wondering if anyone greased their hitch?
we have a 3/4 ton diesel so we no longer use the Anderson. Just  curious about everyone thoughts.
thanks Oliver 371
3 hours ago, Markmck said:
We have a 3/4 ton diesel so we no longer use the Anderson.
When not using the Anderson WDH, make sure you are also not using the Anderson hitch at all, meaning specifically the ball on the cone. Without the WDH boomerang piece bolted through the bottom, the ball is merely held in place by a snap ring which could fail allowing the cone and ball to come up and off.
With a standard ball it is common practice to grease it. Get a rubber cover for when detached before it soils your pant leg! Use any thick grease so it stays put. I use red wheel bearing grease since I have several tubes of it on hand.
Edited by jd1923
A little dab will do ya…https://www.amazon.com/Reese-Towpower  you can probably pick it up cheaper at a local auto parts store.
Edited by Patriot
I use some white lithium but to each their own. Here is a good video on it and he even calls out how the Anderson hitch is different than others.
Todd & Kat
Same here.
My preference:
1 hour ago, Ronbrink said:
My preference:
This is what we use😊
I bought 2 ball covers, but soon found the grease would still get on them. I ruined 2 pair of shorts.
My fix is a sealable sandwich bag, which can get a few uses before I replace it. I seal the bag and the grease keeps the bag from coming off will out and about.
I like that it is colorless, so no staining of clothes; to @jd1923’s point, use a ball cover! I like the CURT brand; standard 1-7/8” to 2” or 2-5/16” diameter ball sizes. I’m also a fan of the Mission Automotive dielectric grease, which I need more of when back in stock.
I had 2 of those hitch ball covers, but the grease gets all over them and me. There is no way to get off and back without exposed grease
I apply sparingly and never had that issue. It is a push and tug to put on and take off, respectively; as in air compression and suction actions!
We occasionally drink "Truleys" (a carbonated fruit flavored beer alternative) -- the cans are a perfect diameter to fit over the greased hitch ball.  Just cut off about 3.5" from the bottom of the can, place it over the ball and pinch the cut-edge below the ball to keep it from flying off when driving.  No more grease marks on your legs....
  • (SOLD) 2022 TUNDRA
