Gliddenwoods Posted March 23 Posted March 23 When we depart from the cold north to begin a trip our Oliver is winterized. Upon a warm State the dewinterizing is to be completed. Two problems: 1.The fresh drain is so small it takes well over an hour to drain. Has anyone modified the drain outlet to speed up the process? How? If not modify the drain outlet are there other suggestions? 2. Draining the tank in a campground is prohibied. Are other owners driving down the road with the open? Or what? Thanks 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
Moderator+ ScubaRx Posted March 23 Moderator+ Posted March 23 Open the drain while driving to your destination. But why does your fresh water tank have any water in it if it’s supposed to be winterized? 6 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Moderators bugeyedriver Posted March 23 Moderators Posted March 23 Steve has a reasonable question about why there is any liquid in the fresh tank at all. Best to have no fluids there at all . . . nothing to freeze. About the slow drainage, well yeah, you do have a tiny drain pipe exiting the trailer from the fresh water tank. The tank is many feet long, but only several inches tall. Not a lot of pressure in the line is available from this configuration, resulting in a puny discharge rate when the trailer is perfectly level. To fix this, raise the nose of the trailer as high as possible, thus giving more depth to the column of water and resulting in a higher pressure at the discharge port and a higher flow rate. It will still take a bit of time, but not as bad as a perfectly level unit. As Steve states, opening the drain while driving is a good tactic, but be prepared for all of the folks passing you, honking and pointing to the back of your trailer as the tank empties. Ha! Good luck. 1 8 Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com
Rolind Posted March 23 Posted March 23 I wondered why there was water in the fresh tank if it was winterized also. I think the OP may be flushing the small amount of rv antifreeze out of the lines and freshwater tank when dewinterizing. I usually do with the fresh water drain open, and even if you fill the tank up a little bit, it takes a while to drain. That would also explain why the OP states it isn’t allowed at the campground. I usually don’t worry about the small amount of rv antifreeze draining onto the campsite. It’s mostly alcohol and just like breaking a good bottle of bourbon at the campsite wo the profanity. 1 2 2 Robert and Cheryl, Louisville, KY, Legacy Elite II Hull #1390 Oliphino, TV F250 Tremor
Gliddenwoods Posted March 23 Author Posted March 23 The proper way to dewinterize (per Oliver Travel Trailer written and video instructions) is to fill the fresh water tank 50 to 100% to dilute the antifreeze and flush the tank. After which one allows this water to drain out under the camper. So & thus, yes indeed, there is water in the fresh water tank to be drained. So...back to my original questions; any helpful suggestions? 2022 Oliver Legacy Elite II, Hull 1242, 9/26/22 Lithium Platinum Power/Solar Package Tow with Supercrew Cab 2019 F-150 4 x4, 5.0L 4-Valve V8 with 3.73 axle ratio & 157" wheelbase. F-150 GCWR of 16,900 lbs with maximum load trailer of 11,500 lbs.
DavePhelps Posted March 23 Posted March 23 The FWT drain is at best slow draining given the design constraints of the system. One issue that can make it much worse is when bits of plastic end up inside the tank from drilling the various holes and not meticulously cleaning it out before installing. I have had these bits bunch up at the tank outlet and at the drain valve. When I added my new water supply draw tube, I cleaned and vacuumed out the tank best I could, and cleaned out the drain valve while I was in there as well. Now, not really wanting to go through that all over again, if it seems plugged up, I'll take my air compressor and blow up the outflow tube (30psi is good) into the tank. This usually clears the occlusions long enough to let the tank drain more normally, which is still slower than I'd like. Hope that works for you. Dave 1 2 2015 Oliver Elite, Hull 107 1998 Ford E-250, 5.4 liter
jd1923 Posted March 24 Posted March 24 3 hours ago, Gliddenwoods said: The proper way to dewinterize (per Oliver Travel Trailer written and video instructions) is to... How did I miss this one? Don't watch the one either about lubin' the stabilizer jacks! 🤣 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted March 24 Posted March 24 11 hours ago, bugeyedriver said: raise the nose of the trailer as high as possible 2 hours ago, DavePhelps said: I'll take my air compressor and blow up the outflow tube (30psi is good) into the tank. Certainly do these things. You may also find lifting the front helps at the dump station! When you blow out the drain (30-50 PSI is good), ALSO blow out the overflow which is under the fridge (only do this when the drain is open). A restricted overflow will impede draining, even if the drain is wide open! Learned this in high school chemistry class. 🤣 And you could use that compressed air to blow out the lines and forget about using antifreeze at all. If OTT in a video actually said to leave the fresh tank half full over winter!?! Please ignore that odd comment! Your manual drain valve has a 3/8” opening in a 1/2” PEX plumbing system. I replaced this valve with an electric motorized valve with a 12mm opening (near 1/2”). My tank now drains twice as fast! I often open the drain while on the road driving home, but don’t do this in prissy locations and those with an abundance of police officers! 🤣 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderator+ ScubaRx Posted Thursday at 06:08 AM Moderator+ Posted Thursday at 06:08 AM On 3/23/2025 at 4:41 PM, Gliddenwoods said: The proper way to dewinterize (per Oliver Travel Trailer written and video instructions) is to fill the fresh water tank 50 to 100% to dilute the antifreeze and flush the tank. After which one allows this water to drain out under the camper. So & thus, yes indeed, there is water in the fresh water tank to be drained. So...back to my original questions; any helpful suggestions? Why not just use the city water connection to flush all the lines? Then all the flush water will go into the gray tank. Also you don’t have to run your pump. Some folks (myself included) will sometimes overthink a simple issue. Oliver dropped the ball on this one. 6 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
johnwen Posted Thursday at 02:06 PM Posted Thursday at 02:06 PM On 3/23/2025 at 9:46 PM, jd1923 said: I replaced this valve with an electric motorized valve with a 12mm opening (near 1/2”) JD I should look at this mod the next time we cross paths! John Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
jd1923 Posted Thursday at 09:59 PM Posted Thursday at 09:59 PM 7 hours ago, johnwen said: JD I should look at this mod the next time we cross paths! John Thanks and can do! 😂 I have an older, longer detailed post... but the first post in this thread shows the highlights! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
