4 minutes ago, CRM said:
So, if I'm understanding this correctly, this thermostat shuts down the fan and compressor together by sending a "shutdown" signal to the unit by mimicking off button on the unit's remote?
The  Cielo is independent of the remote and actually turns OFF the power to the Atmos 1° below the low temp setting then turns ON the power to the Atmos 1° above the high setting. There is zero power draw during the shutdown period. When using the thermostat, the remote must be turned OFF and the phone app used to control. The remote can be used for normal operation of the unit, but for enhanced features like Comfy Mode the app is used. Selecting the proper temp setpoint will determine if the fan or compressor runs longer at shutdown. I will address that another time. There is also a Comfy Max Mode, which mimics a home HVAC set for heat/cool, but I think the fan is continuous. Did this answer your question?
That seems like a perfect solution to the "always on" fan issue! Shouldn't this thermostat work for other units that have a remote control to control them?
As I understand it, the Cielo line of products is primarily marketed for mini splint air conditioners, but obviously found to be comparable with other types. SDG that sells and installs the Drieha Atmos 4.4 uses these IR Cielo thermostats in some of the Class B RVs they mostly deal with. I haven’t read of any other brands of rooftop units being controlled by a Cielo, but guess it may be possible. I agree, a perfect solution!
This is from the description on their Amazon store-
"Product Usage Instructions: Breez Max connects to a 2.4 GHz Wi-Fi network. It is compatible with any mini-split, window or portable unit that has an IR remote control. If your device doesn't work out of the box, please contact Cielo Customer Support to make it compatible."
Looks like any unit that works with an IR remote has a good chance of working with this thermostat. Might have to start a new thread at some point to track what other AC units it actually does work with? Thanks again for this.
14 hours ago, Ronbrink said:
In said mode, once custom temperature or humidity comfort ranges are dialed in, the Atmos will turn on power when the high setting is exceeded and subsequently turn off power when the lower setting is exceeded. This is ‘HUGE
I didn’t think I needed this since already having the remote and other app control but I believe I am going to try it. Being able to more clearly refine the control is what we all want.  Thx for sharing the product and evaluation.
… now, where to place it? USB power makes things interesting.
Edited by rideadeuce
The Cielo has to be positioned for line-of-sight with the Atmos controls in the air distribution panel. And yes, an AC outlet or USB port is needed in close proximity; however it is equipped for hardwiring. When learning how to use the Cielo, I sat at the dinette and plugged into an AC outlet via the supplied 5V adapter; the supplied base stand for flat surface staging was also used. Being a wall-mount is best securement in a rolling earthquake, I first tried it on the forward bulkhead to the upper left of the wet bath door, but didn’t like the cord dangling down the wall and it seemed a bit less responsive due to the distance. I then placed it between the two curbside upper cabinets near the under cabinet USB ports above the cooktop, but the 90° orientation didn’t work as well and there would be concerns of rising heat if cooking. Finally I placed it as shown in the pic, whereby the cord runs in and out of the galley cabinet and plugs into said USB port. I used Velcro for the mount, and may eventually hardwire the Cielo through that upper cabinet and tap into the wiring within the access screw port for a cleaner installation. As positioned, the Cielo is in clear view from bed, and I like that the backlight is dimmable or can be turned off.
Edited by Ronbrink
Good idea! It also claims ‘The smart air conditioner controller is compatible with over 20,000 models of mini-splits, window, or portable units’. Maybe there will be some owners of SOB units willing to try the Cielo Breez Max and report their findings.
It would be very interesting to see if it works with the Houghton units. Hopefully someone with one will see your solution and give it a shot.
And the Truma for that matter!
EDIT: Dometic Penguin ll, as well!
Edited by Ronbrink
The ONLY good thing re the Dometic P2 is it does turn off when fan set to AUTO and temp is reached!
The problem starts every time it starts back up! 😆 I know this is a very individualized thing but I actually like the unit and/or fan only running continuously, especially if it is quiet. It was the loud start and stops of the DP2 that woke me up during the night, etc. I am very hot natured and live in the humid SE. What Ron has figured out is better than the other options of timing out, manually shutting off the unit, or using the AUTO mode with no ability to refine temp settings. Hope everyone has a great weekend!
I’m sharing my experience in hopes of helping other Oliver owners resolve the inherent humidity issue, regardless of the brand of a/c unit they may have. If found to work with a particular unit, perhaps others can share their experiences.
The following has been found beneficial in ‘Setpoint’ selection in Comfy Mode, but may be applicable with use of Comfy Max Mode, as well; TBD. It is important to know that a setpoint one or two degrees below the upper range of temperature selected will have the fan run more than the compressor prior to power shutdown; whereas a setpoint of three or four degrees will have the fan and compressor turn off in sync, and the outside blower fan runs a half minute or so before total shutdown of the unit. Here’s a screenshot of  the Custom Settings for my ‘Day’ Comfy temperature range.
Although I have the Vertical Swing set to Auto, there are nine other positions to choose. Once the Atmos is running in a Comfy Mode, the Swing can be temporarily changed. I find this useful when sitting or lying in bed (head at rear) and don’t want the cold air oscillating downward onto me. Pos 1 can be selected to set the Swing to blow straight out. The Fan speed can also be changed, as well. These interim changes will revert back to the original settings next use.
Edited by Ronbrink
Here’s some observations in using the Cielo Breez Max phone app, the phone’s Bluetooth must be turned on to pair the device and Wi-Fi is initially required to operate the A/C via the app. Once the A/C is powered up and set to run at a desired mode of operation and Wi-Fi is discontinued, the A\C will continue to run as set, but changes cannot be made. However, to make changes or when it comes time to turn off the A/C Wi-Fi is once again needed. I know this based on my experience a couple weeks ago, wherein I started the A/C using the phone app while at my house in order to run the Atmos via the inverter while in transit to the COW Barn for storage. Once stowed and ready to leave, I was unable to turn off the Atmos and found it necessary to use my wife’s cell hotspot in order to do so. Fast forward to yesterday, when I activated a recently acquired Starlink Mini and went back to the COW Barn to check on the Oliver and perform some tests. To no surprise, the SLM worked flawlessly, as well as the Cielo/Almos. It wasn’t a terribly hot day for Texas due to pending inclement weather, outside temp was 88°/relative humidity 77%; the Oliver registered 89°/72%. Yep, the dehumidifier was shutdown with a full reservoir and thus, the high humidity condition within! Not to worry, the SLM/Cielo phone app started and ran the Atmos for 45 minutes, at which time it powered off on Comfy Mode at the set temp of 75°/humidity was 45%. In approximately 20 minutes, the Atmos turned back on when the temp rose to 77°/humidity was 47%. It then ran 17 minutes before total shutdown again, humidity was 45%; no humidity spike whatsoever, YAHOO! Loving the Cielo Breez Max and the SLM is proving to be a worthy addition as well, as many of you already know. Hopefully other owners will try out the Cielo Breez Max on their respective A/Cs, and report on subsequent findings and experiences.
Edited by Ronbrink
On 4/24/2025 at 3:09 PM, jd1923 said:
I'm seeing $1200 with shipping.
https://www.amazon.com/TOSOT-Conditioner-Non-Ducted-Rooftop-High-Efficiency/dp/B0CDWR5RP9/
Still less than $1500 total on the Atmos (with $150 shipping, no SoftStart on either).
https://www.sdgelkhart.com/product-page/atmos-4-4
I witnessed @Ronbrink's installed Atmos and it was excellent. Still not sure the Tosot is of the same quality. Right now, maybe $300 more on the Atmos to be sure with reputable US rep in SDG.
I would love the Greenland inverter A/C that @CRM is also interested in. If I was to learn it is quieter than some reviews show. And I too am waiting another year.
FYI, I recently learned that SDG is now installing the Tosot via the following quote by a member of another forum: “I spoke to Kevin about the switch from Atmos to the Tosot and he said it was because of the tariffs that the Atmos supplier imposed and he could buy the Tosot direct from the manufacturer for less. The units are identical and both produced by Gree”. This product switch was confirmed when visiting SDG’s website.
There is a question that I do not believe has been verified. Tosot a year ago was using R-134a refrigerant. Are they now using the more efficient R-32? Anybody getting one should know this ahead of ordering. Ron can confirm, but I'm pretty sure his and other Atmos use R-32 refrigerant.
Here is a screen shot of the Tosot specs from SDG’s website:
And yes, the Atmos 4.4 has the R32 refrigerant.
NOTE: The above shows a 15,500 BTU cooling capacity for the Tosot, which is higher than the published 15,000 rating for the Atmos. Makes me wonder!
Edited by Ronbrink
We must be skeptical of specs on websites. Check the product label. Likely the R32 is correct and the 15.5K BTU is incorrect, 15K instead.
i had ordered Epoch Essentials 460Ah batteries and if the website was accurate 2 would have fit in the Oliver battery bay with the tray removed. The website had width and height numbers reversed.
Called Epoch and they could not confirm but the distributor did and they changed my order for two 300Ah which fit in the tray.
Often bad data on websites. So much on auto parts websites for sure!
Edited by jd1923
19 hours ago, mountainoliver said:
Here’s a screen shot directly from the Tosot website:
I remain skeptical that the Tosot and Atmos are exactly the same units. I have seen CFM ratings of 400-450 for the Atmos, and as you and JD witnessed my hair was blowing while standing in front of the bath mirrored door. The Air Flow shown for the Tosot is more comparable to that of the former DPll. There are other spec discrepancies, as well.
Kevin should know as soon as SDG has installed a few Tosot units.
Indeed, we heard a lot at the beginning with his Atmos installs. I will continue to monitor other forums and report on any testimony’s or findings.
My feeling is Atmos was designed in Germany and the company made the mistake of manufacturing their product in China, where the copied the design and rebadged Knock-offs as Tosot and other names we’ve seen.
This happened to ALL the technology patents that Motorola had, witnessed while I was there during the 90s. One of the reasons Motorola finally closed in 2011 (Motorola trademark purchased by the Chinese computer company Lenovo)!
Question remains is are they quality knock-offs? SDG must be getting better wholesale pricing on the Tosot brand. Hopefully they made the decision knowing that it is at least comparable quality. If not, they will have future service and warranty issues.
On 3/16/2025 at 7:01 AM, jd1923 said:
They cycle separately but the interior fan is always running when powered on, compressor fan only running when the compressor is running (though likely runs for a period after for cooling).
That's a deal killer for the vast majority of the USA market for the supply air fan to run continuously.  It just evaporates the moisture entrained in the  coil back into the cabin.  Same as the unmodified Houghton's.
If the fan you are referring to is the supply air fan that is a great set up.  Hot and humid locations:  supply air turns off with the compressor.  Hot and Dry and it can run to retain moisture and still not be humid in the trailer.
Edited by Geronimo John
