Broken leaf spring
We have a broken leaf spring on our 2019 LEII on Gunflint Trail in Minnesota (not at all a convenient place for this to happen.) From what I’ve read the OEM is a 1750# 4-leaf spring…is it a Dexter? Does anyone happen to have a part number? I now know from experience and searching for info here it would’ve been a good idea to have a spare on hand.
ALAZARFLILIAKSKYLAMNMSMONENMOKTNTXUTWI66
Thread here: https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://olivertraveltrailers.com/forums/topic/9996-made-in-usa-leaf-springs/&ved=2ahUKEwj7uaXMrKSHAxWUElkFHRtoA9wQFnoECCsQAQ&usg=AOvVaw2TuWEqPQCoyqb1wVMIHpcR
One of the posts lists his replacement specs as:
"Made in USA with USA sourced 5160 spring steel
-Bronze eye bushings vs. plastic
-2,000lb rating/ea vs. 1,750 (will not change gvwr as axles/bearings remain determining factor)
-5 leaves vs, 4
-second leaf extends underneath eye on each end (protecting common break area)
-steel, bolted spring keepers (one each end) vs a single, sheet metal band
-width = 1.75"
-drop = 3”
-length (eye-to-eye) = 25.25”
The company I sourced them from is ALCAN."
ALAZCACOCTDEFLGAIDILINIAKYLAMEMDMAMIMNMSMOMTNENVNHNJNMNYNCNDOHOKORPASCSDTNTXUTVTVAWAWVWIWYmed.jpg.5fd5f3b4c75ee46264e6fb85b8f6056d.jpg
Here is the replacement spring info Oliver Service sent me for my 2021 E2.  They can be found on Amazon in pairs for $68. Note that the springs on Amazon appear to have nylon bushings rather than bronze, but they would serve to get you back on the road and home where you can figure out your final solution
Please open a service ticket with Oliver so they are aware of the issue and can advise for your exact hull#
Edited by Mountainman198
2021 Elite II, Hull# 898
When installing bronze bushings in Ollie's spring eye, I coat the outside of the bushing and inside of the spring eye with castor oil to help the soft bronze slide into the spring eye easier, attempting to prevent damage to the soft bronze bushing.
The last bronze bushings I installed used a piece of threaded rod from a local Lowes with flat washers and nuts.
Edited by rideandfly
@jdmmtx ; If you're still in need of replacement leaf springs, you're welcome to have my OEM 4-leaf springs - no longer needed because we replaced them last April using the Alcan 5-leaf spring packs that @Steph and Dud B mentioned above.
Shoot me a PM with a shipping address and cover the shipping costs...  You can have 1 or all 4 of the springs.  They are in serviceable condition.
Cheers,
Art
  • 2022 TUNDRA
Hey guys.  I tried trudging through some of the 8 pages on the Alcan leaf spring thread listed above.  Wow, that was a long thread.  But I did not see mention of an actual part number to reference for the Alcan.  Did I miss it or do they go off the basic specs of the springs that @Geronimo John mentioned in his attached document (very handy, thank you).
EDIT:  Ah I see, it's a super small business, so likely no specific part number, and just give them the specs.
Thanks.
Chris
Edited by Wayfinder
Chris
2016 Legacy Elite II  o--o  Hull #110 o--o  Wayfinder  o--o  Twin Bed  o--o  2020 RAM 1500 Limited 5.7L
Augusta, Georgia
Since my #110 cannot get new axles due to frame hanger welds, I might beaf up the springs.
Chris
Augusta, Georgia
Thanks.
Chris
There is no part number.
When you call, ask for Lew or Mike and tell them you have a Oliver Elite II(this way they can make sure the centering pin is set up for our spring under axle configuration).
According to Alcan, their springs are rated at 2,750 lb/ea. While most of us who have installed them notice very little incremental stiffness, you should be aware of this going into the purchase.
If you order your new ubolts and nuts from them, make sure you know your axle diameter when you call so they send the correct ubolt size.
I live in Duluth if you need a hand with anything! Happy to run up with some tools, beer, and/or moral support!
  • Love 4
2021 LE II - Hull 922 - "Ollie Be Back"
2013 Silverado 2500HD Duramax
Hugo & Penny
Bob & Cash (the pups)
