mountainoliver Posted August 9 Posted August 9 After 8 years of use it was time to retire the Dometic air conditioner. I have looked at several brands and for one reason or another I decided on the Tosot brand which is the same as the Atmos brand and probably others as well. Since last summer the Dometic has been making fan bearing noises off and on and I’ve grown tired of climbing on the roof to oil the motor. After eight years I really didn’t want to replace the motor only to have something else fail so this was an excellent excuse to replace it with a higher efficiency quiet unit. We’ve been traveling out west for the past three and a half months and were passing “close” to Elkhart Indiana so decided to drop in and visit the SDG folks. The entire replacement process was perfectly coordinated and our installer Joe knew exactly what needed to be done. We’ve camped out in their parking lot the night before with 30 amp shore power available. The next morning at 8:00 AM I backed our trailer into their shop and about two hours later the job was done. They even printed a custom cover plate to cover up the holes from the old Dometic thermostat. We were able to sleep through the night with the air conditioner running for the first time in 8 years without having to use earplugs, and to watch television at half volume instead of full volume! The air registers force air towards the front of the trailer instead of most all of the cold air being forced onto the bed area. We’re parked in central Ohio for a few days and it’s very hot and humid but the air conditioner is keeping the Oliver very dry and comfortable. On low fan the unit draws about 9 ac amps. Running from the inverter the inverter draws 94 dc amps. The Dometic on inverter would draw between 130 - 140 dc amps under similar conditions. We are extremely pleased with the work that SDG provided and with the comfort and efficiency of the Tosot unit. I strongly recommend the folks at SDG for the air conditioner replacement. They have done several Oliver air conditioner replacements and have experience in replacing/installing air conditioners on many different rv types. 5 3 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
dhaig Posted Sunday at 12:57 AM Posted Sunday at 12:57 AM Thanks for sharing your A/C replacement experience. The Tosot unit looks very attractive compared to the Dometic. Would you care to share the cost of the new unit plus installation? Thanks. Don 1 3 North Texas | 2022 LEII, Hull #990, delivered 2/17/22 | 2014 BMW X5 35d
mountainoliver Posted Sunday at 02:16 AM Author Posted Sunday at 02:16 AM Because of tariffs on imported goods and other variables it would be best to contact SDG in Elkhart directly for a quote. The Tosot air conditioners that I have seen online lately range from just under 2,000 to just over 2,000 plus shipping. There may be some dealers that offer the units for well below the above listed prices. 3 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Ronbrink Posted Wednesday at 01:54 PM Posted Wednesday at 01:54 PM On 8/9/2025 at 11:52 AM, mountainoliver said: We are extremely pleased with the work that SDG provided and with the comfort and efficiency of the Tosot unit. I am still amazed at the efficiency and cooling power of the Atmos and glad that SDG adopted the Tosot as an in-kind replacement unit due to tariff-related issues. I did not opt for the Cielo Max Breez thermostat being offered at the time of my purchase, even though it was widely used by SDG in their typical Class B RV installs. I have since added this device and find it extremely beneficial in energy savings, comfort and humidity control. If you didn’t opt for the Cielo with this a/c upgrade I would highly recommend adding one, you won’t be disappointed! I think it is also worth mentioning that these 15K units are far superior to the DPll 11K formerly in my OLEll, which was often found marginal at times during extreme heat conditions here in Texas. I was really disappointed to learn after initial purchase that Oliver began putting this smaller unit in the 2020 year model and thus, always my intent to upgrade to a bigger and better unit. No regrets in my choice and certain you will feel the same! 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
mountainoliver Posted Wednesday at 04:24 PM Author Posted Wednesday at 04:24 PM I really like the unit so far. A little disappointed with the owners manual however. They tell us about certain features but they don’t describe exactly what they do. Curious about Xfan function and I can’t tell the difference between air conditioning and the dehumidifier function. The Cielo thermostat was not mentioned to me but I did notice that SDG had one on the wall in the office area! After using the new unit for about a week now in high humidity I’m really thinking about adding the Cielo thermostat. 3 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
mountainoliver Posted Wednesday at 09:14 PM Author Posted Wednesday at 09:14 PM The old Dometic unit was 13,500 BTU, still last year for example, in the southern Arizona desert we were camped in 115 degree weather. The Dometic ran continuously all day from mid morning until late afternoon. If the temperature dropped to the upper 90’s the unit seemed to be able to cycle off and on but close to and over 100 it would not cycle off while maintaining about 75 degrees in the camper. I question buying an air conditioner smaller than 13,000 BTU unless you never plan on camping in the summer or later on selling it to someone who never wants to camp in the summer. Maybe my old unit was having other issues as well, who knows. 4 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Moderators mossemi Posted yesterday at 04:19 AM Moderators Posted yesterday at 04:19 AM @mountainoliver Was SDG able to utilize the Oliver’s internal condensate drain system? Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
mountainoliver Posted yesterday at 10:25 AM Author Posted yesterday at 10:25 AM No, the internal drain system was abandoned. The condensation now just runs off of the roof. 1 2 2017 Elite II, Hull #208 2019 Chevy HD 2500 Duramax
Ronbrink Posted yesterday at 12:59 PM Posted yesterday at 12:59 PM (edited) 21 hours ago, mountainoliver said: Curious about Xfan function and I can’t tell the difference between air conditioning and the dehumidifier function. Agree, but understand the owner manuals are universal and state that some units may not have all of the features described. For example: “X-FAN function is only available on some models.” Furthermore, typical air conditioning is the Cool Mode setting wherein the compressor will regularly cycle to maintain a desired temperature and the supply fan runs continuously, which causes humidity spikes when the compressor shuts down periodically. In Dry Mode the compressor runs continuously for the sole purpose of condensing moisture-laden air to reduce humidity. Yes, this mode will chill the air much like Cool Mode, but since the compressor is set to run for a prolonged period the temp and humidity will continue to drop to such a point that it exceeds its function and thus, should then be turned off and the unit switched back to Cool Mode. Before Cielo, I had to use the Dry Mode to buffer occasional humidity spikes during the day, but when asleep at night I would often wakeup to extreme humidity levels at morning. The Cileo’s ‘Comfy Mode’ solved these dreaded humidity occurrences, both day and night! Edited yesterday at 01:25 PM by Ronbrink 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Ronbrink Posted yesterday at 01:22 PM Posted yesterday at 01:22 PM 2 hours ago, mountainoliver said: No, the internal drain system was abandoned. The condensation now just runs off of the roof. This may be of concern to some, but we no longer have to worry about clogged condensate drain lines or drip pans causing leaks inside our units, which both Dometic and Truma owners have experienced. After a year of use, I find no issue with the roof runoff. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted yesterday at 01:35 PM Posted yesterday at 01:35 PM 8 minutes ago, Ronbrink said: This may be of concern to some, but we no longer have to worry about clogged condensate drain lines or drip pans causing leaks inside our units, which both Dometic and Truma owners have experienced. After a year of use, I find no issue with the roof runoff. 3 years in and zero issues with the Truma Aventa condensate lines clogging here. We just make sure that our trailer is dead level and all is good. 😊 As I recall I never had issues with the “Demonic AC” either. 🤔 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Ronbrink Posted yesterday at 01:53 PM Posted yesterday at 01:53 PM 2 minutes ago, Patriot said: 3 years in and zero issues with the Truma Aventa condensate lines clogging here. We just make sure that our trailer is dead level and all is good. 😊 As I recall I never had issues with the “Demonic AC” either. 🤔 Understood, I never had a leak issue with my Dometic either nor too concerned about being “dead level”. Some however, have not been as lucky! 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Patriot Posted yesterday at 01:55 PM Posted yesterday at 01:55 PM (edited) 2 minutes ago, Ronbrink said: Understood, I never had a leak issue with my Dometic either nor too concerned about being “dead level”. Some however, have not been as lucky! Ron, you mean Demonic Penguin? 😄 That’s what I use to call that loud jet engine…lol. Sold my old Demonic to a guy with a food truck for $600 after hauling it back from Oliver post Truma install. Edited yesterday at 01:56 PM by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Ronbrink Posted yesterday at 02:07 PM Posted yesterday at 02:07 PM 5 minutes ago, Patriot said: Ron, you mean Demonic Penguin? 😄 That’s what I use to call that loud jet engine…lol. Sold my old Demonic to a guy with a food truck for $600 after hauling it back from Oliver post Truma install. I like your play on words, “Demonic” indeed! Sold my DPll 11K for $600 as well on FB Marketplace in short order. 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
