Sandman Posted August 1 Posted August 1 Hello experts. i mistakenly connected my battery in reverse polarity when reconnecting in the dark garage its stored in. i replaced the fuses in the panel that were blown, but the inverter doesn’t work and i think I need to replace the 300 A DC fuse. Is it safe to connect to and use shore power until i get things checked out? Tim & Camille, Tucson AZ and Chaska MN 2024 LE1 Hull #1478 Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
jd1923 Posted August 1 Posted August 1 10 minutes ago, Sandman said: Is it safe to connect to and use shore power until i get things checked out? Depending on the wiring of your Oliver (there are many variants), shore power may not connect with a blown inverter or blown main 300A fuse. But given the main fuse blew your inverter is likely OK. You can try to connect to shore power, but without replacing the 300A fuse to reconnect your batteries, it likely will not work anyway and either way you would NOT have lighting or 12VDC accessories. You need to disconnect your batteries anyway after this accident. Test voltage on each one separately. Given they are LiFePO4 batteries, if they read much less than 10V they are in trouble but perhaps can be revived. Slow charge each one separately. Some of the small chargers, like this one have repair functions that pulse a small charge on and off to help. https://www.amazon.com/dp/B07W3QT226/ Let us know of your progress and there are many of us who can help. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Sandman Posted August 1 Author Posted August 1 Thanks. I have lights and jacks work after replacing those fuses, but inverter is powerless and won’t reset. I will hook up shore power later to see what works. And I have AGM batteries. Voltage is 99% on the Victron meter 1 Tim & Camille, Tucson AZ and Chaska MN 2024 LE1 Hull #1478 Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
Galway Girl Posted August 1 Posted August 1 I see you have a 2024 LE1. Which inverter do you have? I see in a xantrex XC2000 manual that there is a in internal fuse that may have blown due to a reverse polarity and there's a led light on the back side of the inverter that comes on if a reverse polarity happens. 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Sandman Posted August 1 Author Posted August 1 Thanks I’ll check that too. i appreciate all the great advice. Tim & Camille, Tucson AZ and Chaska MN 2024 LE1 Hull #1478 Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
Sandman Posted August 2 Author Posted August 2 I tested the DC in line fuse for continuity (which was ok) and verified that there is 12 V at the terminals in the inverter. The Xantrex manual doesn't indicate the presence of an internal DC fuse and that an external fuse is necessary. I did replace a blown fuse in Victron MPPT 100I20 charge controller and the batteries now appear to be charging from solar power. Without shore power, there is no display (or alarm) on the inverter display and the inverter will not turn on with the power button. With shore power, there is the following display without an error message. Is there some reset procedure for the inverter or it is toast? What does it mean that there's Shore power display but none on DC, even though I've confirmed 12 V at the inverter? I will call Oliver in the morning but I appreciate the input and suggestions> Tim Tim & Camille, Tucson AZ and Chaska MN 2024 LE1 Hull #1478 Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
Ronbrink Posted August 3 Posted August 3 13 hours ago, Sandman said: I will call Oliver in the morning but I appreciate the input and suggestions> Try calling Xantrec tech support rather than Oliver. 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Sandman Posted August 3 Author Posted August 3 Thanks, I spoke with Oliver and Xantrex this morning. Oliver walked me through a reset procedure but that didn't work. Xantrex thinks its probably the two reverse polarity fuses inside the inverter that could be replaced and might work, but a board could be fried. The only Xantrex service places near me (Minnepolis) are camping world and since the reverse polarity error negates the warranty (pun intended), I'm responsible for costs. So I'm checking into a solar place near me. Maybe upgrade to Li batteries too with a turn off switch so I don't do the same thing again. Thanks again for all the suggestions. 1 Tim & Camille, Tucson AZ and Chaska MN 2024 LE1 Hull #1478 Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
Sandman Posted yesterday at 12:53 AM Author Posted yesterday at 12:53 AM Problem solved! I took the Oliver to a highly-rated solar installer in our area and he solved our problem. Galway girl was correct, the internal fuses (there were two) in the Xantrex inverter were blown. The service tech had another identical inverter on hand (he had replaced it with a Victron) and used those fuses, since he didn’t have new replacements in stock. We also had him replace our AGM batteries with a Vatrer 12V 300AH Bluetooth LiFePO4 Self Heating battery (only $599) and a shut off switch, so I don’t repeat my reverse-polarity blunder when it goes in storage. Thank you all for your help. Heading up to northern MN for some mountain biking next week. 4 Tim & Camille, Tucson AZ and Chaska MN 2024 LE1 Hull #1478 Tow vehicle: 2024 F150 Powerboost with 7.4 kW generator with Anderson hitch and TPMS on the trailer.
Golfnut Posted 49 minutes ago Posted 49 minutes ago Let us know how this lithium battery does for that price.. my AGMs are 4 years old now , might want to upgrade soon. Stay safe out there.. 2022 Elite I # 1179 | 2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
