1 hour ago, MAX Burner said:
We're north of 35k miles with zero issues - if we make it to 75k we might be good.  The spread sheet showed very few failures in the higher mileage range.  The engine/drivetrain warranty is 100k, it would be nice to get a new motor at about 99k!  HA!
I like how you think!!!!!!! 👍
Roger that.  I'm thinking the exact thing with the Ford EcoBoost Phasers.
Toyota has not been replacing engines - they have been replacing short blocks only.  That requires the service techs at dealers to rebuild the engine using a lot of the “used” components - heads, etc.  Some owners are now on their third engines.  Others have gone the lemon law route, which is what I would do since I wouldn’t trust a dealer tech to have the skills and equipment to rebuild an engine vs. full replacement. Certainly they don’t have the clean room that might exist at the manufacturing facility.
Hard to accept the “debris” excuse, as I believe the LX engines might be made in Japan, versus the Tundra and Sequoia engines being made domestically - unless exact same processes are being used in both engine plants. Anyone heard differently?
This is going to be costly, both in money and in reputation, for Toyota.  I’m glad I didn’t make the leap to the new generation Tundra, Sequoia or LX.
2020 Elite II Hull #628 "Pearl" - Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt
TV - 2011 Toyota Tundra Crew Max Platinum 5.7 V8 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
I have a hard time believing the whole debris excuse myself. If that was truly the cause I would think they'd be replacing whole engines and not just short blocks since some "debris" would likely find it's way up to the cam bearings too.
This is what is required to replace the engine on a Tundra.  I sure would not want this done to my brand new truck.
  • Sad 3
I wonder how this recall will impact the fair market resale or trade in value of repaired/recalled trucks? Who would purchase a previously recalled used truck? Personally I would pass. The recall history and engine replacement or rebuild will be a permanent VIN record with Toyota.
Toyota has a massive undertaking is an understatement not only in addressing this the recall, but from a PR and future buyers trust point of view. I have previously owned (3) Tundras and was very happy with all three trucks. It’s sad that the Toyota brand is taking such a hit.
My hopes are Toyota steps up and does the right thing, it would certainly be in their best interest.
Edited by Patriot
@rideandfly
Bill,
I noticed you updated your signature, well done sir!
Bill & Debbie / 2015 LE2 #75 / 2024 F-150 5.0L / North Carolina
Welcome to the Ford Family, and congratulations to you and Debbie on your new TV.
Edited by Patriot
Oh my...  If their "Roger Up" was not factual, then their creditability is also on the line.  That PR debacle cost wise will outweigh financially the engine problem cost.  It now appears that the Short Block answer simply is not going far enough.
Sadly the Ford process was, and continues to be mismanaged from a PR and future customer relations perspective.  The right thing to do in their case was to warrant their engines with the defective design cam phasers with no mileage or time limit.  Not doing so has so many of us angry that I suspect a Class Action law suit will happen.  More bad PR for Ford when it happens.
Ditto for the Ford cam phaser issue.
Headed to the local Toyota dealership later this AM for scheduled oil change - will have a followup report on what their Engine Recall position is thereafter.  I'm getting the old oil analyzed nonetheless.
  • (SOLD) 2022 TUNDRA
So... just returned from engine oil change, rear diff oil change, brake inspection, and (drum roll, please...) engine recall exam.
Toyota's position (at the local dealership, that is) is that the engine recall last week was a preliminary "notification" of an impending engine recall after they determine what the scope of the recall will be, this includes service tech training as needed, parts, logistics, recall procedures (for the fix), etc.
I ordered an engine oil analysis from a third party vendor as part of my service ticket this morning.  Should take a few weeks for the results.  Wish I could report more.
...FYI
Edited by MAX Burner
Man oh man….. We’ve had two tundras.. a 2011 and currently a 2016. Add Debs 20 some odd years of Tacomas and it’s safe to say we are Toyota fans. Our 2016 has 188k miles currently, the 2011 had 125k when we sold it . All good, issue free miles. We started shopping for a new Tundra a couple weeks ago, figuring it was time, and figuring it would be a no brainer… just get a new one…why drive anything else..
We took one out for a test drive, a Limited Hybrid….. and didn’t like it.. We couldn't believe it…
A couple days later, we stopped by a Ford dealer and took an F150 XLT Hybrid for a spin, figuring we better do our due diligence and much to our surprise, we liked it a lot.
I haven’t spent much time on the Oliver Forum for months now, and just happened to check in this evening…. And the first thread I checked out was this one…and I’m glad I did…
I think..
Now I’m wondering what other stuff I’ve been missing  around here.. 🙂
  • 3 weeks later...
Go to Youtube.com and listen to what "The Car Care Nut" has to say about the 3.4 twin turbo engine issues its. This guys know his stuff.  I have an older Tundra 2000 has over 250K on it and runs like new except for the rattles after all these years of off road. Old Tundra just doesn't have the beans to pull my Elite 1 up hills like I want so I have a GX550 coming.  Not affraid of the 3.4 twin turbo and it puts out decent power. All this new high tech without enough research and testing is what's causing all these issues now day. Manufactures need to test these new gagets more before releasing it to the public and using them as ginypigs.
The GX550 is a beautiful vehicle.  I would be hesitant to buy one right now as it's the same V35A engine (although slightly de-tuned) as the ones listed in the recall.  2024 Tundras aren't being recalled (yet), even though there are reports of engine failures in them as well. I'm sure there will be a fix, but I would wait until that fix is implemented at the factory.  Really don't want a service tech at the dealer pulling and rebuilding a very complex twin-turbo V6.  But maybe that's just me.
I'm a huge Toyota/Lexus fan and a former Boeing employee.  Both companies that I have (had) tremendous respect for have really let a lot of people down...
  • 4 weeks later...
Looks like Toyota is stepping up to the plate. A massive undertaking no doubt.
https://www.motor1.com/news/727930/toyta-replace-100k-engines-tundra-lexus/
Edited by Patriot
Had no doubt that Toyota would step up and do the right thing. Had little doubt that there was any other way to solve this issue, either...
For anyone who owns one, I hope you choose the dealership to perform this swap wisely.
And it's possible you may be eligible for a Lemon Law buyback.  Certainly an avenue I would consider versus having an engine replaced on a nearly new vehicle. Or try to negotiate a buyback without resorting to the Lemon Law process.  Could be better situation for Toyota as well.
I wonder when the hybrid models will be included?  Same engine, but less of a safety implication since loss of the ICE is somewhat mitigated by the electric motor.
Edited by katanapilot
I read somewhere that they use a different part number engine block and it's not included in the recall.
  • 1 month later...
This 3.4lt engine design has been out since 2017 and just recently been turbo'd. Toyota already found the issue and are replacing complete engines under warranty.  I've owned Toyota's for over 25 years and are good quality vehicle. I've owned both Ford's and GM's and had the least issues with Toyota's and that why I have on order a GX550 Overtrail coming. Same 3.4lt turbo as the Tundra's.  Midsize SUV's are now only 4 or 6 cylingers. Like the torque specs of the 3.4lt  I do understand that even though the 3.4 might have more torque output then earlier V8's with less torque, The V8's can deliver their torque for a longer period time without overstressing it's engine. Would love to have a GX550 with a V8 but, it just ain't gonna happen.  It's really too bad that U.S. vehicles can't be much better then they are. Would like American made. This is my old Tundra I have to give up since it's doesn't have the beans to pull the hills here around Washington state. ( over the pass )2000Tundra.thumb.jpg.508fd6c9f2f006f314cb59a235cf1460.jpg2000Tundra1.thumb.jpg.47158b1faa597c0eb134dcffedb700df.jpg
Edited by Buddhabelly
Hiroshi
2023 Oliver Elite #1299
2024 Lexus GX550 Overtrail
  • 8 months later...
  • Sad 1
12 hours ago, CRM said:
And I think we'll see further engine recalls in the not-to-distant future. Low mileage engines are still blowing in trucks outside the current recall dates.
Agreed.  Even the hybrids (which were excluded from the current recall) are failing.  Same engine, so it's not really a surprise.  Really disappointing, as I was hoping this would be my next truck.  Fortunately, the 5.7 V8 is hard to kill.
I had high hopes myself. I've owned nothing but Toyota's for more than 35 years and just when I'm ready to retire and travel the country they come out with this dud.
I'm sure they'll get it straightened out eventually, but it's going to have a few years of no engine issues under it's belt before I'll feel comfortable buying one.
  • 5 months later...
11 hours ago, CRM said:
Recall on the 3.5 V6 twin turbo has been expanded to another 127k vehicles. If you own one, it's probably a good idea to go to Toyota's recall page to see if yours is affected.
127,000 Toyota, Lexus Vehicles Recalled for Engine Debris
Toyota Recall lookup
Still no Hybrid models (same engine and plenty of failures) and surprisingly didn't see the Sequoia listed in the latest recall.
I'm going to call BS on the "manufacturing debris" in the engine 3+ years after the first reports.  This looks much more like a design failure that they haven't yet figured out.
I see that RAM is bringing back the V8.  Wonder if Toyota will do the same.  The UR series engines are known for their reliability.
