St8ofbeing Posted October 23, 2024 Posted October 23, 2024 This is the 2nd year in a row we have had CO alarm from the alarm under the dinette in the first few days following winterization. Last year I called Oliver and they sent out a new RVCOLP-2 unit and I replaced it. No more issue till today after we winterized on Sunday. My thoughts for troubleshooting are to order a handheld CO detector from amazon and put the CO unit back in. Once it alarms test using the handheld. Could this be caused by AntiFreeze smell coming from the toilet? Do we need to air out the trailer post winterization? Any other thoughts? Is there a better CO detector I can buy and install? Thanks in advance. 1
St8ofbeing Posted October 23, 2024 Author Posted October 23, 2024 BTW we have a 2023 Oliver Elite II Hull #1340
Moderators topgun2 Posted October 23, 2024 Moderators Posted October 23, 2024 The first thing I would do (if I were you) is to actually use the "search" function at the top of this page by typing in "carbon monoxide". With the 119 results you will get - about 5 down the page is a detector that John Davies put in and it just may be the solution for you. However, note that these detectors do not seem to be the most reliable of devices - read a bunch of the other posts that the search gives you. Good luck! Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted October 23, 2024 Posted October 23, 2024 (edited) @St8ofbeing I will save you a search on the forum. Last year we had to replace our RV Safe LP detector while on a 42 day 6000 mile trip. I purchased the detector at Humphrey RV, in Montrose, CO and it was a fast simple install. We got home and winterized and the new detector I had just installed alarmed and would not reset. So I called RV Safe and explained the issue and long story short they sent me a replacement. The gal was really nice and also sent a prepaid return envelope for the faulty detector. The gal I spoke at RV Safe said well RV anti freeze should not set the alarm off but anything is possible. We had no LP turned on, no leaks and the alarm only sounded after winterizing. I admit the RV AF order was quite strong inside our Oliver. I just don’t understand why the antifreeze odor would set it off. Fast forward - I just winterized last week after an 48 day, 7400 mile trip out west and the LP alarm went off and would not reset after winterizing. So I will be calling RV Safe again explaining what happened and requesting a replacement. If you contact RV safe make sure you specify a white trim replacement. They also come in black. I would caution against adding an on off switch to your LP detector. I opted not to as it could be deadly if one forgets to turn it on. https://rvsafealarm.com/contact/ Edit and update - I just spoke with Andrea she is the Customer Service Rep and is sending me a replacement. I will return the existing detector. Patriot🇺🇸 Edited October 23, 2024 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Rolind Posted October 23, 2024 Posted October 23, 2024 In our experience ethanol fumes whether spilled near the sensor or dissipated by respiration after a few drinks is enough to trigger the CO alarm if the trailer is closed up. I’m sure the ethanol in the antifreeze would also be enough to trigger the alarm. 1 2 Robert and Cheryl, Louisville, KY, Legacy Elite II 2023 Hull #1390 Oliphino, TV F250 Tremor
ADKCamper Posted October 23, 2024 Posted October 23, 2024 (edited) Seems to be a recurring theme... same thing happened to our unit yesterday. Just replaced the original Atwood detector with an RV-Safe detector in April due to the Atwood repeatedly false-alarming. Worked fine all season. Shortly after winterization (maybe an hour?) it went into (CO) alarm and would not stop. Tried 'reset' twice and it began to alarm again shortly after the reset each time. Propane turned off for 2 weeks, no appliances running, RV anti-freeze in the toilet, traps and water lines. Fortunately we are done camping for this season, so I pulled the fuse and visibly tagged the detector as "OFF". If we had had to winterize at elevation this month while still camping, this would be a bigger issue. Sounds like a design flaw??? Edited October 23, 2024 by ADKCamper 2 Tom & Holly 2018 Oliver Legacy Elite #409 - 320W rooftop solar, 300Ah Epoch LiFePO4, Victron BMV-712 & Smart Solar MPPT 100/30, Progressive Dynamics PD4060CVS 60Amp Lithium-capable Converter, Xantrex PROwatt SW 2000 inverter, Bulldog HD1213-0656 Shocks, Falken Wildpeak H/T02 235/65R16C 121/119R; Tow Vehicle: 2026 Silverado 2500, 6.6L Gas, 4x4, Dbl Cab, Std Bed.
Patriot Posted October 23, 2024 Posted October 23, 2024 (edited) On 10/23/2024 at 2:38 PM, ADKCamper said: Seems to be a recurring theme... same thing happened to our unit yesterday. Just replaced the original Atwood detector with an RV-Safe detector in April due to the Atwood repeatedly false-alarming. Worked fine all season. Shortly after winterization (maybe an hour?) it went into (CO) alarm and would not stop. Tried 'reset' twice and it began to alarm again shortly after the reset each time. Propane turned off for 2 weeks, no appliances running, RV anti-freeze in the toilet, traps and water lines. Fortunately we are done camping for this season, so I pulled the fuse and visibly tagged the detector as "OFF". If we had had to winterize at elevation this month while still camping, this would be a bigger issue. Sounds like a design flaw??? Yes, a design flaw for sure. The rep that I spoke with said here in California we don’t winterize our campers. 🙄 I suggested that they place a cup of RV anti freeze in a cardboard box with the detector inside wait for it to alarm and consider recalibration. She seemed to think that was a good idea. We’ll see if that happens. Edited October 29, 2024 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted October 23, 2024 Posted October 23, 2024 1 hour ago, Patriot said: Yes, a design flaw for sure. Maybe. We’d have to be chemists to be sure. I don’t use the pink stuff, but if it’s ethanol based, I would think it could react with brass or other plumbing components to produce the simple but deadly compound CO. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted October 24, 2024 Posted October 24, 2024 (edited) 2 hours ago, jd1923 said: Maybe. We’d have to be chemists to be sure. I don’t use the pink stuff, but if it’s ethanol based, I would think it could react with brass or other plumbing components to produce the simple but deadly compound CO. No chemist here ha! The customer service rep said their company would replicate the RV anti freeze odor and determine if that’s causing the detector to alarm. She said they have had several calls after people have winterized and immediately there after their CO/LP alarm sounded. I guess we will wait and see what the experts come up with. This is the second time around for me. It was interesting to hear her say they have had multiple calls this week on this exact same issue. Edited October 24, 2024 by Patriot 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
St8ofbeing Posted October 24, 2024 Author Posted October 24, 2024 I really appreciate all the replies. Very helpful. Last year i did not link the winterization to the alarm. But two years in a row seems like a trend. 1
John Dorrer Posted October 24, 2024 Posted October 24, 2024 Not happened to us, so now that I have said that wait until 11/1 when I winterize and watch it happen. RV Anti-freeze is non-toxic, and you would think it wouldn't cause the CO sector to go off, but apparently it has. Keep us posted. Very strange. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Zodd Posted October 24, 2024 Posted October 24, 2024 I used this RecPro RV Antifreeze -50°F Protection Non-Toxic which is Ethonal-free, assuming it is the Ehtonal that triggers this. So far, knock on wood, no alarming for me. And I have had it alarm a few times with three of us sleeping. It still has propylene glycol in it. It seems ethylene glycol, which some types of antifreeze use, can produce carbon monoxide when it decomposes at high temperatures. 1 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
Moderators topgun2 Posted October 24, 2024 Moderators Posted October 24, 2024 That stuff sure ain't cheap! 🤑 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted October 24, 2024 Posted October 24, 2024 (edited) 17 minutes ago, topgun2 said: That stuff sure ain't cheap! 🤑 This is what I use and I usually get it on sale. It has strong reviews and has worked well for us with the exception of setting off our LP/CO alarm. https://www.lowes.com/pd/SPLASH-Non-Toxic-50-50-Antifreeze-Cooling-Fluid-1-Gallon-For-RVs-Boats-Pools-Ethyl-Alcohol-50F-Burst-Protection/1001303072?store=612&cm_mmc=shp-_-c-_-prd-_-hdw-_-ggl-_-CRP_SHP_LIA_HDW_Online_C-D-_-1001303072-_-local-_-0-_-0&gad_source=1&gbraid=0AAAAAD2B2W9hRI4Nvwfs2K7-hTSUpLL-r&gclid=Cj0KCQjw4Oe4BhCcARIsADQ0csloYKcIQ04k3NO6UEfmyjY02U09-6gIeVxeIl5hbVkoZO4zZ16R5bkaApkAEALw_wcB&gclsrc=aw.ds Edited October 24, 2024 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted October 25, 2024 Posted October 25, 2024 4 hours ago, Zodd said: I used this RecPro RV Antifreeze -50°F Protection Non-Toxic which is Ethonal-free, assuming it is the Ehtonal that triggers this. This may be the answer! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
John Dorrer Posted November 1, 2024 Posted November 1, 2024 (edited) Well, I winterized this morning, and then the CO Detector went off 3 times. Most of the RV antifreeze I used was from last year and I opened a new one that was different, bought from same Ace Hardware. I left a window open. Very strange. First 2 times no issues. Edited November 1, 2024 by John Dorrer Typo 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
John Dorrer Posted November 2, 2024 Posted November 2, 2024 This what we have been using and never had the alarm go off until this year. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Moderators SeaDawg Posted November 3, 2024 Moderators Posted November 3, 2024 Some cheaper rv antifreeze is , from what I've been told, reclaimed/recycled de-icing glycol. That said, we've not had alarms go off worh the "cheap" stuff from Walmart, etc. Those of you have had the issue, did you also blow out the piping before adding rv antifreeze? 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
jd1923 Posted November 3, 2024 Posted November 3, 2024 15 hours ago, SeaDawg said: That said, we've not had alarms go off worh the "cheap" stuff from Walmart A little aside on this post. Walmart house brand Super Tech is pretty good stuff. I started using this in all our gas vehicles. A gallon for $20 full synthetic rated for 20K miles! Although I would never go over 10K miles on a change. We have 3 trucks, 2 cars, and a Goldwing so none of them get high miles. I'm comfortable running this for 1-2 years between changes. Super Tech Advanced Full Synthetic Motor Oil SAE 5W-30, 5 Quarts - Walmart.com Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
ADKCamper Posted November 3, 2024 Posted November 3, 2024 (edited) 17 hours ago, SeaDawg said: Some cheaper rv antifreeze is , from what I've been told, reclaimed/recycled de-icing glycol. That said, we've not had alarms go off worh the "cheap" stuff from Walmart, etc. Those of you have had the issue, did you also blow out the piping before adding rv antifreeze? Yes, blew out all lines, inlets and outlets with low pressure air prior to introducing RV antifreeze. The difference this year was I left some antifreeze in the toilet bowl. Usually I drain the antifreeze from the bowl into the black tank and leave toilet valve lubricant in the bottom of the bowl. There was likely more "antifreeze fumes" than usual in the air with what was left in the toilet bowl. Our RV antifreeze this year was also the "Champion" brand from Camping World, as shown above... Edited November 3, 2024 by ADKCamper Tom & Holly 2018 Oliver Legacy Elite #409 - 320W rooftop solar, 300Ah Epoch LiFePO4, Victron BMV-712 & Smart Solar MPPT 100/30, Progressive Dynamics PD4060CVS 60Amp Lithium-capable Converter, Xantrex PROwatt SW 2000 inverter, Bulldog HD1213-0656 Shocks, Falken Wildpeak H/T02 235/65R16C 121/119R; Tow Vehicle: 2026 Silverado 2500, 6.6L Gas, 4x4, Dbl Cab, Std Bed.
Moderators topgun2 Posted November 3, 2024 Moderators Posted November 3, 2024 25 minutes ago, ADKCamper said: The difference this year was I left some antifreeze in the toilet bowl. I always do this but I then take Saran Wrap and cover the top of the toilet bowl so that the antifreeze doesn't evaporate over the winter. Perhaps this also serves to lessen the "fumes". Bill 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John Dorrer Posted November 3, 2024 Posted November 3, 2024 Well, this isn't funny anymore🙃. Winterized 3 days ago, anti-freeze poured in both sink traps, floor drain with back flush closed, and toilet. Left window open 2"-3" and no issues. Rain forecast so I closed the window. We were gone 3 hours and when we returned it was going off. Had to place a small USB fan in front of the detector. Took 5 minutes to get the green light. Going to try the wrap. This sucks. John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Patriot Posted November 3, 2024 Posted November 3, 2024 (edited) On 11/1/2024 at 5:21 PM, John Dorrer said: Well, I winterized this morning, and then the CO Detector went off 3 times. Most of the RV antifreeze I used was from last year and I opened a new one that was different, bought from same Ace Hardware. I left a window open. Very strange. First 2 times no issues. John, I stepped in XPLOR this afternoon and checked on our dehumidifier. While inside I noticed that the strong odor of the antifreeze we used to winterize has greatly diminished. I could still detect a slight odor but nothing like it was. So after inserting ear plugs as the alarm as you know is ear piercing and I decided to reattach the RV Safe LP/CO detector. The green light came on in normal and the detector did not go off. 🤞🏻 Our Ollie is parked in our Hangar in the backyard allows us to actually hear the detector if it alarms. I also took @topgun2 suggestion and covered the porcelain throne with Saran Wrap and I also covered grey water drains with a little painters tape. I will let you know if our alarm goes off again as this is week 3 after winterizing. I think leaving two windows open even with our cover on really helped disparate the antifreeze odor. - David Edited November 3, 2024 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Zodd Posted November 3, 2024 Posted November 3, 2024 On the topic of humidity when winterized in the trailer what all do you target and use? I figured I could do <50 using damprid but using that has hardly had much effect and humidity is staying at about 72% which feels too high. I put a second damprid in thinking maybe it just needs two but no impact. The trailer is covered with vents closed. Maybe I need to open vents? Just figured with it being covered opening vents would not do much and maybe even make it worse living in the inland northwest. Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
