Chukarhunter
Chukarhunter last won the day on February 25 2024
Chukarhunter had the most liked content!
4 Followers
2,274 profile views
Chukarhunter's Achievements
Collaborator
Collaborator (7/14)
384
  1. I spliced a male cigarette lighter plug to my Tiretracker signal booster. When I tow, I just plug it into a 12 volt plug in the rear of my tow vehicle and temporarily attach it with a piece of adhesive velcro. One could also plug it into one of the 12 volt receptacles in the trailer. When I am finished towing I unplug it, lift it from the velcro and store it away until the next trip.
  2. Those that might be contemplating getting a Levelmate should know that a newer model was released last year called the Levelmate Max. I had never gone for a Levelmate before but decided to try the Max version and have been extremely satisfied. There is absolutely no need to hardwire it because it runs on three AAA batteries that last over a year and can be replaced in under a minute. As far as technology upgrades over the Pro and Pro+, the Max adds a gyroscope in addition to the accelerometer. This enables one to observe continuous instant changes in level (side to side and front to back) with the trailer hitched and vehicle moving (called leveling on the go). This feature can be useful in finding the best spot to stop and unhitch when boondocking on uneven ground. Another feature is that it can remember the preferred tongue height when it is time to hitch up without having to back the vehicle up to the tongue first. Levelmate recommendz permanently mounting it with screws but I used 2 inch wide heavy duty velcro to mount it just inside the door under the rocker switch panel. No holes drilled.
  3. I may do a bathroom hatch some day but for expediency, I experimented with a quick and simple (and reversible) hack designed to achieve greater heating of the area under the sink while also adding a return vent from the bathroom into the basement to improve heating in the bathroom (My 2020 didn't have a return vent in the bathroom like the newer models). I had also concluded, as have most, that the heat supply vent under the TP was essentially useless because of the long flex-duct run to the bathroom. It never did supply much heat. What I did was temporarily removed the towel bar rack, disconnected the flex duct from the heat vent under the TP holder, dropped the flex duct to the floor (where it heats the area under the sink) and replaced the towel bar rack. That gave me a return vent in the bathroom (without cutting a new hole) that pulls heated air from the cabin into the bathroom and then into the space under the sink, while the loose flex duct also supplies additional heat to the area under the sink. You can tell it is pulling a measurable amount of air through the bathroom into the sink cavity by looking at the dangling TP moving when the furnace is running. I now have two cold weather seasons of experience with this setup and I will never go back. As long as I keep the bathroom door slightly open against the closed twist lock, the bathroom stays warmer than it ever did with the flex duct attached to the vent under the TP. Also, I have noticed that the bathroom feels a little bit warmer when a late night visit to the bathroom is called for, likely due to less radiant heat loss from my (un-shirted) body, due to the warmer surface of the fiberglass surrounding the sink cavity. The additional heat under the sink cavity also improves the heating under the kitchen sink area as the heat from the sink cavity circulates rearward to be recirculated through the furnace.
  4. I also store my Oliver remotely outdoors through the winter but do not winterize. All above advice is solid. I use remote temperature sensors and have found that the coldest spot in the basement is in the lower rear of the trailer (storage area) where the water lines run. If that location stays above freezing, I am confident that nothing will freeze. The one additional thing I did was change out my thermostat to one with remote monitoring and control. I chose a Micro-air Easy Touch RV thermostat. It has both remote wifi monitoring and blutooth. https://www.micro-air.com/products_easytouch_rv_thermostat_touchscreen.cfm When temperatures are forecast to stay well above freezing, I can either turn the furnace off (remotely) or set it low (42-45 degrees). When the forecast is for below freezing temps, I turn it up to around 50. My remote sensor will send an alert to my phone if the rear basement approaches freezing temps and I can then turn the thermostat up even more from home. When daytime temps rise above freezing again, I turn the thermostat down to save propane.
  5. I apologize for chiming in late but just got home last night from a 10 day round trip from Oregon to Saddlestring, Wyoming towing our LE II. The discussion above omitted a very relevant specification when determining safe towing weight limits which is Gross Combined Weight Rating (GCWR). I believe the GCWR for your Tundra is 11,800 lbs. If you were to pull the the maximum trailer weight of 6,700 lbs, that would leave 5,200 lbs of remaining GCWR to work with for tow vehicle plus cargo weight. I believe the curb weight of your Tundra is about 4,800 lbs so if you tried to tow an LE II at 6,700 lbs, you would only have about 400 lbs of cargo capacity. If you were to keep the weight of the LE II at or below 5,700 lbs with full water and propane tanks, it would leave you with about 1,400 lbs of cargo capacity. In my opinion, this would allow you the flexibility to tow an LE II safely with your Tundra until you find (or can afford) the tow vehicle you really want. You would just need to be very disciplined in traveling light in terms of passengers/cargo until you do. I have pulled our LE II for 5 years now with the 4.7 liter engine. I find it to be marginal but adequate for my needs, but then I am a minimalist, the kids are grown up and gone, and we typically depart with the LE II at 5,600 lbs or less with a full water tank. That said, I do want a more capable tow vehicle but am waiting for the next evolution of EV batteries (e.g., solid state) to arrive.
  6. One strip is enough to cover all four porch lights with enough left over to cover the bottom outside lights as well
  7. I did the same thing adding the film to my exterior porch lights shortly after I brought my Ollie new in 2020. Many owners have done the same thing. It is one of the easiest, lowest cost, and most satisfying mods I have made. It only takes a few minutes to apply the film to the lights and the film is durable. The lights still look as good as new after four years. The porch lights also attract fewer flying insects now.
  8. A Honda 2200 EUi has a continuous rating of 2,000 kW which means it is capable of putting at most 2 kilowatt hours (kWh) of energy into an EV battery if it runs for an hour. An EV pickup like the F150 lightening will travel from 2-2.5 miles on a kWh of battery power in normal driving. That means if you wanted to add driving range using an Honda 2200 EUi, you would need to run the generator for a full hour for every 2 miles of additional range you wanted. Level one chargers at home (120 volts) are limited to about the same charging rate as a 2200 EUi; a rate of about 2 kW (15 amps x 120 volts equals 1.8 kW charging rate). Level 2 home (240 volt) chargers can charge a vehicle up to a 16 kW rate (i.e., the F150 Lightening) depending on the specific vehicle. The charging rate using AC power from home is limited by the charging circuitry in the vehicle that converts AC power from the home plug to DC power into the batteries. These internal vehicle electronics limit the charging current (whether 120 volts or 240 volts) so charging the vehicle will not trip the circuit breaker in the home panel. The charging stations being built along freeways, et. are DC fast chargers. They supply DC power directly into the vehicle batteries and typically are capable of charging the vehicle at a rate of 150-250 kW rate which is why they can charge a vehicle like an F 150 lightening from zero to 80% charge in way under an hour. It would take a 2200 EUi over 50 hours of continuous charging to do the same. The good news is if you had an EV like the F150 lightening that is capable of bi-directional power flow, you wouldn't need much if any battery storage in the Oliver itself. When you set up camp, you plug the trailer into the F150 (with 130 kWh of battery), you have over 100 kWh hours of battery reserve for over a month of camping assuming you arrive at camp with close to a full charge in the vehicle. My son is a rural large animal veterinarian and has an F150 Lightening (11,000 lbs towing capacity) as his work vehicle. It gives him several hundred miles of range which is more than enough for a day of ranch calls and he can recharge it from empty to full overnight at home with his 16 kW level 2 charger. Last summer his batteries in his travel trailer were nearly shot but he didn't replace them. He just took his family camping and plugged in to the F150 when they got to their campsite. My son did keep his gas powered F150 for now for the rare times he needs to travel out of state or go on hunting trips more than several hundred miles from home.
  9. I have lived in Oregon my whole life. You have planned an awesome trip. I second the recommendation to visit the Olympic National Park in Washington with a day trip to Victoria (and Butchart gardens) via passenger ferry. As for the Oregon coast, I would seriously consider the incredibly scenic Southern Oregon Coast instead of the much more crowded central Oregon coast. Since you are planning to visit the redwoods, afterwords you can just continue north on Highway 101 from Crescent City California through Brookings, OR and north to Reedsport where you could loop back east to interstate 5 if you wanted to. Some of the nicest coastal State Parks in Oregon are in the remote south coast stretch and there is less tourist pressure. The other thing I would share is that if you only see the western part of Oregon and Crater Lake, you will miss some of the best of the state. Over half of Oregon lies east of Crater Lake and is high dessert and canyonland country. Much of it is very remote with few lodging opportunities and only the lucky folks with a good trailer can easily take advantage of it. If you have time, one of the most remote and spectacular places in Oregon is Steens Mountain. Should you decide to make just one stop in Eastern Oregon along the way, I would suggest making it Steens Mountain and surroundings. (Steens Mountain is the first place I went after I brought my Ollie home from Hohenwald). You can reach Steens Mountain by traveling west from Interstate 84 at Ontario, OR, or west on Interstate 80 out of Salt Lake City and cutting north at Winnemucca on highway 140 to Steens Mountain (Frenchglen, OR). There is a wonderful BLM campground outside tiny Frenchglen called Page Springs, and it is close to the start of a gravel road that allows you to drive to the top of spectacular Steens Mountain itself at over 9.000 feet. Your timing will be good for a visit to Steens Mountain as it is only accessible a few months out of the year due to late snow melt (July) and closure when the first snow falls in late September or October. (bring insect repellent) The surrounding area is rich in history, much of which dates back to the mid-1800's, the Oregon Trail, Cattle Barons and gold and silver mining. From Steens Mountain, you can continue on to Crater Lake via Bend, OR and then south down to Lassen and then west over to the Redwoods. Something to consider if you have the time.
  10. I am old as well and we both have memories of our roadster days. I once wore a new set of tires bald in 12,000 miles with my 68 Datsun 1600. Anyway, I live in the inner city (Portland OR.) and have a low height garage so a truck is just not practical for me and on street parking in my neighborhood is a challenge. My plan when I first purchased #657 was to limp along with the 4Runner just long enough until a tow capable EV SUV became available. The Rivian would work but according to my wife I can't afford one. And actually, the 4Runner is working out much better than I could have hoped. Of course, having driven nothing but manual transmission cars most of my life (like you probably), I am very comfortable manually shifting the automatic when towing to enhance performance and the transmission in my 4Runner is designed for maximum engine braking when descending. I am comfortable driving in the mountains and rarely have to use the brakes much to control speed, even on 6% downhill grades. I have found that the vehicle struggles with an OEM air filter but performance excels with a K&N air filter. I do have to be careful in loading my TV and have become accustomed to traveling light. If I travel with both my wife and dog, I have used up my cargo capacity and most everything else goes in the Ollie. I always keep the Ollie below 6,000 lbs. My 4Runner is a rare version called the V8 Limited that was factory set up for towing and was made in a Lexus factory in Japan. I am the original owner. I think it is almost identical to your GX470 but mine has the x-reas schocks and a self-leveling rear end which yours may not have. It is also factory rated to tow 7,000 lbs which I believe is a bit more than the GX470. Anyway, right before I drove 2,400 miles to pick up my new Ollie, I replaced the x-reas shocks and air springs at a cost of $5,600 and had a complete brake replacement with all OEM parts at a cost of $2,600. I now have over 20,00 miles of towing my Ollie and quite a bit of it has been on interstates in the mountains of Oregon, Washington and Utah. The car does struggle somewhat at high altitudes going uphill on windy two lane roads, but downhill is never a problem and I have never experienced any sway. That said I sure hope to upgrade to a more capable TV soon. Then we can start bringing a few toys along with us🤪
  11. My choice of propane tanks goes to (minimizing) weight being the highest priority. My tow vehicle (TV) has very little cargo capacity so minimizing tongue weight is very important to me. I am an outlier in that regard on this forum. To minimize weight I switched to composite propane tanks shortly after I acquired my LEII. When empty, they weigh about 1/2 of what a common steel tank weighs although the capacities are reduced somewhat. The 20 lb equivalent holds 17 lbs and the 30 lb equivalent holds 22 lbs of propane. Most people couldn't justify the cost because they are much more expensive than steel tanks. However, if lowering tongue weight is important for you as it is for me, you might want to check them out. They are way less expensive then a new TV🤑 I am pretty sure there are a few of you out there that would really appreciate the light weight and don't do extensive cold weather camping. Even if I get a new tow vehicle, I will probably continue to use the composite tanks because they are so much nicer for everyday use. In addition to being much lighter when full, they have a wide base and are extremely stable in the back of the vehicle without tie-downs. Also, they have no sharp edges whatsoever so it is much easier to carry around and pack in the Ollie when carrying a spare tank as I do for cold weather camping. I have never had any problems getting them refilled. They are made in Europe and imported by Viking Cylinders. https://www.vikingcylinders.com/online-shop/ Since they have a much larger diameter base, if you switch to them you will need to switch out your 2 tank mounting tray inside of the doghouse. Viking Cylinders sells a custom fit replacement tray for $40 and the old tray is easy to swap out for the new one and back again if necessary.
  12. The maxxair vent and bathroom vent don't seal real tight so a fair amount of warm cabin air can leave through those vents when closed IF and ONLY IF there is a window open or as you appear to have discovered, a source of outside air entering your basement. I have never experienced condensation under the hatch cover above the furnace like you are so it seems plausible the cold outside air is coming into the basement in that area. Could it be possible that the outside air intake tube for the furnace has cracked or separated from the combustion chamber inside the furnace housing? That would allow outside air to flow freely into the furnace housing and then into the basement through the fan intake vents when the furnace is not running but the furnace would probably still work. It doesn't seem at all likely but that could possibly explain it. Just a WAG.
  13. After four years of towing my LE II and reading countless threads on the Anderson and cargo capacities in general, I have come to the following conclusions. The Anderson improves the towing experience and aids in control of the vehicle in emergency maneuvers. The additional time to hook up the Anderson is negligible compared to the increased safety and driveability it provides If your manual states that a weight distributing hitch is required when towing over 5,000 lbs, it is because it is probably not possible to take advantage of the entire cargo capacity of the TV without using a weight distributing hitch. This is because cargo capacity as stated on the doorjamb sticker is always a product of the maximum front axle loading capacity plus the maximum rear axle loading capacity. It is often overlooked, but you can be driving down the highway with your Gross Vehicle weight 300 lbs UNDER the rated GVWR, but if the rear axle is loaded over the maximum rear axle weight, then you are overloaded. When a vehicle manufacturer states that a weight distributing hitch is required when towing over 5,000 lbs, they have assumed that when towing a trailer with a 500 lb tor higher tongue weight, it is not possible to load the vehicle to its rated cargo capacity (i.e., loaded to maximum GVWR) without overloading the rear axle axle. If you weigh at a scale, it is important that you weigh the front axle and the rear axle. If one is over its rating, the maximum rated cargo capacity of your TV is irrelevant. I am no expert and I hope others will correct me or provide the appropriate caveats to my description above if advisable.
  14. Does your water pump cycle on from time to time even when not using water? If so, that probably indicates a slow leak somewhere in your plumbing system. When you first turn your water pump on, it will pressurize the tank and then turn off. It will not come on again unless you turn on a faucet or flush the toilet. However, if there is a very slow leak, it will come on again after a few minutes or longer because the leak will gradually lower the pressure in the water system. This happened to me last time out after traveling about 30 miles on washboard roads. I traced the problem to a slow leak in one of the push-in compression fittings by the Truma on demand water heater. Even though the leak was in the rear of the Ollie, the leaking water was dripping out one of the forward weep holes.
  15. The only settings I had to change in my 2000W inverter/charger was to change the charge setting from flooded batteries to a LFPO4 charging profile. Our early versions of the 2,000 watt model did not have a LFPO4 setting to switch to so I selected the "custom" battery option. I then set the custom absorption voltage to 14.6 volts (as recommended by the battery manufacturer) and I was done. The main reason you need to adjust the absorption voltage to a 14.4-14.6 volt level (consult your battery manufacturer for their preferred setting) is that the LFPO4 batteries require a higher voltage than flooded batteries to reach full charge, compared to the flooded or AGM batteries. To be confident how to do this with your model of converter/charger, you really need to consult the "Optional Equipment" manual that came with your Oliver. I just looked on the Oliver University and the factory manual they have posted is apparently a mid-2020 updated manual that appears to reflect a firmware upgrade to the units we have, since the manual on the Oliver site displays a LFPO4 setting in the menu, which my 2020 version does not show in the menu and definitely did not have. I would post a picture of my settings table from my manual, but it is across town in storage. PM me if you want me to retrieve my manual and post a copy of the settings menu here. I would be happy to do so.
