Hello experts.
i mistakenly connected my battery in reverse polarity when reconnecting in the dark garage its stored in.
i replaced the fuses in the panel that were blown, but the inverter doesn’t work and i think I need to replace the 300 A DC fuse.
 Is it safe to connect to and use shore power until i get things checked out?
Tim & Camille,
Tucson AZ and Chaska MN
2024 LE1 Hull #1478
Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
Depending on the wiring of your Oliver (there are many variants), shore power may not connect with a blown inverter or blown main 300A fuse. But given the main fuse blew your inverter is likely OK.
You can try to connect to shore power, but without replacing the 300A fuse to reconnect your batteries, it likely will not work anyway and either way you would NOT have lighting or 12VDC accessories.
You need to disconnect your batteries anyway after this accident. Test voltage on each one separately. Given they are LiFePO4 batteries, if they read much less than 10V they are in trouble but perhaps can be revived. Slow charge each one separately. Some of the small chargers, like this one have repair functions that pulse a small charge on and off to help.
https://www.amazon.com/dp/B07W3QT226/
Let us know of your progress and there are many of us who can help.
Thanks.
I have lights and jacks work after replacing those fuses, but inverter is powerless and won’t reset.
I will hook up shore power later to see what works.
And I have AGM batteries. Voltage is 99% on the Victron meter
Tim & Camille,
2024 LE1 Hull #1478
I see you have a 2024 LE1.   Which inverter do you have?  I see in a xantrex XC2000 manual that there is a in internal fuse that may have blown due to a reverse polarity and there's a led light on the back side of the inverter that comes on if a reverse polarity happens.
Thanks I’ll check that too.
i appreciate all the great advice.
Tim & Camille,
2024 LE1 Hull #1478
I tested the DC in line fuse for continuity (which was ok) and verified that there is 12 V at the terminals in the inverter. The Xantrex manual doesn't indicate the presence of an internal DC fuse and that an external fuse is necessary.
I did replace a blown fuse in Victron MPPT 100I20 charge controller and the batteries now appear to be charging from solar power.
Without shore power, there is no display (or alarm) on the inverter display and the inverter will not turn on with the power button. With shore power, there is the following display without an error message.
Is there some reset procedure for the inverter or it is toast? What does it mean that there's Shore power display but none on DC, even though I've confirmed 12 V at the inverter?
I will call Oliver in the morning but I appreciate the input and suggestions>
Tim
Tim & Camille,
2024 LE1 Hull #1478
