chuckstovall Posted May 12, 2025 Posted May 12, 2025 On my 2017 LEII, I've had problems with my Carefree manual awning. Specifically the plastic parts involved with the struts. I'm done trying to keep it functional and am ready to replace it. I'd read that at some point Oliver had gone to Fiamma (not sure if that is correct) and that they now supply Girard. I'm happy with manual operation but would like something that is simple, dependable and easy to use. I'm confident with doing the install myself so just need to find the right one. If you like yours, what do you have? If you've replaced yours, what did you get? Did anyone DIY on the replacement? Along that line, I measure my current awning at 14'4" outside to outside of mechanism, with the actual fabric closer to 14'. Jason tells me the current LEII's come with 16'. Lastly, has anyone swapped their as-built manual for a powered awning? If so, can you fill me in please? Thanks in advance!
Moderators Mike and Carol Posted May 12, 2025 Moderators Posted May 12, 2025 My 2016 came with a manual Fiamma. It’s been reliable and still works fine. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
chuckstovall Posted May 13, 2025 Author Posted May 13, 2025 2 hours ago, Mike and Carol said: My 2016 came with a manual Fiamma. It’s been reliable and still works fine. Mike Thanks for the input. Does it have struts/legs for stabilization?
Moderator+ ScubaRx Posted May 13, 2025 Moderator+ Posted May 13, 2025 (edited) 2 hours ago, chuckstovall said: Thanks for the input. Does it have struts/legs for stabilization? The early Elite II's were all delivered with the Fiamma awnings and they do have legs, they are adjustable in length and can be staked down to the ground or slanted back to brackets mounted on the side of the trailer. At over 11 years in, like Mike and Carol, we have never had a single issue with ours. Edited May 13, 2025 by ScubaRx 1 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
jd1923 Posted May 13, 2025 Posted May 13, 2025 44 minutes ago, ScubaRx said: The early Elite II's were all delivered with the Fiamma awnings Ours too, and like Mike’s and Steve’s still in very good cosmetic and working condition. I find it a pain to use and honestly have only used it once in our 2 years. I usually just park so that our entrance side is in the afternoon shade. We enjoy morning sun with coffee. I would likely use an electric model more often. If ours were to fail though, I would just remove it and all the brackets, patch the fiberglass, and the Oliver would look so aerodynamically cool! 😂 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Jason Foster Posted May 13, 2025 Posted May 13, 2025 18 minutes ago, jd1923 said: ... and the Oliver would look so aerodynamically cool! 😂 Except for the marvelously non aerodynamic gull wing solar panels. 1 2 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Moderators Mike and Carol Posted May 13, 2025 Moderators Posted May 13, 2025 10 hours ago, chuckstovall said: Thanks for the input. Does it have struts/legs for stabilization? Yes, it does. They can sit in brackets on the side of the trailer or you can drop them straight down to the ground. You can also stake them to the ground which I have done. With our sunshade attached the awning can withstand some pretty windy conditions. It’s not as easy to deploy as the electrics, but is not really a hassle either. Mike 1 5 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Moderators SeaDawg Posted May 14, 2025 Moderators Posted May 14, 2025 My 2008 elite came with a Fiama. Manual. We replaced it with another Fiama manual after it suffered some stress (Our fault.) Still working great, 8byears or so later. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Jason Foster Posted May 14, 2025 Posted May 14, 2025 12 hours ago, Mike and Carol said: Yes, it does. They can sit in brackets on the side of the trailer or you can drop them straight down to the ground. You can also stake them to the ground which I have done. With our sunshade attached the awning can withstand some pretty windy conditions. It’s not as easy to deploy as the electrics, but is not really a hassle either. Mike A sunshade for an awning. Wait a second. I need one of those. Is that specific to yours or is it a generic that can be used with any one of them. Specifically, a Girard power awning like mine. I wonder how that would work with the auto retract system? 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
chuckstovall Posted May 14, 2025 Author Posted May 14, 2025 3 hours ago, SeaDawg said: My 2008 elite came with a Fiama. Manual. We replaced it with another Fiama manual after it suffered some stress (Our fault.) Still working great, 8byears or so later. Thanks - great info. Some follow-up questions, if you don't mind. Is it the F45s model? Do you recall the length? Where did you buy it?
Moderators Mike and Carol Posted May 14, 2025 Moderators Posted May 14, 2025 11 hours ago, Jason Foster said: A sunshade for an awning. Wait a second. I need one of those. Is that specific to yours or is it a generic that can be used with any one of them. Specifically, a Girard power awning like mine. I wonder how that would work with the auto retract system? It’s generic, we got it at Quartzsite at one of the booth vendors that are always set up selling RV stuff. It slides into the rail on our awning (there are two). The very top part has a zipper so you can drop the main part quickly if necessary. The smaller top part also makes installing it pretty simple. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Ronbrink Posted May 14, 2025 Posted May 14, 2025 11 hours ago, Jason Foster said: A sunshade for an awning. Wait a second. I need one of those. Is that specific to yours or is it a generic that can be used with any one of them. Specifically, a Girard power awning like mine. I wonder how that would work with the auto retract system? Aftermarket sunshade kits are readily available for a variety of awning makes and models. One would want to turn off the switched power with use on an auto retract unit. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Jason Foster Posted May 15, 2025 Posted May 15, 2025 15 hours ago, Mike and Carol said: It’s generic, we got it at Quartzsite at one of the booth vendors that are always set up selling RV stuff. It slides into the rail on our awning (there are two). The very top part has a zipper so you can drop the main part quickly if necessary. The smaller top part also makes installing it pretty simple. Awesome. Definitely want the zipper style since my awning seems a bit flimsy in the wind. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Jason Foster Posted May 15, 2025 Posted May 15, 2025 15 hours ago, Ronbrink said: Aftermarket sunshade kits are readily available for a variety of awning makes and models. One would want to turn off the switched power with use on an auto retract unit. I would definitely want to keep up with wind conditions since this would only increase the sail. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Ronbrink Posted May 15, 2025 Posted May 15, 2025 7 hours ago, Jason Foster said: I would definitely want to keep up with wind conditions since this would only increase the sail. Right that! I’ve seen where support posts are placed at each corner of the awning (which manual awnings already have or variations thereof) and the bottom of the sunshade is anchored. Supposedly this makes for a more stable setup in windy conditions. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Jason Foster Posted May 15, 2025 Posted May 15, 2025 1 hour ago, Ronbrink said: Right that! I’ve seen where support posts are placed at each corner of the awning (which manual awnings already have or variations thereof) and the bottom of the sunshade is anchored. Supposedly this makes for a more stable setup in windy conditions. I wonder if these support poles are made specifically for Girard or a MacGyver option sans previously chewed gum. 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Ronbrink Posted May 15, 2025 Posted May 15, 2025 (edited) 4 minutes ago, Jason Foster said: I wonder if these support poles are made specifically for Girard or a MacGyver option sans previously chewed gum. Likely MacGyvered adaptations!! Actually, Carefree offers a height adjustable vertical stabilizer that looks universal for all awning types. Edited May 15, 2025 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Jason Foster Posted May 15, 2025 Posted May 15, 2025 56 minutes ago, Ronbrink said: Likely MacGyvered adaptations!! Actually, Carefree offers a height adjustable vertical stabilizer that looks universal for all awning types. Ah ha. Thanks for this. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
