When I greased my trailer the other day, I noticed that all of the bushings on the Monroe struts were cracked.  I am wondering if I should replace the struts or just the bushings. Has anyone else seen this?
2021 Elite II Twin Bed Hull #1023 - Kimba  | 2025 Ford F-350 6.7 Diesel
I would replace the entire shock. The cost of the shocks was not that much and I expect yours are pretty well worn out. I replaced mine on my 2020 trailer about two years ago and what a difference it made.
2019 Ram 1500 5.7L V8, 3.92 axle ratio - 2020 LEll - Hull676
23 minutes ago, Steph and Dud B said:
There's a couple of threads talking about alternatives to the Monroes.
HERE is just ones of those posts on the subject of alternative(s) to the Monroe shocks.
THIS thread directly applies to the bushing question - particularly see the last post regarding the appropriate amount of "bluge" .
p.s.  by typing in "Monroe Shocks" the Forum's search function will return more information of the subject of shocks in general.
Edited by topgun2
added detail
Thanks everyone for your responses.  I tried searching but didn't use the right key words. The other posts are very helpful..
3 hours ago, Roger said:
Get 4 new shocks and you may want to go Bulldog brand vs. Monroe.
https://www.oreillyauto.com/detail/c/bulldog-hd-suspension/bulldog-hd-suspension-shock-absorber/bul0/hd12130656/
https://www.4statetrucks.com/bulldog-hd-shock-absorber-replaces-555001-19-050000007
From what I can tell in your picture, the upper bushings on the original shocks were badly over-tightened causing the rubber bushings to fail prematurely. Your picture shows too many threads up top leaving very little spacing for the rubber. You want to tighten these so that the rubber is just mushrooming and not much more.
Roger:
I note the amount of corrosion in your picture.   I don't know where you live or operate, but for a 2021 trailer it could use some corrosion control efforts.  Especially the axle tube.
