Olive2Roam Posted February 11, 2025 Posted February 11, 2025 We are getting ready to head west from the Nashville area in a week or so and so I will be dewinterizing the Ollie for the first time. My question is around managing the fluids as I do so primarily for safety of the neighborhood dogs. (Don’t own one but many in the neighborhood.) RV antifreeze is not supposed to be toxic but I don’t want to take any chances. How/where do you dispose of the fluids resulting from the dewinterizing process? This is the product I used to winterize. 1 https://www.instagram.com/campbells_olive2roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger Â
Moderators topgun2 Posted February 11, 2025 Moderators Posted February 11, 2025 Olive - Check the ingredient list on the anti-freeze you used. It should not include ethylene glycol - mine doesn't. Therefore mine isn't toxic to dogs and I'd suspect that yours isn't either. Bill     How does ethylene glycol affect dogs? Even small amounts of ethylene glycol can cause permanent kidney damage in dogs.  Less than ½ a teaspoon per pound of body weight can be enough to kill a dog.  Dogs can get into antifreeze by drinking from puddles or licking it off their paws.  2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Olive2Roam Posted February 11, 2025 Author Posted February 11, 2025 7 minutes ago, topgun2 said: Olive - Check the ingredient list on the anti-freeze you used. It should not include ethylene glycol - mine doesn't. Therefore mine isn't toxic to dogs and I'd suspect that yours isn't either. Bill  Thanks Bill. Ethylene glycol, no. Propylene glycol, yes. Should be harmless or at least not critically toxic like auto antifreeze. How do you dispose of the waste water when dewinterizing? Drain out onto the ground?   https://www.instagram.com/campbells_olive2roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger Â
Moderators topgun2 Posted February 11, 2025 Moderators Posted February 11, 2025 1 hour ago, Olive2Roam said: How do you dispose of the waste water when dewinterizing? Drain out onto the ground? Short answer - yes, onto the ground. Longer answer - We live in a very wooded area and our general drainage from the roof and driveway is basically collected into two large catch basins which have their outlets well away from the house down in the woods. We have structured the outlets in such a way as to disperse this water over a fairly wide area so as to not cause erosion and/or drainage into a small nearby creek. With the water I used in flushing the fresh water and grey tank in the Spring, any anti-freeze is well diluted by the time it gets to these outlets. Of course, any flushing of the black tank goes directly into the waste water system of the house while the "main dump" of the black tank occurs prior to bringing the trailer home. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Rivernerd Posted February 11, 2025 Posted February 11, 2025 Propylene glycol is used in many products sold for use by humans. One example is hair conditioner. It is not toxic to humans or animals. It is biodegradable. But, it can contaminate groundwater in sufficient quantity, or damage the essential microorganisms in a septic system. So, the environmentally safe practice is to recycle it. 1  Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2026 Ford F350 Crew Cab with 7.3L gas engine   Â
Moderators topgun2 Posted February 11, 2025 Moderators Posted February 11, 2025 1 minute ago, Rivernerd said: So, the environmentally safe practice is to recycle it. Absolutely agree - if you can find a place to recycle it. Around here THAT seems to be a problem.😪 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Olive2Roam Posted February 11, 2025 Author Posted February 11, 2025 1 hour ago, topgun2 said: Short answer - yes, onto the ground. Longer answer - We live in a very wooded area and our general drainage from the roof and driveway is basically collected into two large catch basins which have their outlets well away from the house down in the woods. We have structured the outlets in such a way as to disperse this water over a fairly wide area so as to not cause erosion and/or drainage into a small nearby creek. With the water I used in flushing the fresh water and grey tank in the Spring, any anti-freeze is well diluted by the time it gets to these outlets. Of course, any flushing of the black tank goes directly into the waste water system of the house while the "main dump" of the black tank occurs prior to bringing the trailer home. Bill Thanks, Bill. https://www.instagram.com/campbells_olive2roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger Â
Olive2Roam Posted February 11, 2025 Author Posted February 11, 2025 1 hour ago, Rivernerd said: Propylene glycol is used in many products sold for use by humans. One example is hair conditioner. It is not toxic to humans or animals. It is biodegradable. But, it can contaminate groundwater in sufficient quantity, or damage the essential microorganisms in a septic system. So, the environmentally safe practice is to recycle it. Good info. I appreciate it. https://www.instagram.com/campbells_olive2roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger Â
dewdev Posted February 11, 2025 Posted February 11, 2025 (edited) I wonder if your local mechanic/garage would take it? Our town recycle facility has a 50 gallon barrel for regular antifreeze disposal. Edited February 11, 2025 by dewdev Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine Â
jd1923 Posted February 12, 2025 Posted February 12, 2025 8 hours ago, dewdev said: Our town recycle facility has a 50 gallon barrel for regular antifreeze disposal. Exactly! Having lived in 5 different states in many cities and counties, I would say that a locale that does not have a recycling program today is a rare case. I keep used 5-gal containers in my garage for oils and antifreeze. These must be recycled separately, but it's safe to say that antifreeze is antifreeze wrt recycling. Brake fluid, spent fuels, oil based paints, solvents, etc. are hazardous waste. Our city schedules one month a year and they actually with application will come to our homes to pick up these wastes. The will be by our home this March! (see link) I go to drop off oil and antifreeze every couple of months. Sometimes I bring the Oliver with me while doing so to check the tow weight! 🤣 https://prescott-az.gov/trash-and-recycling/residential-collection/ 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steph and Dud B Posted February 12, 2025 Posted February 12, 2025 The small amount of antifreeze from the fresh water tank and the outside shower goes on the ground outside the garage. The rest ends up in the black and grey tanks and we dump it at the first campground with hookups. Hadn't really thought about collecting it for recycling. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
