mountainoliver Posted August 9, 2025 Posted August 9, 2025 After 8 years of use it was time to retire the Dometic air conditioner. I have looked at several brands and for one reason or another I decided on the Tosot brand which is the same as the Atmos brand and probably others as well. Since last summer the Dometic has been making fan bearing noises off and on and I’ve grown tired of climbing on the roof to oil the motor. After eight years I really didn’t want to replace the motor only to have something else fail so this was an excellent excuse to replace it with a higher efficiency quiet unit. We’ve been traveling out west for the past three and a half months and were passing “close” to Elkhart Indiana so decided to drop in and visit the SDG folks. The entire replacement process was perfectly coordinated and our installer Joe knew exactly what needed to be done. We’ve camped out in their parking lot the night before with 30 amp shore power available. The next morning at 8:00 AM I backed our trailer into their shop and about two hours later the job was done. They even printed a custom cover plate to cover up the holes from the old Dometic thermostat. We were able to sleep through the night with the air conditioner running for the first time in 8 years without having to use earplugs, and to watch television at half volume instead of full volume! The air registers force air towards the front of the trailer instead of most all of the cold air being forced onto the bed area. We’re parked in central Ohio for a few days and it’s very hot and humid but the air conditioner is keeping the Oliver very dry and comfortable. On low fan the unit draws about 9 ac amps. Running from the inverter the inverter draws 94 dc amps. The Dometic on inverter would draw between 130 - 140 dc amps under similar conditions. We are extremely pleased with the work that SDG provided and with the comfort and efficiency of the Tosot unit. I strongly recommend the folks at SDG for the air conditioner replacement. They have done several Oliver air conditioner replacements and have experience in replacing/installing air conditioners on many different rv types. 5 5 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
dhaig Posted August 10, 2025 Posted August 10, 2025 Thanks for sharing your A/C replacement experience. The Tosot unit looks very attractive compared to the Dometic. Would you care to share the cost of the new unit plus installation? Thanks. Don 1 3 North Texas | 2022 LEII, Hull #990, delivered 2/17/22 | 2014 BMW X5 35d
mountainoliver Posted August 10, 2025 Author Posted August 10, 2025 Because of tariffs on imported goods and other variables it would be best to contact SDG in Elkhart directly for a quote. The Tosot air conditioners that I have seen online lately range from just under 2,000 to just over 2,000 plus shipping. There may be some dealers that offer the units for well below the above listed prices. 3 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Ronbrink Posted August 13, 2025 Posted August 13, 2025 On 8/9/2025 at 11:52 AM, mountainoliver said: We are extremely pleased with the work that SDG provided and with the comfort and efficiency of the Tosot unit. I am still amazed at the efficiency and cooling power of the Atmos and glad that SDG adopted the Tosot as an in-kind replacement unit due to tariff-related issues. I did not opt for the Cielo Max Breez thermostat being offered at the time of my purchase, even though it was widely used by SDG in their typical Class B RV installs. I have since added this device and find it extremely beneficial in energy savings, comfort and humidity control. If you didn’t opt for the Cielo with this a/c upgrade I would highly recommend adding one, you won’t be disappointed! I think it is also worth mentioning that these 15K units are far superior to the DPll 11K formerly in my OLEll, which was often found marginal at times during extreme heat conditions here in Texas. I was really disappointed to learn after initial purchase that Oliver began putting this smaller unit in the 2020 year model and thus, always my intent to upgrade to a bigger and better unit. No regrets in my choice and certain you will feel the same! 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
mountainoliver Posted August 13, 2025 Author Posted August 13, 2025 I really like the unit so far. A little disappointed with the owners manual however. They tell us about certain features but they don’t describe exactly what they do. Curious about Xfan function and I can’t tell the difference between air conditioning and the dehumidifier function. The Cielo thermostat was not mentioned to me but I did notice that SDG had one on the wall in the office area! After using the new unit for about a week now in high humidity I’m really thinking about adding the Cielo thermostat. 4 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
mountainoliver Posted August 13, 2025 Author Posted August 13, 2025 The old Dometic unit was 13,500 BTU, still last year for example, in the southern Arizona desert we were camped in 115 degree weather. The Dometic ran continuously all day from mid morning until late afternoon. If the temperature dropped to the upper 90’s the unit seemed to be able to cycle off and on but close to and over 100 it would not cycle off while maintaining about 75 degrees in the camper. I question buying an air conditioner smaller than 13,000 BTU unless you never plan on camping in the summer or later on selling it to someone who never wants to camp in the summer. Maybe my old unit was having other issues as well, who knows. 4 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Moderators mossemi Posted August 14, 2025 Moderators Posted August 14, 2025 @mountainoliver Was SDG able to utilize the Oliver’s internal condensate drain system? Mossey 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
mountainoliver Posted August 14, 2025 Author Posted August 14, 2025 No, the internal drain system was abandoned. The condensation now just runs off of the roof. 1 1 2 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Ronbrink Posted August 14, 2025 Posted August 14, 2025 (edited) 21 hours ago, mountainoliver said: Curious about Xfan function and I can’t tell the difference between air conditioning and the dehumidifier function. Agree, but understand the owner manuals are universal and state that some units may not have all of the features described. For example: “X-FAN function is only available on some models.” Furthermore, typical air conditioning is the Cool Mode setting wherein the compressor will regularly cycle to maintain a desired temperature and the supply fan runs continuously, which causes humidity spikes when the compressor shuts down periodically. In Dry Mode the compressor runs continuously for the sole purpose of condensing moisture-laden air to reduce humidity. Yes, this mode will chill the air much like Cool Mode, but since the compressor is set to run for a prolonged period the temp and humidity will continue to drop to such a point that it exceeds its function and thus, should then be turned off and the unit switched back to Cool Mode. Before Cielo, I had to use the Dry Mode to buffer occasional humidity spikes during the day, but when asleep at night I would often wakeup to extreme humidity levels at morning. The Cileo’s ‘Comfy Mode’ solved these dreaded humidity occurrences, both day and night! Edited August 14, 2025 by Ronbrink 4 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted August 14, 2025 Posted August 14, 2025 2 hours ago, mountainoliver said: No, the internal drain system was abandoned. The condensation now just runs off of the roof. This may be of concern to some, but we no longer have to worry about clogged condensate drain lines or drip pans causing leaks inside our units, which both Dometic and Truma owners have experienced. After a year of use, I find no issue with the roof runoff. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted August 14, 2025 Posted August 14, 2025 8 minutes ago, Ronbrink said: This may be of concern to some, but we no longer have to worry about clogged condensate drain lines or drip pans causing leaks inside our units, which both Dometic and Truma owners have experienced. After a year of use, I find no issue with the roof runoff. 3 years in and zero issues with the Truma Aventa condensate lines clogging here. We just make sure that our trailer is dead level and all is good. 😊 As I recall I never had issues with the “Demonic AC” either. 🤔 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Ronbrink Posted August 14, 2025 Posted August 14, 2025 2 minutes ago, Patriot said: 3 years in and zero issues with the Truma Aventa condensate lines clogging here. We just make sure that our trailer is dead level and all is good. 😊 As I recall I never had issues with the “Demonic AC” either. 🤔 Understood, I never had a leak issue with my Dometic either nor too concerned about being “dead level”. Some however, have not been as lucky! 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted August 14, 2025 Posted August 14, 2025 (edited) 2 minutes ago, Ronbrink said: Understood, I never had a leak issue with my Dometic either nor too concerned about being “dead level”. Some however, have not been as lucky! Ron, you mean Demonic Penguin? 😄 That’s what I use to call that loud jet engine…lol. Sold my old Demonic to a guy with a food truck for $600 after hauling it back from Oliver post Truma install. Edited August 14, 2025 by Patriot 1 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Ronbrink Posted August 14, 2025 Posted August 14, 2025 5 minutes ago, Patriot said: Ron, you mean Demonic Penguin? 😄 That’s what I use to call that loud jet engine…lol. Sold my old Demonic to a guy with a food truck for $600 after hauling it back from Oliver post Truma install. I like your play on words, “Demonic” indeed! Sold my DPll 11K for $600 as well on FB Marketplace in short order. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
mountainoliver Posted August 27, 2025 Author Posted August 27, 2025 Concerning the difference between cool mode and dry mode. I have run the unit in dry mode for days on end with the trailer in my driveway. We’ve had multiple 90 degree days with high humidity and by setting the temperature a little bit higher than in cool mode the trailer was kept very comfortable. The only difference (according to the Tosot customer service folks) between cool mode and dry mode is that in dry mode the fan only runs on low. Maybe the on cycle is a little bit longer, I’ve not been able to tell the difference. Everything else is the same. Since we tend to run the fan on low 99% of the time anyway, dry mode really works great for keeping the trailer cool and dry. I probably will only use cool mode to initially get a hot trailer cool using high or turbo fan mode and then switch to dry mode for the rest of the time. It’s interesting to note that the specific temperature settings for any particular mode are remembered as you cycle through the different modes. Anyway, learning as we go. 3 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Ronbrink Posted August 28, 2025 Posted August 28, 2025 (edited) 22 hours ago, mountainoliver said: Concerning the difference between cool mode and dry mode. In general, Cool Mode prioritizes temperature whereas Dry Mode humidity. The Cielo Max Breez thermostat effectively and efficiently regulates these two factors and thus, no need to toggle back and forth between modes for optimum comfort with respect to variances in weather conditions (temperature/relative humidity). Edited August 28, 2025 by Ronbrink 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Pat Radack Posted September 10, 2025 Posted September 10, 2025 Perhaps I am missing something; I am an extreme newbie. Are these replacement A/C units, TOSOT and ATMOS, 120VAC units? Has anyone discussed or considered 12 VDC units? Sorry if this is dumb or already been discussed. working on signature too! Suggestions? Pat and Amy Radack Hull # 1189 - 2022 LEII, Twin, Lit Pro Pack, Out Pro Pack, Convection Microwave, Composting Toilet, Truma Aquago, Cradlepoint WAN, Added Truma A/C w/ CP Plus, Midea 20 pint, Foibles. Black 2019 RAM 2500, Cummins 6.7L, Limited, Crew Cab, 4 x 4, 6’ bed w/Rambox 2019 RAM 2500 Limited 4x4 Crew Cab Black. Hull # 1189 Pat and Amy
jd1923 Posted September 10, 2025 Posted September 10, 2025 1 hour ago, Pat Radack said: Are these replacement A/C units, TOSOT and ATMOS, 120VAC units? Has anyone discussed or considered 12 VDC units? Yes 120VAC, and so are the inverter-compressor models like the Turbro Greenland and Pioneer. 12VDC requires running new heavy gauge wire from batteries to the A/C location on the roof since the amperage draw of 12VDC is 10x more than when running on 120VAC. Therefore, 12VDC models are generally light-duty with BTU ratings under 10K vs. 13.5 to 15K BTU that is required for living and camping in most of the USA! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Pat Radack Posted September 11, 2025 Posted September 11, 2025 Thank you. The desire to boondock without the inefficency of a generator is appealing. There is a 13.5K BTU unit. What do you suppose the easy of the path and the distance of the much heavier gauge wire would be? The unit comes with either a 10' or 15' cable. 2019 RAM 2500 Limited 4x4 Crew Cab Black. Hull # 1189 Pat and Amy
jd1923 Posted September 11, 2025 Posted September 11, 2025 30 minutes ago, Pat Radack said: What do you suppose the easy of the path and the distance of the much heavier gauge wire would be? The unit comes with either a 10' or 15' cable. No easy path! 🤣 The outer and interior shells of the Oliver are tight and in-between, lot'sa luck in doing so. Many have asked, but nobody on this forum has demonstrated a viable build. Perhaps it's an idea that does not have a feasible solution. IMO, drop the idea. In the same vain, I wonder why some want an inferior 12V television, when with LiFePO4 batteries an inverter can simply run an 120VAC TV. 12V TVs have limited selection and truly lame resolution. Instead I prefer to run a 4K high-def Samsung monitor, 3/4" thin white and beautiful on 120VAC. IMHO... 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Pat Radack Posted September 12, 2025 Posted September 12, 2025 I think I understand. Perhaps it is time to think about a 12 - 24 - 48 VDC unit that rates at 11K BTU and also heats at 4500 BTU. If you care so much less about heating, what could you do with the space once the existing heater is removed. Surely the 8 AWG couldn't be that hard. A second DC bus bar and a lot fewer Ah for under $1K material. Pipe dream or a new package for Oliver Boondockers... Thoughts? 2019 RAM 2500 Limited 4x4 Crew Cab Black. Hull # 1189 Pat and Amy
Ronbrink Posted September 12, 2025 Posted September 12, 2025 10 hours ago, Pat Radack said: I think I understand. Perhaps it is time to think about a 12 - 24 - 48 VDC unit that rates at 11K BTU and also heats at 4500 BTU. If you care so much less about heating, what could you do with the space once the existing heater is removed. Surely the 8 AWG couldn't be that hard. A second DC bus bar and a lot fewer Ah for under $1K material. Pipe dream or a new package for Oliver Boondockers... Thoughts? I found the 11K Dometic Penguin ll, originally installed in my 2020 OLEll, to be lacking in cooling efficiency with our Texas heat; a 15K replacement proved to be a better unit for my needs. If you don’t plan to camp in extreme heat or cold, perhaps an 11K/4500 BTU unit will suffice, but why limit yourself? Regardless of action taken, having the existing heater for backup may be a better plan over removal. With regards to installing a DC unit, you may first want to try to fish a path for the larger wires required before making that investment. Also, one would think a larger battery bank and even max solar necessary for this “new package for Oliver Boondockers”; added cost that doesn’t seem to be factored into the equation. Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Geronimo John Posted November 29, 2025 Posted November 29, 2025 (edited) On 8/28/2025 at 3:39 AM, Ronbrink said: In general, Cool Mode prioritizes temperature whereas Dry Mode humidity. The Cielo Max Breez thermostat effectively and efficiently regulates these two factors and thus, no need to toggle back and forth between modes for optimum comfort with respect to variances in weather conditions (temperature/relative humidity). For those with an older technology (Not Inverter) I seem to have understood that the Cielo would just shut down the power to the unit in the mode when humidity "give back" from the Evaporor Coil is an issue. But if you have more recent design (Inverter A/C), the Cielo independently controls the (Inverter (Compressor Speed), Condensor Fan, and the Supply Air Fans) to meet what ever humidity and temperature settings are needed. Is the above done by the same model of Cielo or different ones? How does it do so for both types of unit when they all likely have different mother boards? Almost sounds too good to be real. But so many of us really like what it does it must be magic! GJ Edited November 29, 2025 by Geronimo John 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted November 29, 2025 Posted November 29, 2025 (edited) On 9/12/2025 at 2:57 AM, Ronbrink said: I found the 11K Dometic Penguin ll, originally installed in my 2020 OLEll, to be lacking in cooling efficiency with our Texas heat; a 15K replacement proved to be a better unit for my needs. From a M.E. perspective the smaller unit was intended to run longer than the 13.5 units thereby better controlling humidity and pulling less power. A good thing. But it gives up high temperature condition performace (ability to reach set point) and cool down time as trade offs... as you well know. Pretty much of that logic line goes out the window with the advent of the Inverter units. They can cycle output down/up as needed for all applications under those for which they are not undersized. They control both humidity and temperature to set point. Brilliant! I suspect that OTT will be going that direction once there is a bit more experience with them and the reliability issues, good and bad, shake out. That's part of their good conservative approact to significant changes I think. As the inverter refergerator topic continues to matue, I'll be looking at the owner opinions in a couple more seasons as my Dometic 3-way ages and my confidence in the air separation from the cabin and the refer side deteriorates. Likewise with the inverter A/C units. Wish the Houghton was an inverter, but it's not. Lucky that I and others were able to do the two Mods. So I'll likely hold off an A/C upgrade to let this topic mature. Especially if the Ceilo would work well on it! I appreciate all the Owner inputs about the Cielo system and their experiences using it. GJ Edited November 29, 2025 by Geronimo John 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Ronbrink Posted November 30, 2025 Posted November 30, 2025 (edited) On 11/28/2025 at 8:31 PM, Geronimo John said: For those with an older technology (Not Inverter) I seem to have understood that the Cielo would just shut down the power to the unit in the mode when humidity "give back" from the Evaporor Coil is an issue. But if you have more recent design (Inverter A/C), the Cielo independently controls the (Inverter (Compressor Speed), Condensor Fan, and the Supply Air Fans) to meet what ever humidity and temperature settings are needed. Is the above done by the same model of Cielo or different ones? How does it do so for both types of unit when they all likely have different mother boards? Almost sounds too good to be real. But so many of us really like what it does it must be magic! GJ I’m not aware of any Oliver owners applying the Cielo to an inverter a/c install, but reference was made in the below post that those units do not have variable speed air supply fans and the Cielo may provide benefit. I do know that the Cielo thermostats are primarily marketed for mini-split units, many of which use inverter technology. As for your questions, TBD! Installing Pioneer Inverter AC By Treasure Coast Vault June 3 in Ollie Modifications Edited November 30, 2025 by Ronbrink Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
