Hello experts.
i mistakenly connected my battery in reverse polarity when reconnecting in the dark garage its stored in.
i replaced the fuses in the panel that were blown, but the inverter doesn’t work and i think I need to replace the 300 A DC fuse.
 Is it safe to connect to and use shore power until i get things checked out?
Tim & Camille,
Tucson AZ and Chaska MN
2024 LE1 Hull #1478
Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
Depending on the wiring of your Oliver (there are many variants), shore power may not connect with a blown inverter or blown main 300A fuse. But given the main fuse blew your inverter is likely OK.
You can try to connect to shore power, but without replacing the 300A fuse to reconnect your batteries, it likely will not work anyway and either way you would NOT have lighting or 12VDC accessories.
You need to disconnect your batteries anyway after this accident. Test voltage on each one separately. Given they are LiFePO4 batteries, if they read much less than 10V they are in trouble but perhaps can be revived. Slow charge each one separately. Some of the small chargers, like this one have repair functions that pulse a small charge on and off to help.
https://www.amazon.com/dp/B07W3QT226/
Let us know of your progress and there are many of us who can help.
Thanks.
I have lights and jacks work after replacing those fuses, but inverter is powerless and won’t reset.
I will hook up shore power later to see what works.
And I have AGM batteries. Voltage is 99% on the Victron meter
Tim & Camille,
2024 LE1 Hull #1478
I see you have a 2024 LE1.   Which inverter do you have?  I see in a xantrex XC2000 manual that there is a in internal fuse that may have blown due to a reverse polarity and there's a led light on the back side of the inverter that comes on if a reverse polarity happens.
Thanks I’ll check that too.
i appreciate all the great advice.
Tim & Camille,
2024 LE1 Hull #1478
I tested the DC in line fuse for continuity (which was ok) and verified that there is 12 V at the terminals in the inverter. The Xantrex manual doesn't indicate the presence of an internal DC fuse and that an external fuse is necessary.
I did replace a blown fuse in Victron MPPT 100I20 charge controller and the batteries now appear to be charging from solar power.
Without shore power, there is no display (or alarm) on the inverter display and the inverter will not turn on with the power button. With shore power, there is the following display without an error message.
Is there some reset procedure for the inverter or it is toast? What does it mean that there's Shore power display but none on DC, even though I've confirmed 12 V at the inverter?
I will call Oliver in the morning but I appreciate the input and suggestions>
Tim
Tim & Camille,
2024 LE1 Hull #1478
Try calling Xantrec tech support rather than Oliver.
2020 OLEll, Twin, 579:
Thanks,
I spoke with Oliver and Xantrex this morning. Oliver walked me through a reset procedure but that didn't work. Xantrex thinks its probably the two reverse polarity fuses inside the inverter that could be replaced and might work, but a board could be fried. The only Xantrex service places near me (Minnepolis) are camping world and since the reverse polarity error negates the warranty (pun intended), I'm responsible for costs. So I'm checking into a solar place near me. Maybe upgrade to Li batteries too with a turn off switch so I don't do the same thing again.
Thanks again for all the suggestions.
Tim & Camille,
2024 LE1 Hull #1478
Problem solved!
I took the Oliver to a highly-rated solar installer in our area and he solved our problem.
Galway girl was correct, the internal fuses (there were two) in the Xantrex inverter were blown. The service tech had another identical inverter on hand (he had replaced it with a Victron) and used those fuses, since he didn’t have new replacements in stock.
 We also had him replace our AGM batteries with a Vatrer 12V 300AH Bluetooth LiFePO4 Self Heating battery (only $599) and a shut off switch, so I don’t repeat my reverse-polarity blunder when it goes in storage.
Thank you all for your help. Heading up to northern MN for some mountain biking next week.
Tim & Camille,
2024 LE1 Hull #1478
Let us know how this lithium battery does for that price..  my AGMs are 4 years old now , might want to upgrade soon. Stay safe out there..
2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
Looks like an Epoch clone from the outside, same casing and handles.
But it's what's inside that matters and we won't know until Will Prowse cuts one open for review! 🤣
https://www.vatrerpower.com/products/vatrer-12v-300ah-bluetooth-lifepo4-lithium-battery-with-self-heating-200a-bms-supports-low-temp-charging-4-f-5000-cycles-2560w-power
On second look, the length is certainly different!
Epoch 300 Ah L13.77" W7.59" H9.76" and 57 LBS
Vatrer 300 Ah L15.12" W7.64" H9.76" and 55 LBS
Given the length of the Vatrer and the 14" wide battery tray in our Olivers...
Only ONE (1) Vatrer 300 Ah battery will fit in the battery tray, NOT two!
This can limit upgrade potential, but you can just barely fit three (3) of these in the battery bay with the tray removed, like I did mine. 900 Ah heated with Bluetooth for $1,800 is an amazing deal GIVEN these prove to be of good quality with long life. I spent $2,817 total for 900 Ah Epoch but list price today is $3,747 plus tax (1,249 each). Epoch used to give 10-15% OFF, these days it's more often 5%.
One 300 Ah battery is one thing, and sure beats 200+ LBS of old AGM batteries!
Though I'd love to see an Oliver owner mount 3 Vatrer batteries, 900 Ah for only $1,800!
Watch this item. When they get popular like Epoch, they won't be $400 OFF anymore!
I don't understand the need for 900 Ah. Without getting any charging, 300Ah easily covers us for 5 days. With good sunlight our batteries are pretty much topped off every day.  Can you run your air conditioner and microwave? do you run an electric induction stove top?
Fieldbrook, Ca
On the 18th day after crossing the Canadian border at the beginning of June, we finally got some sunshine and things returned to normal, electrically. Our array of 600AHs recovered nicely from 19 & 21% the next day.  I was beginning wish I had a 900 setup.  300 would be too little for us for the amount of boondocking we do.  And we do not power the A/C from battery power.  So far it works for us :)
ALAKAZARCACOFLGAIDILINIAKSKYLAMEMDMAMIMN
We just spent 4 overnights between Flagstaff and the canyon. Not exactly the desert SW at 7600 feet but it was the week of July 20th with highs in the mid-to-high 80s, everyday up there (116F in Phoenix). Two of 4 nights we had monsoon rains and we had to cook indoors using a pressure cooker one night and Emeril oven another (microwave removed for the Emeril). We often use a portable induction cooktop but not this trip. We had the A/C on 24x7 in fear of overnight rains, when generally after dinner we would open windows. A couple nights the old Dometic 3-way fridge had the "Check" (LP) light come on, likely from the altitude, so we also ran the fridge on batteries for about 60 hours over the 4 days.
With the Victron MP2 inverter/charger we can run the Chill Cube A/C, The Emeril Oven, the fridge, the TV and soundbar, etc. all at the same time without worry as to what we can or cannot run on electric. Coffee every morning with an 1100W electric kettle. With 900 Ah LiFePO4 batteries we have power to spare.
I can see what you're saying, but of course with the old Penguin A/C you're not running A/C at all when unplugged. The P2 would bring 300 Ah down to ZERO in 2 hours. I thought we had all the power we needed to run A/C for 4 days straight, and we did but had not counted on running the fridge on electric too, which hour after hour takes quite a bit of Ah.
The picture shows our remaining Ah on our 4th night at 7 PM. Epoch #2 was below 20% and it stopped showing up on the app (notice the pic shows 600 Ah total since it cannot see one battery). By morning SOC was 18% and when we got home late afternoon SOC was 43% with battery #2 again reading, recharged from the DC-DC charger.
SOC of 43% might not sound too good, does it? But keep in mind 43% of 900 is 387 Ah. Instead of driving home, if we had driven to another campsite we'd be back in business for another couple days. I'd give up our 900 Ah right along with my right arm! 😎 But if you have no interest in upgrading your A/C and running it off-grid then 300 Ah is good enough. Those who go from 300 to 600 Ah can get down to 50% SOC and be at 300. If you have small Ah capacity, you always need it full. Having greater capacity allows you to run at lower SOC%.
We were able to run A/C for 100 hours straight, including when towing, with our setup! And if you're always running near 100% SOC, the DC-DC charger will get lonely with no work to do! 🤣
Edited by jd1923
I'm looking at these Vatrer batteries now myself. Can't beat that price for 900ah for what seems to be a decent quality brand.
