fairmontrvpark
Everything posted by fairmontrvpark
When you flushed out the trailer did you also flush the outside shower? I also had some difficulty flushing my trailer out last spring it seemed to take longer than normal to be rid of the anti freeze, associated smell and bubbles in the water. I wrote it off to the design of the tanks being relatively flat bottomed and difficult to empty 100%. I finally set it up with the front end high and flushed everything thoroughly a few times in that position and I was happy with the result. Good Luck. Dan
Dometic Gas Stove doesn't ignite
fairmontrvpark replied to Citrus breeze's topic in Mechanical & Technical Tips
I am glad this solved your problem. For anyone else considering using a vacuum in the future remember that they are not designed to vacuum Gas and I would be very careful of anything that may have a motor that can ignite them..... Safety First. Happy Trails. Dan -
Towing liability- Your advice or opinion
fairmontrvpark replied to Roger P's topic in Towing an Oliver
There is an entirely opposite side to this subject. I have seen three trailers with frame damage due to weight distribution being used on 3/4 and 1-Ton trucks with trailers that were designed to be pulled by lightweight vehicles. These frames cannot counter the stresses that a 1-Ton truck produces by the time the weight distribution system is torqued enough to level it out and it destroyed these trailers and campers ended up stuck here until they had repairs done or purchased another trailer. I agree that a one ton does not need a WD system to tow an Oliver I will leave the litigation stuff to the pros in that department. -
While attempting to remove my ceiling shroud from the Air Conditioner I found two screws that I accessed through the side vents (in addition to the typical two screws that hold the shroud in place) Despite these four screws being removed the Shroud still appears to be attached near its center. If anyone has experience with this particular situation I would appreciate your feedback. I have a call into service already, simply throwing this on the forum to see if any of you have a solution for me. Thanks Dan
The Trauma is Awesome. Its like a heated steering wheel.... now that I have it? I NEED it.
Greetings from new owner in Washington State
fairmontrvpark replied to Landsplash's topic in Introduce Yourself
Congratulations, Enjoy your Oliver and Safe Happy Trails. -
Thank You for this awesome post about winter travel with your Oliver! Your pictures are great and your trip sounds fun. There is too much negativity on this forum relative to winter travel, these trailers are very capable as are you it seems. Safe and Happy Trails Dan
Hull #928 Left the Factory on Oct 12th.
fairmontrvpark replied to fairmontrvpark's topic in Delivery Day Photos
Oliver installed the larger coupler. It is an option, or it was on my 2021 model year build sheet. -
What Hitch to Arrive with to Pick up my new Ollie
fairmontrvpark replied to AlbertNTerri's topic in Introduce Yourself
Albert, I am sure You will be very happy with the Weigh Safe Hitch. I use one as well and am very satisfied with it. The ability to instantly see adjustments you make to your payload is priceless in my opinion. Good luck and Happy Trails. Dan -
Congrats! be safe and enjoy your Rig! I have a short must do mental list before I start my truck and that valve is on it. List is still a work in progress as I add things to the trailers contents. Happy Trails Dan
You know, it actually was because the weather allowed me to leave all windows open every night for 14 nights and now that I have everything closed to keep out the cold I do not smell that "new smell fiberglass oder" that it had when I picked it up. So it was a good time to take it out for the first time. Thanks Again Dan -
I did, and I hope you all enjoyed Branson. You were correct I had no trouble making the Fresh Water, Grey and Black last for the 4 nights I was dry camped and could have doubled that at the rate I was going. Thanks again Dan -
Thank You for the well wishes, I did get some photos up. Today I pulled 540 miles in some respectable sidewinds that had the semis doing 65 on parts of HWY 90 and I am happy to report this thing sticks behind my truck like a 10 year old well trained hunting dog. I am very impressed (again no Anderson Hitch or any other sway control just whats shown above in the pic. Temps are lower here 40's and the heater is more than sufficient as well, One of the benifits of this smaller space is its quick to heat up and it stays that way easily, I am cheating with a three setting "vornado" brand Electric Heater that I saw someone else mention in a post and bought while I was in Kansas City at Target, it works well in here I have it set on low so the Oliver heater functions as well to keep the basement warm too. -
Hello Wayfinder, I suggest you inquire about a larger rental propane tank for your “full timer” situation. For my full time winter campers the local Propane provider delivers 110 gallon propane tanks and connects them to the RV and tests all connections as well for $45.00 a year tank rental.... it’s cheap and simple as they also deliver the Propane and fill these tanks so you do not have to haul your 30 pounders into town all the time. And the price of the fuel is lower than when you refill.... it is a win win situation trust me the only question is if it’s available there in your area. Dan
Not one single thing to complain about, Thus far its everything I expected and more. Tows like a dream behind the One-Ton (no anderson hitch just a 2-5/16 Ball.) My tongue weight is 610 Lbs. Fresh Water Tank is Full rest empty. My Hitch provides the actual weight on the spot. I can imagine others have a much higher tongue weight as I am single and pack very light in comparison to most. I do have two 15 gallon water jugs in the front box that I bought filled and strapped there to increase the tongue weight because at 490 Lbs. (This was the exact weight when I pulled it out of the factory and for the first 500 miles before I put any of my stuff inside of it) I was feeling a bit more feedback from the trailer than I appreciate and I figured the additional weight would change its attitude. It did and having the extra water along is a plus until I hit cold country next week then I may change them out for a couple sand bags. Before JD tells me the front box is only rated for 150 Lbs... I know... Its fine and I will beef it up before my next trip. I will post a couple pics when I get better service or home I think this Weigh Safe hitch may be something others find helpful especially if your in a situation where tongue weight is critical due to your tow vehicle. A quick google of "weighsafehitch" and you will be looking at it. I can attest to the fact that it works well and is much faster then finding and weighing on a CAT scale at a truck stop especially if your experimenting with different weights to find your comfort zone. At any rate Props to Oliver for building a quality product in a time when that is not so common anymore and I was very impressed with their staff and how I was treated by them on my pick up day. They are all working hard to push these units out the door but they are doing it with Grace and I appreciate that a lot and they deserve the credit for it. I have attended three Nascar races in a row now (I did not have the Oliver yet for the first two) and will be dry camping in the infield of Kansas City Speedway this weekend, this will be my first time dry camping and I am sure I will exceed the tanks capacity but they do have service running there to pump and fill so I am REALLY not dry camping but I will give it a go and see how long I can get by.... Trouble is that insta hot water heater works very well and it only takes a handful of showers to top off the grey when the water does not get cold. Oh, and the towel hooks somebody was hating on in their blog? they work perfectly, my towels have not fallen off in over a thousand miles and I doubt they ever will but you DO have to know how to hang the towel properly on this style hook..... thanks Grandma for that lesson years ago! Happy Trails Everyone, From Guthrie Oklahoma... For Now...
- 12 replies
- 18
The equipment arrived rather quickly as described above, It is installed and working and the following are the results to date. Local Provider via Microwave type system; Mbps Download - 22.3 Mbps Upload - 1.91 Latency - 39 ms Star Link: Mbps Download - 152.9 Mbps Upload - 3.00 Latency - 40 Thus far Star Link is the ONLY option for us with these types of internet connection speeds. Now to see how reliable it is with our weather patterns. I personally have yet to experience it as I am sitting in Guthrie Oklahoma in Hull #928 (my pick up date was bumped up two weeks) but I was so happy to hear this report from my office that I decided to update my post here.
Currently on a microwave system, not at all interested in using either of the companies mentioned above. If Starlink can provide anything close to what Annwnn describes in their post I will be very satisfied.
I signed up and paid the deposit months ago, received an email yesterday with a $450.00 Payment due in order for them to send me the system and I could not hit the "take my money" button fast enough. I do not expect anything close to perfection, but where I am located in SW Montana the only thing available is 19-20 MB and that is already spotty so it wont take a lot to improve my situation. I will update as there is something to say, No, I do not know when I will receive the equipment, only that they did take my $450.00 and "its being shipped". This is not an RV system just the standard system. Dan
If you have a recommendation of a Full Service Camp Ground that you have physically stayed at near Nashville, TN. I would appreciate your input/suggestions. I will book a week at the end of OCT so I can enjoy Nashville while also putting the RV through its paces near the factory after I pick it up. I am aware of the new campsite at the factory and David Crockett. I am looking specifically to set up closer to Nashville. I see there are several campgrounds available just figured I would see what first hand info this forum has on the subject. Thanks Dan
It’s official! Just picked up Hull 888 today!
fairmontrvpark replied to Steve and Mary's topic in Introduce Yourself
Congratulations and I agree that is a cool hull #. I pick up #928 the end of next month, heading south early to attend Talladega and Charlotte Races beforehand. Best of Luck with your new Rig! Happy Trails. Dan -
Satellite TV and Radio Reception
fairmontrvpark replied to Trainman's topic in Mechanical & Technical Tips
I see you do not have a service at your residence so this may not help but I use Dish and can add my RV to my existing account for $5.00 a month. This requires a dish compatible portable Satellite of course so there is that initial investment but once its all set up I can view anything on the road I would normally watch from my home as long as I have all the necessary signals available to my Trailer. I am told other services offer similar programs but am not familiar with any of them. btw thanks for the reminder I pick up Hull # 928 soon and I had forgotten all about getting this set up. Dan -
Well said! And I strongly urge anyone asking the question "how much can I tow?" to read Dave's statement above however many times it takes to fully understand what he is saying. I see the word "overkill" used a lot in this and other forums. In my opinion when it comes to breaking ability, weight of tow vehicle VS. weight of trailer and the amount of cushion or reserve left in the tow vehicles overall abilities that there is no such thing as "overkill" properly defined this would be "safer", "more reliable", "less stressful" and "much more enjoyable". I own a Ram One Ton and have towed 5th wheels, Gooseneck Equipment Trailers and Dump Trailers that are at the maximum of what my truck is capable of in all respects for decades..... In all of those situations myself and everyone around me in traffic were at a greater risk because of the fact my Rig was traveling at its maximum capacity... while capable and rated for it the fact remains its literally on the edge of disaster and I was responsible to keep it on the safe side of that edge every second. I do not consider this type of travel a vacation by any definition of the word. My reason for purchasing an Oliver is so that I can hook it up behind my One Ton and enjoy my drive more than I would with a 40' long 30,000lb 5th Wheel behind me so I caution those of you that are considering towing your Oliver behind any Rig that would be at its Maximum all the while you are in motion/driving for all of those same reasons. The physics are the exact same despite the gross weight being much different in the event of a sudden need to break or high wind or ice or another bad driver an Elk/Moose/Deer/Dog your still at a much larger risk of experiencing a catastrophic event that you could otherwise avoid with a larger tow vehicle that provides another type of "insurance" you cannot purchase from an insurance agent..... the ability to break, swerve and hopefully avoid a wreck in most cases. Good Luck to you all and please know we are not giving this advice because we want you to be just like us it is because we want the roads to be safe for you and for us and our loved ones and the larger your tow rig the safer we all are no doubt about it. Don't fall for the overkill hype!! Dan
Will this valve open at all with the original door intact and closed? given this is the Grey Water tank full open would not be necessary to let it drain.
- 17 replies
- modifications
- drain
(and 1 more)
Tagged with:
