jd1923 Posted June 21 Posted June 21 "The Ugly Duckling is a fairy tale by Hans Christian Andersen about a duckling who is rejected by his siblings due to his unusual appearance. After enduring hardship and loneliness, he matures into a beautiful swan, illustrating the theme that true beauty comes from within and that one should not be judged by outward appearances.” We were fortunate to find our Oliver three years ago for sale right in our neighborhood! And at the time, we had no idea what an Oliver is and what makes it special! It didn’t take long though, since just 5 days after we first viewed our Oliver was paid in full, so the prior owner delivered it to our home on June 7th 2023. This day is also Chris’ birthday and what a special surprise it was. Chris loves every time we get away in our Oliver, and me too! I generally buy used vehicles in good condition, letting the original owner absorb the new-price depreciation. I enjoy fixin’ them up, making them as good as new and better, making them mine! From the start, I had planned on making repairs, mods and upgrades with a budget an additional $15,000, just for parts. With good patience, ample time and craftsmanship she could become something special! Hull #113 was well cared for; prior owners kept her clean and often kept her covered. She returned to the factory in 2018 and 2021 for maintenance and other services; new white blinds, new Atwood furnace and much more. Also in 2021, she moved from Florida to Las Vegas and was ceramic coated at the time. Always from the South and SW has kept corrosion at bay. Good records were kept and we are now the 4th owners. She looked good when we first got her and everything was in working order. 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted June 21 Author Posted June 21 It didn’t take long, parked outdoors in the Arizona sun, to become a dull pasty white! She started with four 6V lead acid batteries, an old 2KW Xantrex inverter only with PD converter in the power panel. She had wires all over the battery bay and everywhere else for that matter, fuses and breakers under beds, manual water valves and the mess it was born with spread out into every corner of the basement. And it had old-tech accessories; the cameras fore and aft, a WiFi Ranger, Dish satellite and that awful Dometic P2! All that has been corrected and improved with a lot of Marine-Tex used to fill nearly 100 holes! And what a silicone mess that OTT started at the factory and some owners believe caulk on top of old caulk is proper maintenance! In the two years from 2024 to 2025 I rebuilt almost every electrical, mechanical and plumbing system in our 10-year-old Oliver Travel Trailer. It’s been a lot of work, but our Oliver is worth it! I plan to enter another post to chronical all my repair and modification work but here we’ll focus on its cosmetic restoration. The finale was to dress up our Ugly Duckling. Not merely gelcoat buffing and ceramic coating, but a complete exterior body restoration! 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted June 21 Author Posted June 21 (edited) I wanted the final outcome to far surpass the large investment in stripping, cleaning, buffing and ceramic coating. This meant a whole lot of extra work. I’m not the guy who hires the guy, drop it off and they will handle everything. Shops only do what they’re paid to do. I wanted to do everything I could do to make the final result far better. My first step was to remove all the awful silicone caulk. What mess as you can see in the first picture. Then I went around the entire hull leaving piles of old caulk along the driveway. This extra work was truly worth the effort. I also removed every trim part, outlet covers, awning mounts, the covers to the furnace and HWH, the handles, latches and hatch on the doghouse, the door hook (no longer needed with Lippert friction hinges), the cameras fore and aft I’ve never used and all the old-tech like the WiFi Ranger and the monster rooftop satellite dish! This way, my detailer had a wide-open canvas to focus on stripping, cleaning, buffing, polishing and ceramic coating without a lot of stuff being in the way! Edited June 27 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted June 21 Author Posted June 21 An autobody professional I’ve used before suggested a local guy who runs a detailing shop at the far end of Chino Valley, the town north of Prescott. Cameron came by our home, looked over the Oliver carefully, at every angle. He explained what he would do and gave me a reasonable quote. We picked a start date and shook hands. He asked for 2 weeks, so he could work on our Oliver along with other scheduled work. When 2 weeks had come, he asked another two days to “to really get her right!” She was a thing of beauty, in that every square inch of the hull was shining so brightly! We have never seen our hull in this amazing condition. While Cameron was working on the shine, I was working on restoring or replacing all the trim parts. I painted the fridge vents, the furnace and HWH covers a medium gray to match the Oliver graphics and the gray on our truck. 1 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted June 21 Author Posted June 21 I had removed the Dometic Penguin A/C prior to this work. I temporarily filled the 14x14” opening with a piece of plywood to keep dust out while allowing Cameron the room above to make the entire rear roof shine! It’s always a mess under an old A/C. Good thing we did because the new Chill Cube is a foot shorter to the rear. With my son’s help, we installed the new Furrion Chill Cube A/C. One last task was to restore the rear bumper area. I removed the mounts for the bicycle rack we don’t use, drilled out more rivets and removed the deck plate and folding bumper. I cleaned the inside waste hose area, and steel brushed, sanded and ceramic coated all parts. I've been wanting to write this up for a few months now. Chris is out of town on her annual "Sisters Trip." Adam's been working overtime and it's boring being home alone. That’s it – she’s all done! 😎 When it's time for some love again, I'll drop her off with Cameron for a renewal! No more Ugly Duckling, but quite the Beautiful Swan she is now! 9 1 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
ScottyGS Posted June 21 Posted June 21 John, Thanks for posting this! Our trailer (#145) came off the line in June of 2016. Oliver at that time was making about 2 per week so I am thinking the delivery date on #113 was sometime in February of that year. I've been proud to own her for ten years now and lucky to be able to store indoors for most of that. I have the satellite dish installed and appreciate the pictures of it's removal. I think it would be awesome to pull the guts out of it and put a Starlink Mini in there but that kind of work is way above my pay grade. What did you replace yours with? Looks like a smaller more angular version of the dish cover. I am sure it attracts less bugs that the original. I've had conversations with Oliver management about answering price objections with a "cost of ownership" vs. purchase price strategy. Your work on this trailer is a poster child for that. Ten year old trailer that, at least in my opinion, is better than new. When people talk about their automatic awnings and other new stuff, I like to bring up mirrored cabinet doors and Lonseal flooring. Thanks again for all the pics and sharing your work. Hope our paths cross in the future. Scotty 1 Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - 2016 Hull # 145 2024 Nissan Titan XD - Western NC
Tom and Doreen Posted June 21 Posted June 21 John, what an absolutely amazing job! It 'looks like' an Oliver but it's so much more now than that you've made improvements to all aspect of the trailer. I don't know if you follow the YouTube channel Dave's Auto Center but you could be the "Dave" of the Oliver world! 1 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
Moderators Mike and Carol Posted June 21 Moderators Posted June 21 Looks great! 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
ScottyGS Posted June 21 Posted June 21 Another thought.... I know that Oliver is focused on selling new trailers... That's where their marketing is directed. But... How many of us remember the reason for the name "Legacy Elite". It's because this is a trailer that will endure. That you could hand down in your family over generations. JD's trailer is a perfect example of this. Oliver should feature this trailer in it's ads. TEN Years and still going strong! That's a story that shows the advantage of cost of ownership vs. purchase price. Good Job JD! 3 1 Gregg & Donna Scott and Missy the Westie - The Flying Sea Turtle - 2016 Hull # 145 2024 Nissan Titan XD - Western NC
jd1923 Posted June 21 Author Posted June 21 5 hours ago, ScottyGS said: John, Thanks for posting this! Our trailer (#145) came off the line in June of 2016. I have the satellite dish installed and appreciate the pictures of it's removal. What did you replace yours with? "cost of ownership" vs. purchase price strategy. Your work on this trailer is a poster child for that. Ten-year-old trailer that, at least in my opinion, is better than new. Thanks again for all the pics and sharing your work. Hope our paths cross in the future. Scotty Just 4 days after our Oliver was delivered, I joined our great OTT Forum. My two favorite sections are "Where's Ollie" and "Ollie Modifications" where I frequent often! Early on, Bill @topgun2 referred to our hulls as "cousins" (our #113 and his #117). There are a lot of us with 2016 and older Olivers. These 10+ year-old Olivers have had nothing but special care through the years. I hear Scotty is just starting a renewal project of his own! You wrote "cost of ownership" vs. purchase price." As written above, I had budgeted 15,000 for upgrades (plus 1000 +/- hours in sweat equity) in addition to a very good used price for the hull. My detailed spreadsheet has documented a total of $16,120, so I'm a little over budget. This includes new D52 axles with Alcan Springs, 5 Victron devices, 900 Ah Epoch Essentials, new Chill Cube A/C and so many other documented upgrades. It includes an Emeril Air Fryer, new luxury bedding, new custom upholstered dinette seat cushions, additional shelving, multiple exhaust fans, etc. It includes every bracket, roll of tape, every nut and bolt I used in the last 3 years. I figure our cost of ownership, everything included, is 70% of the cost of a fully optioned new Oliver. Wouldn't trade her for a new Oliver, no way! I've made better choices in our upgrades, and I do better work than the contract installers OTT hires. Then there's the little things like this for example: Yeah, couldn't wait to ditch the dish! That thing was HUGE! I put a Winegard RZ-7500 TV antenna in its place (using 3M VHB tape, NO screw holes). It still appears to be large, but it's actually less than half the size of the Dish! As far as Starlink, I have that and our Pepwave cellular router built into the tow vehicle instead, so it's always with us while camping and on day trips. Picture shows the front roof completed, but before the detailing work. I hate caulking and I'm not good at it. I made a mess with Dicor caulk, not using that product again! But it looks great from the ground! 🤣 And no more useless Wi-Fi Ranger and cameras up top. Yes, the older hulls have some bonuses, some you mentioned, and the little things like separate switches for Entry and Side Porch lights (ours now have lights fore and aft too). Oliver Hull #113 is a family member. Our son Adam got to know her, camping the month of April around the Prescott NF. She will always be with us. 😎 5 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Martin White Posted July 6 Posted July 6 On 6/20/2026 at 10:09 PM, jd1923 said: I had removed the Dometic Penguin A/C prior to this work. I temporarily filled the 14x14” opening with a piece of plywood to keep dust out while allowing Cameron the room above to make the entire rear roof shine! It’s always a mess under an old A/C. Good thing we did because the new Chill Cube is a foot shorter to the rear. With my son’s help, we installed the new Furrion Chill Cube A/C. One last task was to restore the rear bumper area. I removed the mounts for the bicycle rack we don’t use, drilled out more rivets and removed the deck plate and folding bumper. I cleaned the inside waste hose area, and steel brushed, sanded and ceramic coated all parts. I've been wanting to write this up for a few months now. Chris is out of town on her annual "Sisters Trip." Adam's been working overtime and it's boring being home alone. That’s it – she’s all done! 😎 When it's time for some love again, I'll drop her off with Cameron for a renewal! No more Ugly Duckling, but quite the Beautiful Swan she is now! Wow. I am truly impressed. We just bought our 2019 Oliver E2. I am thinking I will have it cleaned and new coating next year. Had to replace the water backflow valve and my heater won’t ignite. Thinking it may need new sail switch. We love it. Thanks. Martin & Linda 2 1
jd1923 Posted July 7 Author Posted July 7 10 hours ago, Martin White said: Wow. I am truly impressed. We just bought our 2019 Oliver E2. I am thinking I will have it cleaned and new coating next year. Had to replace the water backflow valve and my heater won’t ignite. Thinking it may need new sail switch. We love it. Thanks. Martin & Linda Thank you very much, Martin & Linda! New Oliver and new Forum Members for a month now - Congratulations! 😂 A lot like us 3 years ago. Our 2016 was 7 years old at the time as your 2019 is today. Keep working your required maintenance, fix or mod your top-of-list items and very soon enjoy some travel and good camping! 😎 We keep improving our Oliver way-of-life with several major modifications and all the many little things, while getting away 180 overnights so far! This cosmetic restoration and our new Chill Cube A/C were our last big projects. Please add a simple forum signature when you get a chance. Search here and ask questions re your "heater" (furnace or HWH?). You may be on the right track thinking "sail switch" but of course first make sure you're getting LP and 12VDC. Welcome, thanks again and best wishes, JD 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted Tuesday at 03:34 PM Moderators Posted Tuesday at 03:34 PM 20 hours ago, Martin White said: Wow. I am truly impressed. We just bought our 2019 Oliver E2. I am thinking I will have it cleaned and new coating next year. Had to replace the water backflow valve and my heater won’t ignite. Thinking it may need new sail switch. We love it. Glad you’re enjoying your “vintage” Oliver! Over time, you’ll be replacing and upgrading items as they wear out. There are a couple of backflow valves to watch, the one at the back of the trailer and one on the black tank flush line. The sail switch is one thing I’ve never done, our furnace keeps chugging away. The front cover did fall off once creating lots of heat under the bed but nothing coming out of the vents! Keep us posted on your maintenance and upgrades - Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Martin White Posted Tuesday at 05:50 PM Posted Tuesday at 05:50 PM 10 hours ago, jd1923 said: Thank you very much, Martin & Linda! New Oliver and new Forum Members for a month now - Congratulations! 😂 A lot like us 3 years ago. Our 2016 was 7 years old at the time as your 2019 is today. Keep working your required maintenance, fix or mod your top-of-list items and very soon enjoy some travel and good camping! 😎 We keep improving our Oliver way-of-life with several major modifications and all the many little things, while getting away 180 overnights so far! This cosmetic restoration and our new Chill Cube A/C were our last big projects. Please add a simple forum signature when you get a chance. Search here and ask questions re your "heater" (furnace or HWH?). You may be on the right track thinking "sail switch" but of course first make sure you're getting LP and 12VDC. Welcome, thanks again and best wishes, JD 10 hours ago, jd1923 said: Thank you very much, Martin & Linda! New Oliver and new Forum Members for a month now - Congratulations! 😂 A lot like us 3 years ago. Our 2016 was 7 years old at the time as your 2019 is today. Keep working your required maintenance, fix or mod your top-of-list items and very soon enjoy some travel and good camping! 😎 We keep improving our Oliver way-of-life with several major modifications and all the many little things, while getting away 180 overnights so far! This cosmetic restoration and our new Chill Cube A/C were our last big projects. Please add a simple forum signature when you get a chance. Search here and ask questions re your "heater" (furnace or HWH?). You may be on the right track thinking "sail switch" but of course first make sure you're getting LP and 12VDC. Welcome, thanks again and best wishes, JD 10 hours ago, jd1923 said: Thank you very much, Martin & Linda! New Oliver and new Forum Members for a month now - Congratulations! 😂 A lot like us 3 years ago. Our 2016 was 7 years old at the time as your 2019 is today. Keep working your required maintenance, fix or mod your top-of-list items and very soon enjoy some travel and good camping! 😎 We keep improving our Oliver way-of-life with several major modifications and all the many little things, while getting away 180 overnights so far! This cosmetic restoration and our new Chill Cube A/C were our last big projects. Please add a simple forum signature when you get a chance. Search here and ask questions re your "heater" (furnace or HWH?). You may be on the right track thinking "sail switch" but of course first make sure you're getting LP and 12VDC. Welcome, thanks again and best wishes, JD Not sure how to add a forum signature. Not sure I understand how to use this site for searches either. Oh well. Will keep trying. Thanks again
Boudicca908 Posted Wednesday at 04:04 PM Posted Wednesday at 04:04 PM 22 hours ago, Martin White said: Not sure how to add a forum signature. @Martin White I sent you a private message with a few links and I hope that helps. You should see a notification about a 'new private message' near upper right corner (on my computer, that is where my notifications show up). 1 Oliver Elite II Twin (delivered 3/28/2022) Tow Vehicle: Chevy Silverado 2500HD diesel my Oliver has camped here
