Beth H Posted January 22 Posted January 22 We have been trying to connect the tv so that we could hear it through the sound system to no avail. Checked you tube and owners manual. Seems simple but we cannot make it work. Thoughts?
jd1923 Posted January 23 Posted January 23 (edited) Not sure this should function in the way you desire. If playing a DVD through the Furrion, the HDMI out is connected to the TV for picture and the audio channels of the HDMI are played locally through the Furrion speaker outputs (try this to see if you can make it happen). When the input/source is via the TV, broadcast TV or streaming, the Furrion is likely not in the loop and audio out is pushed through the TV speakers. If your TV has output selections which include the Furrion system, this would work, but your TV likely thinks of the Furrion as an input source and NOT an audio output. On a more advanced TV with a HDMI-ARC circuit (certainly NOT this plain OTT OEM system) you could get this working (requires a high-end TV). Instead get a soundbar and connect to the audio out of your TV (connect by audio cables, HDMI, Bluetooth, or Wi-Fi). Edited January 23 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators topgun2 Posted January 23 Moderators Posted January 23 Try watching THIS Oliver video. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
PlainsTraveler Posted January 27 Posted January 27 in our Oliver, Hull 895, we need to select the Optical Input on the Furrion to listen to the TV sound. 2
Cameron Posted January 28 Posted January 28 I do the same. I just hit the "AUX" button, clicking through the options, until it says "optical". 1 2021 Elite II #841, 2020 GMC Sierra 1500 AT4, 3.0 diesel
jd1923 Posted January 28 Posted January 28 (edited) 11 hours ago, PlainsTraveler said: in our Oliver, Hull 895, we need to select the Optical Input on the Furrion to listen to the TV sound. Thank you and @Cameron too. Our older hull did not have an Optical audio cable installed, HDMI only. Good to know. Edited January 28 by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Boilermaker Chemist Posted January 28 Posted January 28 The owner’s manual for my 2023 says to set the AUX to “ARC”. However, I’ve tried that and a number of other things to no avail. I’ll probably have Oliver service take a look next time I’m there. Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
CRM Posted January 28 Posted January 28 52 minutes ago, Boilermaker Chemist said: The owner’s manual for my 2023 says to set the AUX to “ARC”. However, I’ve tried that and a number of other things to no avail. I’ll probably have Oliver service take a look next time I’m there. Usually only one of the HDMI inputs on a TV are labeled "ARC". You might want to check that the HDMI cable coming from your stereo is plugged into it. 3 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 4.30 axle and tow package.
John Dorrer Posted January 28 Posted January 28 On 1/22/2025 at 6:33 PM, Beth H said: We have been trying to connect the tv so that we could hear it through the sound system to no avail. Checked you tube and owners manual. Seems simple but we cannot make it work. Thoughts? High highly recommend you reach out to Oliver and be able to be in the trailer so they can walk you through the steps. You can then share with Oliver exact steps you have been following and see where the disconnect is😊 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
HappyCamper7424 Posted January 28 Posted January 28 (edited) 4 hours ago, CRM said: Edited January 29 by HappyCamper7424
HappyCamper7424 Posted January 29 Posted January 29 4 hours ago, CRM said: Usually only one of the HDMI inputs on a TV are labeled "ARC". You might want to check that the HDMI cable coming from your stereo is plugged into it. Thanks, I’ll check that out.
Steph and Dud B Posted January 29 Posted January 29 This is how the cables are connected to the Vizio TV in our 2022. TV audio through the Furrion stereo is by selecting the ARC input on the Furrion. We have to turn the Furrion volume up quite a bit to hear the TV audio. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
