  2. JD, Mud flaps have been on my to do list for along time. I was planning to install John Davies design but your idea looks to be a bit less effort for instalation and appears to provide protection up into the wheel well. The clearance between the flap and the tire appears to have a small clearance. My concern: I have been caught by a storm on dirt / clay roads with not rock top dressing. The road surface stick / wraps a couple of inches of clay around all the tires. Does your design have enough clearance to accommodate this extreme situation? Hopefully, I will not be caught by these road condtions in the future but want a design for all conditions.
  3. Today
  4. Wow! And I thought being self employed had its issues. Can't imagine how you would deal with that scenario.
  5. I have "flat plug" four pin connections on my Oliver bike rack. I ran a connection wire under the Oliver to my F-150 and plug it directly into the truck. To accomadate both the trailer electrical cord and the bike rack cord I remove the truck outlet cover and replace when not towing. To remove and replace the outlet cover I replaced the plug hing with a pin that can be pulled and replaced. (If you are interested I can post photos tomorrow. This system has work flawlessly for two years
  6. Yeah, and then you have altitude. Our trip was mainly in June, not July-August! I expected heat in Kansas or Iowa but was not expecting it in the Dakotas and Wyoming. Finally, Colorado camping at 9K ft was cool! šŸ˜Ž Drove down to Phoenix on Thursday to pick up Chris from Sky Harbor Airport. High temp on the truck trip computer was 112F on Phoenix highways. The high in Prescott was 85F (low 58F). Our home is at 5400 FT. That's a 27-degree difference with 4300 ft change in elevation. In Arizona you can drive a couple hours and change your weather which doesn't work in the Midwest!
  7. In our case my wife's first employer no longer exists so that made things a bit more difficult.
  8. We pretty much dont travel in July unless we get an unusual cool stretch and can mobilize quickly. We have the quieter Truma ac but still the point is to be outside. If the heat doesnt get you up here in northland the humidity and mosquitoes will. I have researched how far north i need to go to get substantial temperatures drops (vs south central wisconsin) and the outcome was not encouraging. By heading to far northern wisconsin or the southern portions of the UP, we might see about a 5 degree temp drop. If we get up to the northern side of lake superior or the Apostle Islands that might improve to a 7 to 10 degree drop depending on positioning of the jet stream. Anything more probably requires the Canadian rockies!
  9. I agree working with the local office has been far better for us dealing with my wife's alzheimer's sister. It was very easy to get a call through, leave a message and they return the call. Apparently, or at least in this neck of the woods SSA office no longer takes in person visits any longer and haven't for quite a few years. It's also true their workforce has been substantially reduced. I would also recommend going back to the source of your wife's work place which is where this problems originates not the SSA per se. It's ludicrous they do not have a record of her working there for 20 years. Get a lawyer then I'll bet they will come up with her work records in short order. Sorry you're having to go through this, what PITA.
  10. I started mine in early 2026 preemptively because it all seems like a train wreck around the next bend. Waiting until 70 for max benefit seemed too risky so thought i should just start pulling my money out now. My benefit fell into place with only online input in late 2025. The spousal benefit took an additional two phones calls and there too, SSA didnt have the work record. But in the end that straightened out and the money is flowing. It helped to keep records of the agent you are talking to, get their phone number and work with the same person everytime!!! It might also help to work thru your local office.
  11. Dave I remember seeing that photo in the past. For me the pipe cleaners do next to nothing unless I go out and manually pump them back and forth which will remove quite a bit of water from the weep holes. On one window I have enlarged the weep holes, curb side rear, and that window seems to consistently have much less water in the channels and doesn't tend to leak either. I have never heard of paracord though, what the heck is that? Will have to look into this. Thanks
  12. Yesterday
  13. I posted this pic a couple years ago in another leaky window thread. Those weep slots are just not up to the task of keeping water from building up in the tracks (capillary attraction really hinders water flow). Folks talked about using pipe cleaners and lantern wicks to help wick out the water (maybe they work as well) but I find that 1/8" paracord works great. Cut some 3" lengths and stuff them in the slots. It's amazing how well they work! Don't heat seal the ends! Easy to replace and everyone has some paracord around right? Some may think it's kind of ugly looking but better than a wet bed! Cheers, Dave
  14. We've had rain off and on since last night and a sizable downpour mid morning, so with new weather stripping gaskets installed on the windows thought it would be a good time to see how well they have performed. Initially no leaks a good thing given the amount of rain. Brought out my portable wet/dry vac and vacuumed all the weep holes and ended up with around 6 oz of water collected from the windows. IOW's the new gaskets did little to nothing to stop infiltration. Photo posted below to illustrate the amount of water collected. Water was poured into a measuring cup to verify amount. Until this point there were no leaks inside the trailer, but it kept raining. This afternoon I checked again and sure enough a small leak had started to occur on the street side rear window. Not enough to be a major issue yet but the fitted sheet had a wet spot about 3-4 inches in diameter. Weep holes were not emitting or leaking water which was no surprise. The tracks have been cleaned twice in the last month alone. The upside down weep holes at the top of the frames have been plugged all to no avail. The new installed gutters do avert water running down the side of the trailer but offer no benefit from rain hitting the windows directly. I can't imagine living down south where torrential downpours are normal and putting up with this. I'm at a loss for how to deal with this going forward. Thanks
  15. Did you do this trip yet? Any feedback on the Chill Cube in hot humid weather? Does it keep up with the heat. Is power consumption doable on your batteries? šŸ˜Ž If your trip is still on the horizon, let us know afterwards. Thanks!
  16. That's what I thought. Living in Arizona we do not travel in the summer months. Then a couple experiences changed my thinking! Over two years ago we did a SW Utah trip, from Apr 21 to May 7, 2024. You wouldn't think it would get hot, springtime at high elevation, and most of the trip was fine. The day we left, we dropped down about 3K ft to US-93 and we boondocked in Wikieup, AZ. It was 93F when we got there and fortunately by 9PM it was cool enough to be in the cabin again. Back then we still had lead acid and the Dometic P2 so all we had tp remove cabin heat was the Maxxfan. Our next stop was to be Valley of Fire SP, NV where we had booked a dry camping spot. Quite a fitting name, given the forecast showed 99F highs for the next 2 days of our reservation. We wasted that money, instead having to book an electric site at the north end of Lake Meade. Plugged in to run the G-awful Dometic A/C. I had to wear noise-cancelling headphones to watch TV and to fall asleep! Thank goodness it was only 2 of 16 nights on that trip. Last year we did a 5-week trip to Minnesota, from May 29 to July 4th. We headed out east and swung north and took a northern route back. I believe it was 12 of 36 nights where we needed A/C. I had thought being so far north we wouldn't need A/C, bad assumption. We even had to book campsites in SD and WY where we would have much preferred to boondock in the woods but were forced into a campsite to plug in. After that trip, I vowed never to hear that awful Dometic P2 again! And also, my goal was to gear up in Inverter and Ahs and replace the A/C with a unit that would sip vs. gulp Ahs. For you, the freight-train NOISE of the P2 should be enough of a driver. You plug in so yeah power consumption does not matter (though we run ours for lunch breaks on the road too). Easiest DIY out there given size and weight. The only A/C model I've heard of that needs a custom platform was the Truma. The Chill Cube has a 29x29" footprint, making it a full foot shorter to the rear. It's also the lightest unit out there. Here is my DIY thread. This link will take you down page 2 to where my installation starts. I have installed 3 RV A/C models in the last 6 years, and this one by far was the easiest. You will need to add a furnace thermostat control which I also show here:
  17. According to AI, for whatever that's worth: "The Social Security Administration (SSA) has experienced the largest workforce reduction in its history, cutting more than 8,000 agency jobs—shrinking staff to its lowest level since 1967. These reductions and regional office closures are causing severe customer service delays, extended call wait times, and backlogs for vital disability and retirement benefits." I'm supposed to get my very first SS payment soon. Fingers crossed. Good luck.
  18. I guess not pulling the trigger on replacing the NOISY Dometic (Penguin 2?) A/C that came with our LE2 back in early 2022 has opened the field for more upgrade options? I’m still hoping to DIY this project - so is the latest consensus the ā€œChill Cubeā€? Is some kind of external roof support still an issue? NOT on lithium or solar, almost always plugged in, so AH’s are not on our criteria list. We like the condensate drains through the tubes between the hulls as opposed to running off the roof - but not opposed to running it through an external tube if that is an option. One big reason that we haven’t rushed into anything as of yet is that we -rarely- use the A/C. It’s got to get to the high 80’s before we opt to break out the earplugs, crank the TV volume to 100, and run the A/C until we get to 70-something and shut it off again. I guess I’ll run the original equipment until it stops working at this rate. (That, and avoid Texas in August…)
  19. It would help if you showed a picture of the "flat plug" on your new bike rack. Without seeing that, I might guess it could be the 4-pin trailer connection (for small trailers without brakes). Here is an example: Curt Vehicle Wiring Harness with 5-Pole Flat Trailer Connector - 60" Wire Lead CURT Custom Fit Vehicle Wiring C58531 What you're attempting is not an easy job! Most trucks that have the 7-blade connector also have a 4-pin connection zip-tied somewhere above the bumper. But the Oliver doesn't have one! 🤣 You can pick connections for brake lights, turn signals, reverse and running lights in one of two locations. 1) tap into the lights at the rear of the Oliver, or 2) at the junction box where OTT splices the 7-blade harness into the Oliver trailer wiring. I believe this junction box in newer Olivers is inside the bathroom vanity, but who knows on a 2026. In our hull it's easily accessed under the front dinette seat (see picture). If I was doing this for our hull, I would pick option #2 since you can see these wires are easily accessible (likely not so in your Oliver). The link I supplied shows a 60" wire which is fine for rear wiring. If you are going up to the front harness, you want something like this that has longer wires. It's actually rather easy to run wiring from the rear, along the streetside basement, all the way up to front junction box. 35 Ft 4-Way Trailer Wiring Harness - Wishbone Style - 42" Ground Optronics Trailer Wiring A35W42B The hard part front or rear is to tap into the existing wiring. I rarely recommend using 3M Scotchlokā„¢ connectors, but I would in this case since secondary rear wiring on a bike rack is not exactly "mission critical." Hope this helps! šŸ˜Ž
  20. Yeah, at a minimum you gotta remove the basket to spray Vortex. As you can see in my picture, it gets rather dirty under there! I removed all this just for ceramic coating, to do the job right. Removed the doghouse handles and latches, the outlet plates, anything screwed down or riveted. Whatever doesn't come off has to be masked for Vortex application. Can't stand warning labels either! You can see where a couple were removed and the one showing was removed next. With the basket off, it can be cleaned thoroughly with a degreaser that you wouldn't want to use if the basket was still above fiberglass. I'm not interested in PPF or Vortex. Now that we have a good ceramic coating shine we prefer to enjoy the clean look. Don't forget mud flaps, regardless of other protection, and not just on the TV. I found the dirtiest part of the Oliver was always the fiberglass underneath behind the Oliver wheels all the way to the rear bumper, grease, road tar, etc. It was bad, but not anymore! Either way, the result is in the prep work! šŸ˜Ž
  21. AI keeps telling us that the local SSA office CAN print out the report we need IF we can convince them to. But these days you need to make an appointment online and ā€œI’ve tried mailing this and it keeps getting lostā€ isn’t a choice if the appointment system. AI also says if all else fails ā€œCall your Congressmanā€ yeah - if you haven’t had enough of inefficient bureaucracy yet.
  22. We do the clean-up each time we break camp. (Though around the cat little box - every time we attend to it.) We have a carpet runner - that goes from the bathroom door to under the edge of the (king) bed and covers the width of the ā€œlinoleumā€. I shake it out to get rid of the loose dirt, and we wash it about once a month or so. Our biggest issue is cat hair - which seems to be magnetically attracted to the upholstery. It’s not a big issue for the furnace return register as we rarely use it. We go through the sticky ā€œlint rollersā€ at a pretty good rate. We did inherit one of those large outdoor rugs/mats that we use if we’re going to be in one place for more than a few days. Out West, we found it likes to blow away. We found it two or three camp sites downwind once.
  23. Hi folks, Totally non-Oliver and not even travel or trailer related - but wanted to ask if anybody had any tips for getting the Social Security Administration to actually do their job. About two years ago Debra contacted a former employer’s pension administrator to claim the pension she had coming for 20 years service. They told her they had no record of her even working there, and would need to obtain a detailed report from SSI to prove she worked there. OK - a bit wired, but not the first time we’ve had something odd happen. (My theory: Debra’s last name starts with two ā€œAā€s, so my data processing background tells me that first record in a database often gets pulled in as a column label and lost.) Anyway - download, print, fill out the form from SSI online, send it in with the required fee, and wait - up to 120 days. 120 days - and then some - come and go and no report in the mailbox. Several calls and holding for hours online and the final answer is ā€œwe can find your request and we’ll have someone look into it and get back to you.ā€ (Guess what happened…) Several more weeks/months later we have to contact them again - still no record of the request - they DO show the payments received though. Fast-forward to a year later after several more phone calls. They send a packet out that says they couldn’t complete the request because they couldn’t find the signed form - so she has to start all over- but - they do send a voucher of sorts showing payment. So - she re- mikes the whole thing with the voucher and a new, signed request form - and we wait. No reply 150 days later. So the phone calls begin. Again. Last week - the person on the phone says ā€œWe have no record of your request… we’ll escalate this to a priority levelā€ (which they did twice with the first one.) So - here we are with a pension we can get because SSI can’t fulfill a fairly routine report of the records the pension custodian needs to do their job. Debra wasn’t even going to pursue it, but I worked for the same company and am receiving a pension. (Different last name.) so I KNOW there’s $$$ on the table. Any suggestions besides tearing hair out?!
  24. Is THAT what the Oliver looks like without the front storage basket?! I barely recognize it…
  25. I figured if I got totally locked out - even though we kept a set of trailer keys in the truck - I can just slide a side window open from outside and climb in cat-burglar style. The 2025 Sierra has the keyless entry (fob in pocket or purse) which is reliable (so far) and you can also unlock it with your smartphone. (Which is usually reliable - u less there’s no cell service…) So I’ve kinda gotten used up not using it needing a key. As I mentioned before - I know there are a lot of keyless locks around, though most likely not suitable for RVs. I’m sure there’s some other ones out there that are simpler and less prone to failure. As I also mentioned - using our trailer for several months at a time for five years now, I’m not going to gripe too much about things that quit working. I’ve had to replace the smoke alarm twice, the CO/propane detector, swap out the tire valve stem cores, stop the Truma water heater from sending fireballs out the side of the trailer, replace the television, yank out the awning seal, replace the Nor-cold freezer hinges twice, the Furrion Stereo, one touch-light and another one failing, replace the black tank valve, patch up a leaky window frame, tear the MaxxFan down to replace the motor, oh - and the dang Dometic A/C still sounds like a 747 with full takeoff power. (see there? You got me started….)
  26. 2026 LEII hull 1673. Just purchased a new bike rack Kuat Piston Pro X for the back of the Oliver that has turn signal and brake lights installed in the rack. It requires a flat plug connection. Any suggestions on how to get that flat plug powered from the trailer? I searched the database for ā€œflat+plugā€ and didn’t see anything…
  27. We have a daily interior clean-up. Amazing the amount of dog hair that comes out of the vacuum. We have 3 small shower rugs that I take out and brush off. Shake out Fiona's bed sheet, and also brush off the L.L. Bean waterproof mat at the door. 5-8 minutes out of our day. The heater exhaust vent is the first thing my wife vacuums. She does the interior cleaning. Once a year I wipe down the inside fiberglass and use the wax mix TopGun shared with the group.
  28. With my Turbro Inverter, once it reaches set temp I'm seeing between 250-600 watts during the day in 85-95 degree weather with 80+ humidity so you're probably pretty close with your numbers- and we keep the inside temps low, too... around 70-72. Haven't monitored during the night yet but obviously the watts draw will be even lower. Don't know why anyone who boondocks would buy anything but an inverter AC/Heat pump.
