇸
  23. Hopefully I'm posting in the appropriate thread and it has not already been posted here. Just saw this on Bloomberg via MSN: https://www.msn.com/en-us/money/companies/ford-recalls-4-4-million-vehicles-on-trailer-controller-flaw/ar-AA1X88AR?ocid=hpmsn&cvid=69a1a8ea953d4482be96a7f27cdc157f&ei=145 Bloomberg (subscription required): https://www.bloomberg.com/news/articles/2026-02-26/ford-recalls-4-4-million-pickups-suvs-on-lighting-system-flaw
      • 2
      • Thanks
      • Like
  24. We re all here to help Jeff, no worries! 👍🏻
  25. Now, the original question makes more sense! Bill
  26. I believe that it was Patriot who first brought Sea Biscuit to the attention of the Forum. They certainly do have quality products and both you and Patriot speak very highly of the owners. Also, glad to hear that the Elite I is working out well for you - your 15,000 miles in the first period of ownership is a bunch. Bill
  27. Of course, there also could have been an issue with the adjustment of the brake shoes and/or with the automatic adjusters. But, most likely (as jd1923 first pointed out) your brake controller is set too high. Any way you slice it (unless you have the bad habit of "riding" your brakes) 24,000 is way too soon under anything near "normal" usage to wear a set of trailer brakes out. Bill
