I have two of the touch lights, the one over the stove, and the one over the sink that work sometimes, and don't work most of the time.
I want a light with a real switch like the one in the bathroom.
I don't want to do anything to the existing light hole.  I understand I will need a hole for a switch.
Has anyone done this?
What light did you use, and where did you get it.
Thanks
Am I the only one having problems with the touch lights?
We had an issue with the touch light over the sink. It started acting intermittent last season, and then pretty much stopped working. Then for some reason, it “sorta” worked, sometimes coming on when touched, other times not. Oddly, when it was “off”, it stayed on dimly all the time. It got to the point I’d have to shut off the lighting master. I just didn’t want a light kinda working, and perhaps doing something bad - like starting a fire.
I ordered these lights from Amazon - thinking they were touch lights just as were already installed.
https://a.co/d/cg5xSAf
When I finally got around to doing the replacement a couple of weeks ago, I found they are NOT touch lights, having a physical switch in the same location in the center of the light as the factory installed lights do.
They look pretty much the same, and the mounting holes are close enough that no new holes need to be drilled.
You’ll need to drill out the three pop rivets holding the old light in place, and get a light duty pop rivet gun and the smallest rivers (1/16” I think) to install the new light. You’ll also have to pull out the rubbed rubber mat and thin plastic floor plate in the cabinet to access the wires. I used crimp-on butt splices to make the new connection.
Though I intended to replace the defective light with another touch light, I think I’m happier with a real switch as it more likely cuts the power off completely when off - where a touch light has to always be energized to sense your touch.
PS - I probably could have used the included sheet metal screws - or a bit longer ones - instead of pop rivets, as I don’t really like them that much.
Edited by Galileo
Added the PS
  • Care 1
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
(17.9mpg towing, 35mpg clean)
RealTruck hard tonneau cover
Rove R2-4K DashCams
I replaced all of my lights this year.  Got them on amazon,  they are 5 inch with a switch along the bezel  they are dimmable also..  not to tech savey no pics look them up..  they dont sit flush , but it’s pretty close. Ok for for my taste…. I had two touch lights replaced under warrenty..  didnt last to long..   Im very happy with the lights i installed..  Good luck..  OTT finally got rid of those lights ..  went with the ones with a switch..
spacer.png2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
Thanks
See my longer post - you WON’T need a new hole for the switch!
BTW - I don’t really like the light switch in the bathroom. I find it pops loose out of the hole easily.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
My stove one is acting exactly like your sink one.
My sink one was acting up, but it seems to be fine now.  I don't use the other touch lights very much.
Thanks for the link.  Those seem to be the very thing I was looking for.
One of the things that happened on my 48 day trip, the 2 lights over the sink and stove became intermittent.
38 minutes ago, HDRider said:
Yes...that is what Oliver sent me a few months ago.  I like them better.  Bezel was difficult to twist off the first time but easy after that.  3 screws and slightly different hole pattern...NO MORE RIVETS...YAY!
Good luck
ALAKAZARCACOFLGAIDILINIAKSKYLAMEMDMAMIMN
These are the lights we replaced the lights over the sink and stove. It has a on/off button in the center, blue night light and dimmable light. Box of 4 so I have 2 more if the others fail.
We did have a problem with the one over the dinette. I removed the dome, and re-alligned the spring, and we have had no further issues. TheScreenshot_20250711-141140.thumb.png.9bb22ec5ab687b935ac08b060ce98a25.png key is just a light touch, not pushing on the dome.
Sounds like there are several good options - and - the failure of existing lights provides the opportunity to upgrade.
Life is good(?)
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
All this talk about touch lights and replacements made me reconsider making do with the stock fixtures. Currently installing two early arrivals and with one done, very pleased! I’ve always considered the lights to be too bright, especially over the dinette; sensitive eyes. Thinking that problem may be solved with these ones, dimmable cool white with a blue night light/ambiance feature. What think you?
Those look great! How was the installation and do they have a mechanical on/off switch or are they touch activated?
There is a touch sensitive control button in the center; touch to change colors, long touch to increase/decrease lighting. Can also be turned on/off by Master light switch to last setting(s). Simple install; a little larger diameter, but mounting holes were same. First install was above dinette, this second above the cooktop. I plan to install additional lights above each bed, over sink and maybe in wet bath under cabinet.
Edited by Ronbrink
So the wifey thought the light installed over the dinette was too dim, even though its brightest setting was 400 lumens. To maintain harmony, it was upgraded to the larger in this line of fixtures, 720 lumens. I hate it when she’s right! I can easily dim this light to my liking when dining and have an abundance of light when need be. I have since installed the larger size over each twin bed and two of the smaller in the ceiling; of which two of the four stock lights started failing over a year ago. Today I plan to replace the remaining ceiling and sink fixtures using the smaller to complete this project. Let there be light!
As before, the Ceiling switch controls the four lights in unison to their last settings; and the Master switch does the same for all of the lights. I remain undecided if the wet bath under cabinet light will be upgraded in like manner.
The fact that they turn on to their last setting may have sold me. I dislike that the master switch activates the touch lights. However, if they could adjust to a lower setting or turn on blue, that would be nice. I just don't like that when I don't want them on I have to go touch each one.
Todd & Kat
Install of the nine replacement lights in the main cabin DONE. The ‘cool white’ (blueish tint) vs the stock ‘warm white’ (yellowish tint) color temperature is so much brighter! Pics at full lumen and blue lighting:
Ilike that design. The bezel looks good and the slim profile is good too.
2023 Elite #1403--2019 Ford F150--2.7 Ecoboost V6--10 speed auto--without Max Tow
Can you provide a link to where you got them?
Or, a part number and the manufacturer?
They look great
Amazon purchases:
  • 2 months later...
Hi Ronbrink,
so when installing did you wire the black on the fixture to the red or yellow on your Ollie under the cabinet by the sink? How are the holding up? The look great and thinking about replacing mine as the cabinet under sink would not shut off one night middle of the night…
11 hours ago, Jjnps said:
Hi Ronbrink,
All of my lead wires were black/white, ceiling and under cabinet. In your situation, probably black to the red and white to the yellow; in my trailer yellow designates ground/neutral. These are quality lights and thus, expected to hold up well; no issues to date and so much easier to operate. The former lights were indeed frustrating, which lead me to do the total light replacement, no regrets!
I like that the holes are the same - keeps things clean.  On a different note, how do you like the ProBreeze Peltier dehumidfier?  How well does it bring down the rel humidity?
I used to carry the smaller version, but got the larger model that holds more condensate to keep from having to go to the COW Barn so often to empty when in storage; high RH is a thing in Clear Lake (Houston) being near the GOA coast! Several owners have these and are pleased with performance. Although still carried with when traveling, I no longer rely on it to control cabin humidity; my Cielo Breez Max a/c controller efficiently maintains a comfortable 40-50% average level in the Oliver at all times, whether in the Oliver for extended periods or away.
Edited by Ronbrink
  • 2 months later...
I got an Idea on how to fix the original lights that were failing.
First, I had 3 lights that went from randomly failing to one out of 10 times trying to turn it on the light my come on.  I played with the ones over the kitchen counter for 6 months trying to get them working better.   When the 3 light started failing  I decided to upgrade to the 7" and 3" white and blue lights for the touch lights.   As I was taking things apart I noticed that I could turn the light on/off every time by just touching the spring.  I also found that I could get within about .050 of an inch (just less than 1/16 of an inch) of the spring the light would turn On/Off every time.
After I finished installing the all of the new lights, I thought I would try something. I took the light that was failing the most, and drilled a 3/8 hole in the center of the cover. I put the cover back on the light and it looks ugly.   I thought If I could find a piece of metal button I could make it look nicer. Then I remembered I had a couple of 5/16 push on axle nuts/caps.  The axle cap fit perfect in my hole and I put the cap back on.   The cover looks like it was manufactured  like this.    I hooked the light up to 12V and tested it.  It works great.  Just like the light did with me touching the spring.  Not pushing required, just get real close or light touch on the axle cap.
This is a cheap and quick way to possible getting your lights functioning again.  You might try to use a 3/8 press on nut cap.  And drill the hole to 7/16 so the spring would set inside the axle nut instead of  on the flange of the cap.  Although you might not have enough spring pressure to have the spring tightly touching the nut.
BTW, I do like the new lights.  The 7" cool white (5000K)  model  is almost as bright as the originals, the 3 inch ones are dimmer.  We  chose to use the 3" one over the beds and kitchen table.
