taylor.coyote last won the day on January 1
taylor.coyote had the most liked content!
124
2016
2019 F250
4,258 profile views
taylor.coyote's Achievements
taylor.coyote started following 2 broken leaf springs / shocks , PD-5100 Automatic Transfer Relay - Loose connectors , 2nd Awning? and 4 others
taylor.coyote replied to Wayfinder's topic in Mechanical & Technical Tips
Last year my original box shorted-out due to loose connection screws. The loose connections caused melted wire coating, melted part of the housing and could have started a fire. The new box has much better connections. Based on my experience, the price of the new box is cheap insurance. The issue with screws loosening is well documented within this forum. At minimum, you should check screw tightens regularly. best of luck -
In addition to your awing decision. We would strongly recommend NOT TO INSTALL THE RAIN GUTTER ADHESIVE STRIP under the awing. We found its primary function is to capture debris that makes a big mess on your roof. We removed our gutters several years ago and let the water drain down the side of the trailer with no issues. If you wish, you can install gutters over the windows. We live in a rainy climate on the pacific coast and are much happier without any gutters. Without gutters, you will find it much easier to keep your trailer clean. And congratulation on your purchase. We hope you enjoy your Oliver as much as we have.
We purchased a used trailer in 2019 that has two awnings. We spend a lot of time in the remote high deserts boon-docking in the western states. Over the last six years we have yet to use the awning on the back side of the trailer. The good news: we have been able to use the second awning for spare parts on a couple of occations to keep our front awning operational. Based on our experience, we would not recommend investing in a secound awning.
Nice, well done. I like your solution much better than ours. We used up a left over roll of thin aluminum sandwich foam insolation purchased for cold weather window inserts.
Battery Box Separation
taylor.coyote replied to Mike and Carol's topic in Mechanical & Technical Tips
GJ, thanks for the tips on suspension and tire pressure. I'm running Alcan springs and 50psi in the tires. Hopefully this combination with lightweight batteries and steel rivets will be a good solution after my repair -
We are repairing our battery box separation as we speak per the old string from Galway Girl. The combination 250lbs of AMG batteries, off the grid travel and aluminum rivets proves to have been a bad marriage. Now have 300AH lithiuim batteries weighing in at 80lbs and steel rivets. -
Pebble Flow trailer and Rivian in the wild
taylor.coyote replied to taylor.coyote's topic in General Discussion
I perceive EV technology to be very cool and loved by several friends. Respectfully, range anxiety is not for me. 225 mile range would be very confining for our off the grid style of travel. I'll let the charging stations become better developed and dependable, EV ranges to increase and the let early adopters scout out this new frontier. I'm old enough and my F250 6.7 is young enough that it may out last my ability to drag a trailer around. Best to you and hope your EV tow vehicle serves you well. -
I like to learn but with the Ollie, it usually is attached to a price tag.. As they say "you can't take it with you"
And my wife says I over think things..... Shackle and lug nut torque values, grade 8 vs grade 5 bulldog hitch bolts, tire inflation and ongoing managment, packing bearings temperature monitoring. Now an expaned intellectual conversation on safety chains a the length of the emergency brake cable. As before with many issues, my Ignorance was bliss. Now I need to consider the above safety chain / emergency brake strategy with the hope we won't see Ollie pull up along-side our truck.
Jd, I missed your question about remote camping in the Navajo nation. The answer is yes, we were able to camp outside of campgrounds in remote areas. You can get permits at the visitor center in Cameron for various areas. We had planned to camp in the Coal Mine Canyon area but it was closed due to road damage. The folks at the visitor center recommended the little Colorado River Canyon. The Little Colorado River Canyon was very remote but you had to work / very slow go to get there. It's out there, you will likely be alone and have dark skies. Be sure to ask about roads for your Oliver. We were cautioned about some of the roads.
Last night on the road after 6 weeks. We are staying at Dumbarton Quarry Campground, part of Fremont Ca park system. What a nice surprise, one minute we are fighting Bay Area 6 lanes of traffic and next you are in what seems to be a remote place miles from the concrete jungle. Besides an oasis in the middle of madness, the price at $73 is very reasonable for the city. This is a great stop over if passing through the bay-area. We'll be on the road at 4am to beat traffic. Should be home in humboldt County, Ca before noon tomorrow.
Pulled in to Dumbarton Quarry Campground (great place to stay if needing a place in the east bay / San Francisco). A Rivian pulling a Pebble Trailer pulls in. The driver un-hitches the trailer and uses his I-Pad to back/drive the trailer in place. Next the leveling jacks automaticly lift the trailer off the ground and self-level. I spoke with the owner and this is the first shakedown night from the factory in Fremont, Ca . The owner said he should get a range of 200+/- miles with the Rivian/Pebble combo. The Trailer motors are said to add about 100 miles to the Rivian's range vs pulling a standard trailer. I have to say it's very cool and makes our Oliver / F250 look and sound like a dinosaur. Regardless of how cool, this guy is way braver them me. I like being able to carry a couple of fuel cans for a bit more range (more than double the Riven/Pebble combo). We need early adopters and I'm not that guy. I wish him the best. Yes, the Pebble is very cool.
JD, we have hull #124 (2016 production) and broke one spring two years ago. Initially we replaced both springs on the damaged side with the stock springs. Later, we learned of the issues with stock springs and replaced all the springs with Alcan parts 5,000 miles ago. It was my understanding the issue is more about the stock spring design than the production year.
Nearing end of a fantastic 6 week trip. Camping at Morrow Strand State Beach, Ca Clear and sunny with blustery winds, 74 degrees.
