davekaro Posted May 27, 2025 Posted May 27, 2025 On 5/26/2025 at 7:56 AM, rich.dev said: Please report back on what style windows Oliver will be swinging to. It was confirmed on the tour today that 2026 model Olivers will have awning style windows. Full details still being worked out and 2026 model details should available in the coming weeks. 2 5
rich.dev Posted May 27, 2025 Posted May 27, 2025 51 minutes ago, davekaro said: It was confirmed on the tour today that 2026 model Olivers will have awning style windows. Full details still being worked out and 2026 model details should available in the coming weeks Nice, I will definitely be interested in switching if the window openings of the 2026 are the same as my 2023! 4 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
rich.dev Posted May 27, 2025 Posted May 27, 2025 (edited) @topgun2, I can see this topic (Oliver switching to awning style windows in 2026) getting a lot of interest, maybe move these window posts to a new thread? Edited May 27, 2025 by rich.dev 3 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Moderators topgun2 Posted May 27, 2025 Moderators Posted May 27, 2025 3 hours ago, rich.dev said: I can see this topic (Oliver switching to awning style windows in 2026) getting a lot of interest, maybe move these window posts to a new thread? Good point rich.dev - your wish is my command.😃 Thanks for the suggestion. Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted May 27, 2025 Posted May 27, 2025 (edited) 5 hours ago, rich.dev said: Nice, I will definitely be interested in switching if the window openings of the 2026 are the same as my 2023! In my discussion with Scott Oliver while at the rally, the possible “retro fit” of the new double pane/insulated awning tilt out windows is something they are considering. (This will be expensive to retrofit if it can be done). Scott said that the engineering dept is working on it. The only concern I have is sacrificing the great cross ventilation of the existing windows which we really like. The tilt out windows have their pros and cons, but will also really limit cross ventilation. It will be interesting to see how this unfolds. Edited May 28, 2025 by Patriot 4 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
rich.dev Posted May 28, 2025 Posted May 28, 2025 (edited) 44 minutes ago, Patriot said: The only concern I have is sacrificing the great cross ventilation of the existing windows which we really like. The tilt out windows have their pros and cons, but will also really limit cross ventilation. Am I missing something, I believe with a fully tilt out window you will actually have much better cross ventilation vs the stock sliding windows, it boils down to size matters! The opening with my side windows fully open is approx. 15"x18" (only approx. half of it widthwise is open), wherass with a same frame size as current Olivers but fully tilt out window you will have the entire window opening of approx. 15"x46". VS Edited May 28, 2025 by rich.dev 3 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Patriot Posted May 28, 2025 Posted May 28, 2025 (edited) 1 hour ago, rich.dev said: Am I missing something, I believe with a fully tilt out window you will actually have much better cross ventilation vs the stock sliding windows, it boils down to size matters! The opening with my side windows fully open is approx. 15"x18" (only approx. half of it widthwise is open), wherass with a same frame size as current Olivers but fully tilt out window you will have the entire window opening of approx. 15"x46". VS The only important detail missing is exactly which model/manufacturer tilt out window Oliver will choose as a supplier. 🤔 The window you show appears to be a basic lexan non double pane style? My understanding is the new windows will be insulated, tinted glass, and double pane and hopefully up fitted with no see um screens. Then what sort of privacy shade will the new windows have? Lots of details to be worked out for sure. So for now it’s pretty much a wait and see. Hopefully for future owners they will fully tilt out. Edited May 28, 2025 by Patriot 5 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted May 28, 2025 Posted May 28, 2025 34 minutes ago, rich.dev said: Am I missing something, I believe with a fully tilt out window you will actually have much better cross ventilation vs the stock sliding windows, it boils down to size matters! This is certainly true when there is a good breeze outside. When it’s still out, you can turn the fan on exhaust, just barely crack the window(s) where you want the airflow to get good ventilation. The fact that the bedside windows open on the rear side and the fan is front of beds it pulls air across the bed. A better breeze is felt if you sleep heads towards the kitchen/pantry. 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
davekaro Posted May 28, 2025 Posted May 28, 2025 21 minutes ago, Patriot said: The only important detail missing is exactly which model/manufacturer tilt out window Oliver will choose as a supplier. Correct. It wasn't revealed to me what model/manufacturer they are going with. It was mentioned they thought the tilt out would be about 8 inches. So, still not clear, and we will wait and see. 21 minutes ago, jd1923 said: you can turn the fan on exhaust Agree. If the cross-flow ventilation isn't cutting it with the new awning windows, I imagine turning on the fan on exhaust will alleviate that issue. 1
Patriot Posted May 28, 2025 Posted May 28, 2025 (edited) 25 minutes ago, davekaro said: It was mentioned they thought the tilt out would be about 8 inches. So, still not clear, and we will wait and see. I heard the same, and an 8” tilt out would be reduced air flow vs existing the windows with cross ventilation. I really don’t have a dog in the fight and have not had any issues with my current windows which provide great cross ventilation. Just regular maintenance in keeping the tracks and weep holes clean and all is good. It will be interesting to see what supplier of tilt out windows the Oliver engineers roll with. Edited May 28, 2025 by Patriot 4 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
rich.dev Posted May 28, 2025 Posted May 28, 2025 30 minutes ago, Patriot said: I heard the same, and an 8” tilt out would be reduced air flow vs existing the windows with cross ventilation Ah yes, a bummer for the new owners if it’s the partial tilt out windows, I just assumed it would be the fully tilt out windows! A good reminder what someone once told me, assumption is the mother of all screw ups! 6 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
rich.dev Posted May 31, 2025 Posted May 31, 2025 (edited) Here’s a post on Facebook showing the new bathroom window, looks like a full tilt out awning window! https://www.facebook.com/share/p/1AfbuQxS34/?mibextid=wwXIfr Edited May 31, 2025 by rich.dev 4 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
rideadeuce Posted May 31, 2025 Posted May 31, 2025 (edited) Not sure how applicable smart glass would be for an Oliver trailer but the function is awesome. In the camper below, all the windows and bathroom glass are smart glass which can change from clear to opaque with a push of a button providing instant privacy. No tracks to clean or window treatments to manage. https://www.smartglasstech.us/city/usa-smart-glass-technologies-landing/ Changed the video to one without music. It shows the smart glass function but the longer videos show it’s use better. Also, linked made in USA manufacturer site that explains more about the technology. Best, M Edited June 1, 2025 by rideadeuce 2 - Mike Brentwood, TN - 2018 Elite II - Spirit of Adventure Hull #308 - 2016 Toyota Tundra Limited 5.7L Class IV hitch with 12k lb coupler, Weigh safe adjustable trailer hitch, Dobinsons HD 2in Leaf springs, Timbren bump stops, Dobinsons 3in coilovers and UCAs, Mechman 370 amp HO alternator. Oliver upgrades: Starlink, Cradlepoint cellular modem, Victron Multiplus II 12V 3000W, Ekrano display, Orion XS 50amp DC/DC charger with Anderson connections, Toshiba 6-in-1 Microwave oven - air fryer combo, Atmos 4.4 15k AC/12K Heat pump, Nova Kool 5810 fridge, Epoch 460aH x2, 520 watts solar on top, Custom aluminum bicycle rack, Alcan Springs, Bulldog shocks, Falken H/T02 tires, Seabiscuit Metal Designs front storage box and moose rack.
davekaro Posted May 31, 2025 Posted May 31, 2025 9 hours ago, rich.dev said: looks like a full tilt out awning window! Love the enthusiasm but what makes you think so from this photo?
jd1923 Posted May 31, 2025 Posted May 31, 2025 5 hours ago, rideadeuce said: … can change from clear to opaque with a push of a button providing instant privacy. No tracks to clean or window treatments to manage. Video didn’t show much and given the noise, was t going to click on the long version! 🤣 A window that can go from full light to blackout dark would be a game-changer! This would allow us to delete our blinds, less day-to-day hassle and more seating room to lean back sideways on the beds and dinette seating. I still want sliders however for ease of one-handed opening/closing. Though I do get how full-timers have different needs. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted May 31, 2025 Posted May 31, 2025 (edited) 8 hours ago, davekaro said: Love the enthusiasm but what makes you think so from this photo? I don’t think it will be full tilt out….only time will tell. Edited May 31, 2025 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Patriot Posted May 31, 2025 Posted May 31, 2025 6 hours ago, jd1923 said: A window that can go from full light to blackout dark would be a game-changer! It sure would be a price point game changer. Cha Ching!! 😎 💸🤑 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Geronimo John Posted May 31, 2025 Posted May 31, 2025 6 hours ago, jd1923 said: A window that can go from full light to blackout dark would be a game-changer! This would allow us to delete our blinds, less day-to-day hassle and more seating room to lean back sideways on the beds and dinette seating. Really cool beans! TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Steph and Dud B Posted June 1, 2025 Posted June 1, 2025 On 5/24/2025 at 1:20 PM, davekaro said: Though awning style could be left open in rain without needing to have the trailer awning open. The Girard awnings on our 2022 are not supposed to be left open in the rain. Girard explicitly states not to have them partially open in the rain, either. I would prefer swing out acrylic windows for sure. 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Patriot Posted June 1, 2025 Posted June 1, 2025 (edited) 13 hours ago, Geronimo John said: Really cool beans! Of course the really “cool beans” would come at a much higher price for sure GJ which would surely be passed on. 😊 Edited June 1, 2025 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Patriot Posted June 1, 2025 Posted June 1, 2025 (edited) 1 hour ago, Steph and Dud B said: I would prefer swing out acrylic windows for sure. The only huge issue I would have with acrylic windows is how easy they scratch. Polishing scratches out of acrylic windows is a non starter for me. Let’s hope for future owners that the windows will be tilt out and glass and insulated. Edited June 1, 2025 by Patriot 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
rich.dev Posted June 6, 2025 Posted June 6, 2025 On 6/1/2025 at 9:30 AM, Patriot said: The only huge issue I would have with acrylic windows is how easy they scratch. Polishing scratches out of acrylic windows is a non starter for me. Another sneak peak from Oliver about the new windows, to me they don’t look like acrylic, but hopefully dual pane! https://www.facebook.com/share/r/1CDPcaif7x/?mibextid=wwXIfr 2 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Patriot Posted June 6, 2025 Posted June 6, 2025 (edited) 1 hour ago, rich.dev said: Another sneak peak from Oliver about the new windows, to me they don’t look like acrylic, but hopefully dual pane! https://www.facebook.com/share/r/1CDPcaif7x/?mibextid=wwXIfr Yes, they look nice, and there is more to come! 😊 Edited June 6, 2025 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Patriot Posted June 8, 2025 Posted June 8, 2025 (edited) Just speculating on other possible changes here.😎 New upgraded sound system? New style/type of flooring and update on seat cushion color/cover options? A direct dedicated plug for Starlink? Induction cook top similar to the (pic) replacing the LP burners maybe? 🤔 Edited June 8, 2025 by Patriot 4 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
davekaro Posted June 8, 2025 Posted June 8, 2025 2 hours ago, Patriot said: A direct dedicated plug for Starlink? How do you envision this working or what would the point of it? Is it an Ethernet port to extend coverage inside the trailer? Is it just a DC power port? Both?
