  2. I would be fine with a better installation, ease of use and longevity of the cable over a larger storage space. I believe this is a good example of OTT improving their design through the years! In our Oliver, Chris uses this space for storage, a small pressure cooker, yes TP and paper towels, extra coffee and a whole lot of dog food and treats!
  3. Funny! Moderation with AH is the key! 🌋🔥 David
  4. Thank you JD. I am hoping that @Patriotwill weigh in with a photo. However, it might indeed be easier to lube the zerks with the 45 degree bend. So with the angled zerks, you wouldn’t have to remove the tire unless you wanted to? I am sure Alcan would put the angled zerks on if I went that route. David
  5. Today
  6. I was wondering if anyone would notice those. The latch is still in working order, but I know many trays with a single latch would sheer off. Those blocks of oak wood with two screws in each have been there since 2021. I think Jason Essary even mentioned them when he saw them, and how they seem to work well. LOL You have a keen eye Bill. You win the prize for spotting them.
  7. Yesterday
  8. More like this. But still the same idea.
  9. You mean like - THIS VIDEO Bill
  10. So this may have been covered bf, but my shotgun rider pointed me to a video that used 8” stainless lag screws and 1 1/2” fender washers to use as tent stakes for our clam screen house. Boy what an easy way to secure your shelter. Beats the rock hammer by a mile.
  11. Hi Steve, thanks for your assistance with this plumbing project. I really appreciate it. Marc
  12. Thank you
  13. We know that most of the older PD's had two RP fuses, and likewise some had the Lithium switch. I suggest testing the unit amp output to definatively end the discussion. Just turn off the solar controller, turn off the Inverter (If installed) turn on the Converter, and either check the SOC reading at the SOC display (If available) or use a clamp-on-amp meter at the battery to directly to the battery.
  14. When I first read your post, my first comment was 🤣!!! Just search for keyword 'Victron' to find MANY upgrade threads! Here is my DIY thread, new Epoch batteries with Victron MP2 and components. We now have 7 Victron components (see app screenshot below), from the Smartshunt to Solar Chargers, to DC-2-DC chargers, etc! Adding the Victron Orion 50A DC-2-DC charger => Only a couple of Oliver Owners had upgraded to the Victron Multiplus II inverter/charger and Epoch batteries before I did ours, summer of 2024. And many have done so since. In this post Patriot shows an excellent professional installation! You have dozens of upgrade threads here you can study to make yours what you want!
  15. David, @Patriot should chime in. He prefers mounting the wet bolts, Zerk fittings to the inside. You get full clearance but the down side is you have to crawl under the trailer to lube the suspension. I prefer mounting the wet bolts in the standard direction, facing out, but then I replace the straight fitting with a 45-degree Zerk fitting to get the required clearance. I usually have some reason to remove the wheels every year or two and always lube the suspension at that time anyway. Your old suspension likely has 6mm x 1 threads on the Zerks. I'm pretty sure the Alcan wet bolts use 1/4" x 28 fittings. You can verify this with Alcan. https://www.amazon.com/dp/B0DQBPTK3Y/?th=1 Get one of these too, and many of us use a battery-powered grease gun. I have the Dewalt model with the LockNLube coupler attached and just the other day, I was able to lube the suspension on my truck in minutes! https://www.amazon.com/dp/B00H7LPKKU/?th=1
  16. The existing wiring is adequate just as long as you don’t try to use all 600 amp/hrs at once! 🌋
  17. Thank you Mountainoliver. There is the cost differential from the 3X 105 to two X 300 AH batteries versus, but two 300 AH would allow for future upgrades and it’s good to know that the existing wiring on my system would be adequate. Thanks again. David
  18. Yes, the monsoon season, late July through September has chance of flash floods, but it would also be > 110F! Will soon be in the dry season, Q2 starting with April winds! It’s so BRIGHT up here, my eyes hurt after 3 days! Even with back to the sun, the Oliver looks like a high-powered light bulb! Maybe should have parked with curbside to the north. Chance of rain this week is 0-0-0-0-0-0-0!!!
  19. Thank you for the advice, I will certainly look at them. Ron
  20. Over the years I have found that more amp/hrs would be of benefit. I initially felt that the 300 amp/hrs of the BB batteries were enough but with the compressor fridge on 24/7 during winter traveling and a few cloudy days here and there, my batteries would draw down to less than I am comfortable with. Anyway, two of the 300 amp/hr batteries seem to be the wave of the future. Having two still gives me the redundancy that I like. As built, Oliver used 4/0 welding cable for the main battery connections to the inverter. These are large enough for the 2,000 watt inverter and are protected by a 250 amp fuse. These wire for all other dc circuits is #6 welding cable and is adequate for the existing dc circuits in the trailer. I did not install a larger Progressive Dynamics charger or a larger inverter so I didn’t feel it necessary to upsize any wiring. I do have the air conditioner wired so that I can run it through the inverter but it only draws about 90 dc amps. The microwave by comparison draws about 120-130 dc amps. Really the only thing I did when I initially installed the lithium batteries six years ago was to clean up some of the wiring by moving all of the #6 wiring out of the battery box and I added a circuit breaker. Not too involved.
  21. I apologize for the thread drift - but - those battery slide tray stops are interesting. Cheap, easy to remove/replace and appear to be effective. Bill
  22. We are planning on having Alcan replace our axles and springs this summer. Several people have mentioned having Alcan position the zerks so as to make greasing easier. Can someone who has done this please post a picture of their zerks? This chore has always been difficult, and making it easier sounds appealing. Thanks. David
  23. Mountainoliver, thanks for the clear writeup of your battery issue. I was wondering if you could elaborate on your choice of two 300 AH batteries versus 3 or 4 of the 105 AH, of course besides the increased AH! Your trailer is similar to ours in age-have you changed any of the wiring as to gauge to accommodate the increased AH? What is a general rundown on your electrical system? Again, appreciate your writeup. David
  24. Especially in the rainy season. The views sound amazing, but I probably wouldn't try to tow my Oliver through that.
  25. I was thinking the same thing as you JD. However, I am not confident, no matter what I do, even multiple bolts, that my home-brew fix will hold up to the weight of four AGMs above, with road bumps. I'm no metal guy but I'm thinking of an adjustable solution. Something like this device, (only an example and quick search). https://www.rockler.com/heavy-duty-lifting-leveler?country=US&promo=shopping&utm_source=google&utm_medium=cpc&utm_term=&utm_content=pla&utm_campaign=PL&sid=V91190&gad_source=1&gad_campaignid=17424410624&gclid=Cj0KCQiAtfXMBhDzARIsAJ0jp3C2O8eZqs9M8M7CpmGG4oAKjWuDowPNrbrKNJUMh9-A2esKafqTJ6IaAlxpEALw_wcB I will notify Oliver Service so they know of the issue and see what they suggest as well. It's best they have proper metrics for future improvements. Cheers,
  26. Our 2023 is the same, and we were surprised to see it in the middle of the compartment, especially after seeing older models with the vacuum formed tray in there. But I suspect it is to ease the cable angle as much as to prevent using the bay for storage. Our TP and paper towels get stored in there.
  27. I don't mean to overwhelm you. While you are under the Oliver looking at the shocks, Pay close attention the leaf springs. Look to make sure the leafs are not sitting flat on one end or the other and/or over-sprung. If they are it could cause the shocks to wear out prematurely. If they are there is a huge topic on leaf springs ( more like a book). Remember to just take one thing at a time, you have an older trailer, but is built to last. There is a ton of information on this website, and people that care about there Olivers. Happy Travels.
  28. Yes, I saw all of the glowing reviews six years ago when I did my upgrade to lithium batteries. Back then Oliver had just introduced their lithium trailer and there weren’t many choices for lithium batteries. Battle Born was the gold standard then. This goes to show that lab testing has little resemblance to real world life testing day in and day out over the years. Even now and with most things we buy, we do our homework and research the best we can and select the best option. I’m not too upset with the way this has turned out. These batteries have traveled many miles in six years and have been well used all without any maintenance. We on average spend four months out of the year in our trailer every year, in 2025 it was six months. We are ready for the next chapter!
