FLYnGATOR Posted June 24 Posted June 24 While charging on the generator, the 25 amp circuit breaker on the Zantrex 3000 inverter keeps tripping. I’m running the generator and the inverter switch ON I’m using a champion 3400 W generator and running the air conditioner simultaneously. Could it be the charger and the air conditioner are pulling too many amps simultaneously tripping the breaker? I’m going to try charging only, with the air conditioner off and inverter switch OFF any thoughts? Mark Mark & Claudia “Mr. Douglas” 2024 LE ll twin, hull # 1457, Truma AC & WH, Platinum solar, Natures Head 2024 Ford f250 Lariat Ultimate 7.3L gasser / 3.75, FX4
Geronimo John Posted June 25 Posted June 25 8 hours ago, FLYnGATOR said: I’m running the generator and the inverter switch ON Here is how I remember it: The Inverter's job is to Invert your power. It takes DC from the batteries and turns in in to AC via a transformer an turns it upside down again and a gain to create 60 hertz Alternating Current for your 120 V systems. The Converter takes 120 volt power and Chargers your batteries. Normally the Auto Transfer Switch causes the Inverter to not be energized at the same time as the C. nThis is because the inverter is not needed when you have A/C power from a shore power source. But it is possible and desirable to charge your batteries using the C and also power it up by your generator providing the energy to do so. This can be a high draw and "sucks up" much of what the main breaker will allow. Since I don't have clue what systems you have in a wonderful 2024, I can only suggest that if you have the ability to change your C charge rate, it may be pulling a lot of power that overloads the breaker. Hence some folks have dialed down the charge rate to leave more power available for other uses. You can check this by flipping the C's breaker off and see if you are still tripping the main breaker when on generator. OH one more hint. Many generators require us to use a bonded neutral plug. Like Honda's for example. I would start with that topic on the forum. The Progressive Industries EMS will no allow power from an unbonded neutrall for such generators. But failing to do so has not tripped a main that I am aware of. It willl however preclude shore power from getting you to your 120V loads. Hope this helps out a little bit. GJ 5 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Snackchaser Posted June 25 Posted June 25 19 hours ago, FLYnGATOR said: any thoughts? Hi Mark, There could be a number of reasons why the 25 amp Inverter breaker is tripping. However, assuming that the Air Conditioning and Charger are otherwise working fine, then the most likely reasons are the inverter settings, the breaker, or the generator. It’s helpful to understand that all AC loads (except the refrigerator) pass-through the inverter, and it automatically prioritizes current to the AC loads over charging. So when the 20 amp Air Conditioner is passing through, it throttles down the charger amps to prevent overcurrent. The inverter charge current demand is highest when the battery is discharged, so it might just be overworking the inverter enough to trip the breaker’s thermo element when running the Air Conditioner with a discharged battery. If the battery is not fully discharged, and it’s still tripping, then read on. BTW, if the inverter is turned-on while using shore or generator power, it only means that it will automatically transfer to battery power if shore power fails. Also, the generator neutral bonding will not impact the current or breaker, but it’s required by code. I have 4 troubleshooting suggestions. Items 3 and 4 will require some experimentation with the inverter settings and this is best done using the Xantrex phone app. These settings will not harm anything, but they will reduce inverter output to match the capacity of your generator. It’s a low probability that the 25 amp breaker is bad, but it is a possibility because the inverter should warn you and shut down when it nears it maximum output… before the breaker trips. A quick assessment can be made without an amp meter. If it’s tripping instantly, it means the magnetic short circuit trip function is probably bad and the breaker should be replaced. If it trips’s after some time, and it can easily re-set after cooldown, then it’s tripping on the thermo function and it’s probably okay. The generator is big enough to handle your loads, but it could be that the regulator is not working properly. Verify that it’s increasing RPMs when the load increases. You can also check the input voltage on the Xantrex display, it should be close to 120 volts. The inverter’s charger current setting is too high (Setting 24.) The default setting is 150 amps, but it’s not an amp to amp conversion. I’d set it to 30 amps and if the breaker no longer trips, then dial it up in 20 amp increments until you find a trip-less value. I had to change this setting on my inverter because it was drawing more current than my 2000 watt generator could supply, and I was getting low voltage brown outs. It would have probably tripped the breaker eventually, but the generator tripped first. I think I finally set it to 60 amps. The inverter’s AC input breaker setting is too high (Setting 28.) This impacts the load prioritization ratio. The default setting is 50 amps so you can start by setting it to 25 amps to see if that works. If so, then dial it up in 5 amp increments until you find a value below the breaker trip value. Note: I’d change settings 24 and 28 at the same time, then dial them up until you find a an acceptable value where the breaker does not trip. I hope that helps! Cheers, Geoff 1 7 1
John Dorrer Posted June 25 Posted June 25 34 minutes ago, Snackchaser said: Hi Mark, There could be a number of reasons why the 25 amp Inverter breaker is tripping. However, assuming that the Air Conditioning and Charger are otherwise working fine, then the most likely reasons are the inverter settings, the breaker, or the generator. It’s helpful to understand that all AC loads (except the refrigerator) pass-through the inverter, and it automatically prioritizes current to the AC loads over charging. So when the 20 amp Air Conditioner is passing through, it throttles down the charger amps to prevent overcurrent. The inverter charge current demand is highest when the battery is discharged, so it might just be overworking the inverter enough to trip the breaker’s thermo element when running the Air Conditioner with a discharged battery. If the battery is not fully discharged, and it’s still tripping, then read on. BTW, if the inverter is turned-on while using shore or generator power, it only means that it will automatically transfer to battery power if shore power fails. Also, the generator neutral bonding will not impact the current or breaker, but it’s required by code. I have 4 troubleshooting suggestions. Items 3 and 4 will require some experimentation with the inverter settings and this is best done using the Xantrex phone app. These settings will not harm anything, but they will reduce inverter output to match the capacity of your generator. It’s a low probability that the 25 amp breaker is bad, but it is a possibility because the inverter should warn you and shut down when it nears it maximum output… before the breaker trips. A quick assessment can be made without an amp meter. If it’s tripping instantly, it means the magnetic short circuit trip function is probably bad and the breaker should be replaced. If it trips’s after some time, and it can easily re-set after cooldown, then it’s tripping on the thermo function and it’s probably okay. The generator is big enough to handle your loads, but it could be that the regulator is not working properly. Verify that it’s increasing RPMs when the load increases. You can also check the input voltage on the Xantrex display, it should be close to 120 volts. The inverter’s charger current setting is too high (Setting 24.) The default setting is 150 amps, but it’s not an amp to amp conversion. I’d set it to 30 amps and if the breaker no longer trips, then dial it up in 20 amp increments until you find a trip-less value. I had to change this setting on my inverter because it was drawing more current than my 2000 watt generator could supply, and I was getting low voltage brown outs. It would have probably tripped the breaker eventually, but the generator tripped first. I think I finally set it to 60 amps. The inverter’s AC input breaker setting is too high (Setting 28.) This impacts the load prioritization ratio. The default setting is 50 amps so you can start by setting it to 25 amps to see if that works. If so, then dial it up in 5 amp increments until you find a value below the breaker trip value. Note: I’d change settings 24 and 28 at the same time, then dial them up until you find a an acceptable value where the breaker does not trip. I hope that helps! Cheers, Geoff I tried to help on Mark's Facebook post. I think your explanation is correct. I was trying to figure out why he has the inverter on. Using shore power at the power post or a generator the inverter shouldn't be on. I was getting hung up on this. I have charged our 2022 LE, Lithium & Solar without changing any settings. I have also run the AC without making any adjustments. When I use the generator it is being run on fuel. He is running his on LP. 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
John Dorrer Posted June 25 Posted June 25 20 hours ago, FLYnGATOR said: While charging on the generator, the 25 amp circuit breaker on the Zantrex 3000 inverter keeps tripping. I’m running the generator and the inverter switch ON I’m using a champion 3400 W generator and running the air conditioner simultaneously. Could it be the charger and the air conditioner are pulling too many amps simultaneously tripping the breaker? I’m going to try charging only, with the air conditioner off and inverter switch OFF any thoughts? Mark Mark, I think you got better recommendations here. Hopefully you get things sorted out. 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
FLYnGATOR Posted June 25 Author Posted June 25 Great explanation! Thanks so much for the information! I’ll keep you posted Mark 1 Mark & Claudia “Mr. Douglas” 2024 LE ll twin, hull # 1457, Truma AC & WH, Platinum solar, Natures Head 2024 Ford f250 Lariat Ultimate 7.3L gasser / 3.75, FX4
Geronimo John Posted June 26 Posted June 26 12 hours ago, Snackchaser said: Also, the generator neutral bonding will not impact the current or breaker, but it’s required by code. On our "Older" Ollie's the Progressive Industries system switch makes a difference to getting power into the trailer when the power is coming from most generators that require neutral bonding.. Are you saying that is not the case for "Newer" Ollies? Thanks just trying to keep up to date. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rich.dev Posted June 26 Posted June 26 9 hours ago, Geronimo John said: On our "Older" Ollie's the Progressive Industries system switch makes a difference to getting power into the trailer when the power is coming from most generators that require neutral bonding.. Are you saying that is not the case for "Newer" Ollies? Thanks just trying to keep up to date. On our 2023 you still need the neutral bonding plug to run a generator, you can override it by turning off the progressive industries switch in the attic. 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Snackchaser Posted June 26 Posted June 26 10 hours ago, Geronimo John said: On our "Older" Ollie's the Progressive Industries system switch makes a difference to getting power into the trailer when the power is coming from most generators that require neutral bonding.. Are you saying that is not the case for "Newer" Ollies? Thanks just trying to keep up to date. This is a great question John, and it brings to mind that a lot of folks probably don’t understand the importance of bonded neutrals on RV generators. The NEC requires neutrals to be bonded to ground at all power sources so that any fault currents have a path back to the source. This assures that any fault current has a low resistance path to ground that can handle enough current to trip the breakers. Otherwise, the fault current will look for an alternate path to ground and there might not be enough current flow to trip the breaker… at least until someone comes along and completes the path to ground and gets a shocking surprise! This is particularly important for the Progressive Industries transfer switches because they switch both the hot and neutral wires. When the switch transfers to an un-bonded neutral, then it’s possible to create a situation where there is no path to ground. This is true for all Olivers, both old and new. Additionally, GFCI’s and surge protectors rely on the ground to detect circuit imbalances. Both the hot and neutral conductors pass through a Current Transformer and cancel each other out in a balanced circuit. However, any leakage to ground from either hot or neutral wire will be detected by the Current Transformer, which then instantly interrupts the circuit. This can’t work if the neutral isn't bonded to the ground. So it’s important that RV generators are bonded to ground, and most of them are. It should say so on the label, and the few that aren’t bonded, including Hondas, will say something like “floating ground.” If you're still uncertain, then just use a Generator Bonding Plug which are readily available for under $20. Cheers, Geoff 1 4 1
Moderators Mike and Carol Posted June 26 Moderators Posted June 26 I have a 2K watt Champion inverter generator that I just plug in to, I haven’t used a special plug. I guess I need to look to see if the Champion is “bonded to ground”, something I wasn’t aware of. Going on 10 years and still learning…. Mike 6 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Geronimo John Posted June 26 Posted June 26 8 minutes ago, Mike and Carol said: I have a 2K watt Champion inverter generator that I just plug in to, I haven’t used a special plug. I guess I need to look to see if the Champion is “bonded to ground”, something I wasn’t aware of. Going on 10 years and still learning…. Mike Either that OR you have been running power protection naked for ten years. Good news is that if so you still have a lot of Joules left in your Progressive Industries power filter! 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted June 26 Posted June 26 (edited) 1 hour ago, Snackchaser said: This is a great question John, and it brings to mind that a lot of folks probably don’t understand the importance of bonded neutrals on RV generators. Geoff: For sure. When I first purchased my Ollie (2018) I was having power issues and could not figure it out. Then one of the forum owners mentioned the use of the bonded plug. Problems disappeared. But every so often the issue pokes its head out of the covers and all of a sudden it is a new topic. This is one item that OTT needs to really stress in their Owner's training and manual. Thank you for the details on how it works. That I did not fully know. Your post has made it's way into my DIY folder so I can whip it out when the covers get disturbed again for another owner. GJ Edited June 26 by Geronimo John added visual of device discussed. 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators Mike and Carol Posted June 26 Moderators Posted June 26 10 minutes ago, Geronimo John said: Either that OR you have been running power protection naked for ten years. Good news is that if so you still have a lot of Joules left in your Progressive Industries power filter! Yep, joule preservation is important when running naked, (power protection naked, of course). 4 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Geronimo John Posted June 26 Posted June 26 (edited) 47 minutes ago, Mike and Carol said: Yep, joule preservation is important when running naked, (power protection naked, of course). I was wondering it anybody would catch that one. LOL! Edited June 26 by Geronimo John 2 2 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
John Dorrer Posted June 27 Posted June 27 I may have missed something here. I believe the OP said he was running his generator on LP. I don't recall seeing that discussed. How much of a difference is there using LP vs fuel? It was my understanding there is a significant difference. Will the change of some settings then allow his AC to run without issues? John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Steph and Dud B Posted June 27 Posted June 27 23 minutes ago, John Dorrer said: How much of a difference is there using LP vs fuel? Good point. I believe running on propane derates the generator by a bit. With a 3400W unit, maybe enough to cause an overload in this situation, but I was wondering why it wasn't tripping the breaker on the generator. Now, after @Snackchaser's excellent explanation I'm wondering if an unbonded generator is preventing the generator's built in breaker from tripping, causing the Oliver's internal breaker to trip instead. However, the Progressive power protection should not have let him connect an unbonded generator in the first place, so maybe the generator's breaker is faulty? 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
rich.dev Posted June 27 Posted June 27 26 minutes ago, John Dorrer said: I may have missed something here. I believe the OP said he was running his generator on LP. I don't recall seeing that discussed. How much of a difference is there using LP vs fuel? It was my understanding there is a significant difference. Will the change of some settings then allow his AC to run without issues? John, we run our dual fuel Maxpeedingrods MXR3500S on propane without any issues. I prefer propane vs gas - it's cleaner burning, more eco friendly and lower maintenance. However, with propane you lose energy output, on our MXR3500S the specs are: Peak Wattage: 3500W (Gas) / 3100W (LPG) and Running Wattage: 3200W (Gas) / 2800W (LPG). 1 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
FLYnGATOR Posted June 27 Author Posted June 27 Update 25 amp inverter breaker still trips on normal shore power. So I don’t believe it was my generator. The breaker is tripping on thermo as it is HOT and resets after cooling. This occurs with and without the air conditioning on. Dialed the charger down to 80A Same result Mark 1 Mark & Claudia “Mr. Douglas” 2024 LE ll twin, hull # 1457, Truma AC & WH, Platinum solar, Natures Head 2024 Ford f250 Lariat Ultimate 7.3L gasser / 3.75, FX4
FLYnGATOR Posted June 27 Author Posted June 27 I get about 60 minutes or so of charging before the breaker trips 1 Mark & Claudia “Mr. Douglas” 2024 LE ll twin, hull # 1457, Truma AC & WH, Platinum solar, Natures Head 2024 Ford f250 Lariat Ultimate 7.3L gasser / 3.75, FX4
Snackchaser Posted June 27 Posted June 27 Mark, Good going, you're narrowing it down! We now know that the breaker gets hot over a 60 minute period when charging the battery, and it trips as it should. It's important to know if only the breaker is getting hot, or the accociated circuit wiring too? If it's just the breaker, then it probably has some internal resistance and it should be replaced. You could verify that by swapping it with the other 25 amp panel breaker and re-test. If the whole circuit is getting hot, then that's an indication of something else. It would also be helpful to know If the breaker was tripping sooner than 60 minutes originally, and if you lengthened the time by dialing down the charge amps. You can go always dial it down more. 1
FLYnGATOR Posted June 27 Author Posted June 27 Also discovered that the 25 amp inverter breaker Does not need to be on for the inverter from battery. The only way to get “shore power“ in is to have the breaker on Mark & Claudia “Mr. Douglas” 2024 LE ll twin, hull # 1457, Truma AC & WH, Platinum solar, Natures Head 2024 Ford f250 Lariat Ultimate 7.3L gasser / 3.75, FX4
FLYnGATOR Posted June 27 Author Posted June 27 I always got 60 to 90 minutes charging time before the breaker would trip. I will swap out the breakers to test the circuit when I get home Mark & Claudia “Mr. Douglas” 2024 LE ll twin, hull # 1457, Truma AC & WH, Platinum solar, Natures Head 2024 Ford f250 Lariat Ultimate 7.3L gasser / 3.75, FX4
FLYnGATOR Posted June 27 Author Posted June 27 Thanks again for your expertise. Always nice to know if I’ve got the star link, I can get some technical help! Mark & Claudia “Mr. Douglas” 2024 LE ll twin, hull # 1457, Truma AC & WH, Platinum solar, Natures Head 2024 Ford f250 Lariat Ultimate 7.3L gasser / 3.75, FX4
jd1923 Posted June 28 Posted June 28 On 6/25/2025 at 10:46 AM, John Dorrer said: I was trying to figure out why he has the inverter on. Using shore power at the power post or a generator the inverter shouldn't be on. I was getting hung up on this. It really depends. Geoff really explained every facet nicely and fully in detail. Everybody should read his post a few times! When we had the OTT installed 2KW Xantrex, when OFF shore power you had to turn the inverter on to run anything 120VAC, but not the air. You wanted it off most of the time if you're running on LA or AGM batteries, when not needing AC appliances/outlets so you would not loose SOC%. With a 3KW inverter installed, generally all AC circuits run through the inverter including the A/C. This is also how I installed our Victron Multiplus 2. I see no reason to ever turn off our inverter, so we don't. In fact since I installed it a year ago it has been on 24x7x365 unless it's on high amp charge when I'm trying to get to sleep and it's making some noise under my bed. Then I turn it OFF via the Bluetooth app and turn it back ON when I wake. With ample Ah LiFePO4 batteries and rooftop solar and the fact that our hull sits outdoors and does not get winterized nor go in storage, our Victron MP2 in ALWAYS powered on ready to use anytime. 1 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted June 29 Posted June 29 (edited) On 6/27/2025 at 11:05 AM, FLYnGATOR said: The breaker is tripping on thermo as it is HOT and resets after cooling. This occurs with and without the air conditioning on. Thermal tripping can be caused by a bad connection. With a corroded or loose connection the increased resistance will cause a voltage drop. Yet the loads will still operate at the same wattage. To do that, the amps increase. The heat generated usually is AT the corrosion site. Hence needing a thermal gun as well a clamp on Multi Meter. GJ Edited June 29 by Geronimo John added or loose connection 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
