Steve and MA replied to Lamar's topic in Mechanical & Technical Tips
This suggests the inverter doesn't supply power to the induction cooktop. If that's the case, I have no idea why Oliver would wire wire it that way. I know that in older models, the Xantrex 2000 watt inverter did not power the air conditioner, but not powering an induction cooktop by design doesn't make much sense. Steve -
Steph and Dud B replied to Lamar's topic in Mechanical & Technical Tips
Did you have your inverter turned on? If you're on batteries with no shore power you need the inverter on to create 120VAC electricity for the cooktop. -
topgun2 replied to Lamar's topic in Mechanical & Technical Tips
While the outlet itself may not be GFCI, it almost certainly is on a circuit that is GCFI controlled (i.e. is a slave off a GCFI). I'd suggest that you keep checking for another "tripped" GCFI. Bill -
Ok, I started my generator and now my True Induction Stove Top works. Am I missing something? -
Snack Chaser, thanks for the response. I found the buttons on the USB outlets. Didn’t know they were there and they all work. Good to know. All of the outlets that I can find work. There is one GFCI that I found near the floor in the forward dinette that was tripped. But after resetting it the induction stove still is not working. The one outlet outside is not GFCI. I’m going to hook into shore power again to see if by doing that the stove will turn on. I have both a generator and a 30 amp connector nearby for this morning yet. Lamar -
I remember. Our little community is festooned with flags lining the streets. Let us never forget.
I see where many have viewed this thread and thus, wondering if anyone else, other than a few others, have tried using a Cielo with their unit and what the results were. It would be good to know of any success with other unit brands, especially Truma, Houghton and Dometic; or even the newer inverter style units.
The Boerne Community Concert Band performed a concert in the town square yesterday evening. All patriotic songs, marches and songs of each branch of service. Also a nice rendition of Taps for our fallen heroes. It was a good turnout, lots of camping chairs and good weather. Small town USA. Happy Memorial Day! Mike
A day to remember and a day to not forget.
Snackchaser replied to Lamar's topic in Mechanical & Technical Tips
Lamar, sad to hear of your troubles! I have no idea how those stoves are wired, but they should be GFIC protected (Ground fault interrupter circuit). Those can trip for numbers of reasons. It could have its own GFIC receptacle under the cabinet somewhere, or it could be fed from an another GFIC receptacle. I'd check all the AC receptacles to see if they are GFIC and if they are tripped. Don't forget the one above the kitchen counter and the outdoor plug. If you find one tripped that won't reset, let us know for further investigation. Also check the AC wiring diagram in your manual, it should show whether the stove circuit is GFIC protected, and give clues where to look. The stove wouldn't be related to the 12v outlets. If you're talking about the USB outlets, they might have a tiny pushbutton switch on the front of them. The cigarette lighter type of 12v outlets are notorious for having the wire terminal pop off the back, but unlikely for that to happen to both of them. If the fuse is okay, then I'd take a close look at whatever you're testing them with. Good luck and let us know what you find. Geoff -
Lamar started following True Induction Stove Top will not turn on
We took possession of our new 2026 Legacy I in about April. Spent most of the time learning the systems and getting ready for our trip to Utah where we plan to do mostly Boondocking. We did one trial run overnight close to home to get the feel for things but we were tied into shore power. We were planning on a second unhooked but storms rolled and we had to leave. Tonight is night one on the 2 week long trip and we are boondocking. The True Induction Stove top will not turn on. It did turn on when we were hooked to shore power when we did the trial run. I am using a lodge frying pan, making sure we have the right material on the stove top. But there are no lights coming on the cooktop. I checked the breaker and it appears ok (knowing they can go bad and you can’t tell until you replace them). The inverter seems to be working as the microwave/convection oven works. The batteries appear to be above 90%. It’s gonna be a long 2 weeks without a stovetop. I don’t know if this is related but two 12 v receptacles on the street side do not appear to be working either. I’ve checked fuses but they seem to be fine. Any insight would be appreciated. I’ll also put a ticket in, but I’m sure Oliver is closed until at least Tuesday because of Memorial Day. Lamar Hull #1687 Also, for Veterans, their families, and those who lost someone they cared for in the military…I trust this Memorial Day, Remembrance Day, or Decoration Day will be meaningful to you.
Nope, doesn’t happen. The truck was absolutely coated with goo several times and the Ollie nose, but the windows literally get nothing, not even any dirt to speak of. The front edge of the outdoor power socket and edge of the Truma door get it though. The windows have been trouble and maintenance free in over 3k miles. Pro tip to make them even more maintenance free is to SiO2 them. Water beads and runs off beautifully too, I use Griots Garage SiO2 window treatment. It’s not as serious as a full body coat, less concentrated, but it’ll last 3-6 months. Hey even the Secret Service uses it on the Beast.
@jd1923 I would start hunting for the streetside light power wire at the main switch panel. I also think that is the easiest spot to tap the power wire for the new light you want to install, running a new wires, front to back, in the trough of the upper cabinets might be the easiest part of the job. Mossey
It was a pleasure meeting you as well. How was your drive home?
So, are you going to the Oliver Rally in October? And are you going to open your Ollie for tours? ;-)
Sure - but... It's tinted glass - the bugs simply will not know what hit 'em.🪰🦟🐝
We always called it the "kitchen junk drawer." Had one in every home we've owned, now including the Oliver! No remotes in ours, but most of the other stuff on her list, yes! 🤣 We have a spice rack above the cooktop in the overhead cabinet. Ours too would not fit in the junk drawer. I wanted all the many remotes, nicely held in the nightstand drawer. This picture is old and btw we traded in the Rummikub game for a Carbles board which doesn't fit in the nightstand! With our new A/C installation, I mounted the two most important remotes (fan and A/C) on the wall. We have two (2) TV remotes (since I always misplace one) so that one is always bedside on my custom shelf! I did screw into the interior of the nightstand drawer (should have used tape), but only 3M 4950 VHB tape on the fiberglass. Holds these shelves tight! More ideas Dan! 😎
I was thinking by the front edge of these windows will collect bugs. Let us know next time you have a windshield full of bugs! 🤣
Fixed! Thanks to all you guys especially @Tom and Doreen All you guys on this forum are so much help.
LOL -- I have all my remote controls in there, where Oliver Delivery team placed them -- but also these things: my fire lighters; a clear plastic travel "soap box" that I use to collect miscellaneous "mystery parts" that I find now and then; I keep 'em just in case; sandwich baggie with bulldog clips, paperclips, rubber bands and twist-ties small flat koozies small pliers and a screwdriver with changeable tips; pens, pencils, sharpie markers; small box of magnets; a pad of sticky notes; my extremely condensed "GO LIST" that is my pre-travel checklist -- it sits on top and I only have to take a peek to be sure I'm ready. But I like your use as spice drawer. My spices wouldn't fit in there, though.
It was nice meeting the two of you and pups Oliver & Winston this week while we were picking up Hull 1703 in Hohenwald.
