2008RN Posted Thursday at 05:53 PM Posted Thursday at 05:53 PM I am planning a 8-10 week trip in British Columbia,Yukon and Alaska for next summer. I started to think about internet access, and being able to communicate with kids. So I started looking at Starlink posts in the forums here. I am thinking about the Starlink mini and the Starlink Route mini with the mesh network then doing the Pause anytime with standby mode to lessen the Starlink charges. I am not at the point of wanting to drill holes in the Oli or install a satellite in/on the truck. I know others here were talking about going with the Starlink mini and StarLink router mini in order to able able to get the satellite receiver out at the 50 ft limit and still get decent reception back inside the Oli. I was hoping to get some feed back on how this is working out. Thanks, Bob Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
jd1923 Posted Thursday at 07:19 PM Posted Thursday at 07:19 PM (edited) 1 hour ago, 2008RN said: I was hoping to get some feed back on how this is working out. Hey Bob, there is much experience here. Mine is just one input for you... I purchased the extra router when Geoff posted this (impulse purchase because of the $40 sale): https://olivertraveltrailers.com/forums/topic/10918-the-new-starlink-mini-router-for-what-ails-you/ Turns out a year later, I've never used it (still have it NIB somewhere)! I just last week integrated our Mini to the Pepwave router which is pretty cool, but our installation is far beyond what you expressed you want. https://olivertraveltrailers.com/forums/topic/9933-pepwave-cellular-router-and-not-the-common-install/#findComment-126971 You really don't need anything but a simple way to mount the Mini. At first, I just sit it on an upside-down milk crate. I was using battery packs so not to string wire, but the Mini comes with a 120VAC power supply (inverter ON required) with produces 30VDC with a 50' cord. We're always 50 ft within view of the northern sky and I would not want the hardware sitting much further out of sight. The simple stand pictured, better than my old milk crate, is what we use when our truck cannot be parked in the right spot. I have a camping rule to minimize setup which in turn reduces all the work to setup and tear down and we move a lot (as you will going all the way to Alaska)! No poles and suction cups for me. As far as service, there is the monthly $10 cost for stand-by service which includes enough bandwidth to setup, download updates, configure and test the installation. You can also slowly load a web page or send an email, again very slowly but the connection is there. When you upgrade service (Starlink must be positioned and phone setup must first be connected to Starlink W-Fi when there's no cell service), they prorate the first month. Our billing date is the 4th of the month, so for example, if I start service on the 20th of the month, given my billing date I will be charged about half the plan cost. I can immediately change the next month plan to return to Stand-by $10/month, so I don't forget. On such a trip to Alaska, you may just need it ON for 2-3 months. This is good to know, but more so for us where we have the cellular antenna and router and T-Mobile 5G SIM card which costs $30/month on my business plan. If we're getting cell which is about 80% of the days we travel then I'm paying for Starlink only when necessary. But when you activate, you're charged on that date through your billing date. Edited Thursday at 07:22 PM by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Todd B Posted Thursday at 09:19 PM Posted Thursday at 09:19 PM I have really liked our Starlink mini when traveling. I have used it for basic keep in touch stuff all the way to video calls for work. We have even held two wifi based phone calls over Starlink mini while on the standby plan! My setup is still pretty basic. I have a tri-pod I mount it on so I can move it to the best spot and plug it into the side of Ollie. Speed and reliability have been great! As @jd1923 mentioned the ability to switch plans is great. Sometimes I have paid $15 for 50GB of data for the 4 days I needed it (just got lucky with how it hit my billing window). 2 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
Moderators Mike and Carol Posted Friday at 12:35 AM Moderators Posted Friday at 12:35 AM After a lot use of our Starlink Mini, our normal method of deployment is to use the outside plug on the side of the trailer to plug in the power supply and then set the dish on the tongue box if we’re facing north-ish or on the bed cover of the truck if we’re not. That’s it. No mount, no tripod. The back of the dish has the right angle if it is on a level surface. I do have the router and we used it once when we were camping in Washington state under a heavy canopy that required the dish to be a little too far from the trailer for good bandwidth. If the dish is on the trailer tongue box we get plenty of bandwidth. Even on the back of the truck it’s no problem. I did have one mishap one evening in New Mexico when a thunderstorm popped up out of nowhere and blew the dish off of the box. It still works fine after its flight and hard landing. Just a scrape on one corner. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
2008RN Posted Friday at 07:24 AM Author Posted Friday at 07:24 AM 11 hours ago, jd1923 said: The simple stand pictured, better than my old milk crate, That stand looks pretty cool. What parts did you use to make it work. Also the battery looks like a Dewalt 20V battery. How did you wire into the battery. I like the idea of not using cables if possible and if I use a cable I only what to use one. Either RJ45 or Power. I have a tonneau cover so placing it on the cover when needed would be great, when not possible I would like the stand instead of just sitting it on the ground, and the stand had weight in the base it would be even more stable on the Tonneau. Thanks for letting me know that you arrived at your current setup through a process. I liked to know that. I know your setup is more complex than I want now, though it works great for your needs and you arrived at that over testing and growth. Sorry but what is NIB"🤔 I have a question for you and @Todd B how can you mount the mini on a pole or a tripod, Most tripods are 1/4-20 threads and I have know idea what the pole size @jd1923 uses. Special Addapters or does the mini come with all of those mounting options? Sorry for basic questions, When I was a machinist/ automated equipment tech, and then IT, I usually tried to wrap my head around a situation before I would implement. I am kind of anal retentive at times. I like seeing things from different angles before I purchase something. I do not mind fabricating/ buy adapters to make things work, but it nice to have an idea which way I will move before I purchase something. Sometimes it works and sometimes it is working through a problem/situation to come up with a solution. If someone else has a good solution that works, I do not mind leveraging those solutions. Why reinvent the wheel if someone else has already done it. (Off topic) I built a 42' x 16' free standing awning off the back porch with plastic corrugated roof special ordered from the east coast( my wife's idea), I want a plywood with metal roof. The awning roof cantilevers over the roof on the house . Living in Oregon in with many trees and 90+ humidity in the winter I needed a way to clean the awning roof, because of the debris, moss and lichen growth. When I first tried to do this I made a 3 nozzle sprayer on rollers to hook to my pressure washer. It failed miserably. I ended up recruiting my son, and we both stood on our metal roof, one sprayed the roof with water as the other used a micro fiber mop head on a 16 ft paint roller pole to clean the roof. This worked but it was very labor intensive. I found an old high end pressure washer at an estate sale this year. My son and I made the base so I could tow it with the mower and put a removable hose real on the base. I went over every part of the sprayer. It looks like brand new accept for the dented Honda gas tank. It took a 3 iterations with the old 3 nozzle sprayer, but I got it working great, and at half throttle. Had some fun at full throttle where the sprayer was floating 4ft above the roof because of the spray pressure. When I got it dialed in it took 1.5hrs by my self without getting any over spray on the metal roof, as compared to 4hrs for 2 people and both of us getting wet on a metal roof. The point of the story I may be slow and with limited resources, but I never gave up on finding a solution. 2 Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
2008RN Posted Friday at 07:48 AM Author Posted Friday at 07:48 AM (edited) 7 hours ago, Mike and Carol said: I do have the router and we used it once Was it the router a mini? Did you use the mesh wifi or did you do RJ45? If you used the mesh wifi where did you put the router. Living in Oregon we are often under a tree canopy, and the cell reception is very spotty at best on the coast, along the Cascade mountain range and in eastern Oregon prairie land. I still have a problem calling something a mountain range in Oregon after spending most of my life in Colorado Rockies. I do have a hard tonneau cover, but no tongue box . My preference would be to set it on the tonneau and then to disconnect it before take the truck on a outing and store it somewhere. Edited Friday at 07:57 AM by 2008RN Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
2008RN Posted Friday at 08:00 AM Author Posted Friday at 08:00 AM 10 hours ago, Todd B said: We have even held two wifi based phone calls over Starlink mini while on the standby plan! That is nice knowing you can still do some minimal data functions, like phone calls over wifi, and I am Assuming text, and emails in standby mod Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
Todd B Posted Friday at 01:05 PM Posted Friday at 01:05 PM 5 hours ago, 2008RN said: That is nice knowing you can still do some minimal data functions, like phone calls over wifi, and I am Assuming text, and emails in standby mod Correct. @2008RN, I have this adapter. https://www.amazon.com/dp/B0DP21TD7L?ref_=ppx_hzod_title_dt_b_fed_asin_title_2_0 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
Steve Morris Posted Friday at 02:08 PM Posted Friday at 02:08 PM (edited) 1 hour ago, Todd B said: @2008RN, I have this adapter. https://www.amazon.com/dp/B0DP21TD7L?ref_=ppx_hzod_title_dt_b_fed_asin_title_2_0 Note that the Mini came with two different socket sizes since its release. Pucks are not interchangeable between the early ant later versions. I use this to mount my Mini on an old unused camera tripod. https://a.co/d/00vsLugU Edited Friday at 02:09 PM by Steve Morris ----- Steve - Northern Ohio, USA Wandering around on occasion, always lost. 2021 Toyota Land Cruiser - 2023 Oliver Elite II Twin Hull #1360 “Curiosity” Facebook - Instagram Camped in Curiosity = Green —— Visited with Curiosity = Gray
jd1923 Posted Friday at 05:16 PM Posted Friday at 05:16 PM (edited) 17 hours ago, 2008RN said: That stand looks pretty cool. What parts did you use to make it work. Hello again Bob, and thanks! I merely purchased a 4 ft piece of 1 1/2" PVC (2" OD) and a coupler from Lowes. Sawed the PVC in two 2 ft sections and the coupler will join the two only in the truck installation (pic1). The lower 2 ft section is permanently mounted to our extra fresh water tank. This works in an open bed but the lower section could be bumper mounted or to the side of a truck cap or the Oliver front basket. For the "umbrella stand" option the set screws from the stand fit into the drill holes. There is also a 3rd drill hole up top (cannot be seen in pic) to hold the Starlink set screw. Half fill the umbrella stand with water and it's not going anywhere! Good sale price on this today at $27! https://www.lowes.com/pd/Patio-Premier-Patio-Premier-Square-Blow-Mold-Umbrella-Base-Black/1002629278 17 hours ago, 2008RN said: Most tripods are 1/4-20 threads and I have know idea what the pole size @jd1923 uses. Special Addapters or does the mini come with all of those mounting options? Starlink includes two mounts. Mike mentioned he would merely lay the Mini on a flat surface. He's using the simple base mount that has a kickstand to produce the correct angle. I started the same way but found often in the woods finding a flat spot to support the dish is difficult. Starlink includes a second mounting plate (pic2) which comes with the 2" mounting hole with set screw. Notice the two drill holes in the upper post. If I'm using the umbrella stand, these line up with those set screws. I love the 1 1/2" PVC mount and would not stray from this. If I was to buy a stand again, instead of the umbrella stand which is large to store, a folding tripod would be OK, if I could find one that would hold the 2" pipe. I wouldn't want to get into camera stands, 1/4-20 screw mounts with adapters. IMHO, a soft 1/4" screw should not be the only thing holding the dish, not in heavy weather. No skinny stands, no long poles, no suction cups, nothing fancy for me. Just open your compass phone app, mount the dish pointed north, check alignment on the Starlink app, just a one minute installation required with this setup! 😎 17 hours ago, 2008RN said: Sorry but what is NIB"🤔 Sorry, acronym from eBay sales, means "New in Box." Edited Saturday at 01:20 AM by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Wayfinder Posted Friday at 07:33 PM Moderators Posted Friday at 07:33 PM I don't yet have the mini, but I still use the Starlink Gen 3. I had purchased a tri-pod mount adaptor from Bantha Overland on Etsy. I just checked and he has a few 3D printed items for the mini as well. I'll use him again as the first mount was a good solid solution for my heavy-duty camera tri-pod. I like having items that are multi-purpose, to save weight & gear, i.e. a camera AND Starlink Tri-Pod, etc. Also with the mini, I want to check out all the cool cases/mounts available. Veritas Vans seems to have an interesting solution for the mini. I'm also thinking 3M tape magnets so I could put the mini on top of the Ollie, or on top of truck cap. Which ever works best at the time. Lastly, I think this is more true for the mini, but recently I took a chance and started pointing my Starlink Gen 3 in any direction in the opening of trees (within South Georgia). I was amazed that I did not see any speed test reduction compared to pointing dish North. Try that out. It sounds like the mini pretty much can point anywhere too these days. 1 Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
Moderators Mike and Carol Posted Friday at 09:58 PM Moderators Posted Friday at 09:58 PM 14 hours ago, 2008RN said: Was it the router a mini? Did you use the mesh wifi or did you do RJ45? If you used the mesh wifi where did you put the router. Living in Oregon we are often under a tree canopy, and the cell reception is very spotty at best on the coast, along the Cascade mountain range and in eastern Oregon prairie land. I still have a problem calling something a mountain range in Oregon after spending most of my life in Colorado Rockies. I do have a hard tonneau cover, but no tongue box . My preference would be to set it on the tonneau and then to disconnect it before take the truck on a outing and store it somewhere. It’s the Starlink router, RJ45. The dish came with a pretty long power cable and we got a similar length cable for the router. We ran the cable from the dish back to the trailer, through the dinette window (screen slightly open) to the router that we set on the dinette table. Beside the tonneau cover and tongue box we’ve used the picnic table to set the dish on, and we’ve also just set it on the ground. Just wherever has the best shot to a clear sky in the right direction. If we’re gone for the day I just bring it inside until we get back. 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
2008RN Posted Sunday at 06:04 AM Author Posted Sunday at 06:04 AM (edited) Hi, Thanks for everyone for your input. You filled a lot of blanks in my knowledge, and allowed me to research several things dealing with the Starlink Mini and accessories. Here is where I am starting. 1. I found out that StarLink is starting production runs of the Mini V2 Sattelite dish. It will use very slightly less power, and includse a 4S lithium battery integrated in to the back of the Dish with 71Wh battery. Most likely the back will change due to the battery and the attachments will need to change, so 3rd party stuff will need to be redesigned. They will be using a USB-C for external power. After reading about the new version. I do not think I want the new version. I think I will stay with the current version, with so many accessory options out there. I think presently I have seven 5Amp (100 Wh theorically, 90Wh in real life) DeWalt batteries at home and 3 chargers. I could free up 2 batteries and 1 charger. Or if I bought new batteries, I could buy two 5 Amp batteries. There are always places having sales on them, and it would probably be cheaper than the newer version Mini batteries. Anyway, I placed an order today for the current Starlink Mini and 100GB Roam plan for $55/month. 2. We are going out to the beach for 5 days, it would be a great time to do some testing of the Mini the distances from the trailer and internet speeds with 120V hookup. After I do the distance/up and download speed testing I will make a decision on router needs. 3. I haven't made a decision on mounting yet. I have a 2 tripods, one normal size and small Joby Gorillapod, they take up little space. The Joby is very configurable for uneven terrain like on boulders or slopes. I will test them, looking at stability and ease of set up. I expect JDs setup to be extremely stable and quicker setup. I think I might be able to hook the battery adaptor to the PVC pole on the stand, The Umbrella Stand just takes up more physical space in the truck. 4. After I get back home I will do functionality test of the stand by mode. I had problems with the Starlink AI Bot purchasing a the Starlink plan and Mini. I wanted to pay the cost outright. The bot just signed me up for payments over 12 months. The Bot couldn't cancel the order and the order was locked in before I could get logged in (minutes). The Bot tells me I can cancel upt o 3 hours after ordering, but the system won't let me. Boy was I pissed. I got tired of hearing, "I am sorry, that's on me". I left a scathing anti-AI review. The only saving grace for Starlink is a real person called back 5 hours later and fixed it so I could call back after receiving the Mini, and they would allow me to pay off the Mini. About 10 minutes after purchasing the mini, a youtube video popped up about Starlink charging large service charges, $200 - $1500, for any changes to their account. These charges have been in high data traffic areas where area is overloaded and they are constantly degrading customers bandwidth. He said these charges should go down/away after the Gen3 satellites start taking the load off (64x increase in throughput) off which will be placed with the upcoming starships. Their hope is to deploy twice as many Satellites per load with the starships. Also some good info on life cycles of the satellites. Thanks again Everyone for your input, Bob Edited Sunday at 06:10 AM by 2008RN 2 Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
jd1923 Posted Sunday at 04:26 PM Posted Sunday at 04:26 PM (edited) 10 hours ago, 2008RN said: I think presently I have seven 5Amp (100 Wh theorically, 90Wh in real life) DeWalt batteries at home and 3 chargers. I could free up 2 batteries and 1 charger. Or if I bought new batteries, I could buy two 5 Amp batteries. There are always places having sales on them, and it would probably be cheaper than the newer version Mini batteries. If you already have several 5Ah Dewalt batteries, bring 2-3 with you. I had two 6s that were 3 years old. Burnt one leaving it attached to Starlink overnight. While sleeping it went to zero, no lights, wouldn’t recharge. Gave the other 6 to my son after I bought two 10 Ah which stay in the Oliver. Mounted one of my chargers in the Attic. The two 10s will last a full 24 hr cycle, each will run the Mini for about 8 hours. Figure the 5 Ah Dewalts to last 3-4 hours each. You’ll need something like this: https://a.co/d/0boBnuD4 10 hours ago, 2008RN said: The Umbrella Stand just takes up more physical space in the truck. I like the cost and simplicity of the 1 1/2” PVC but the umbrella stand is really too big. Wish I had a good place to store it but lately I stopped bringing it and one campsite this trip we were back to laying it on a milk crate 10 ft behind the Oliver. 90% of the time, I can use my truck mount, move the truck a few feet over to clear trees when needed. Love our complete setup of truck-based 5G Cell/Starlink/Wi-Fi! Pull the Mini and PVC section out of my truck toolbox and we’re ready in one minute, all devices already Wi-Fi connected to our “Home” network. 😎 I’m also big about using what you have. Perhaps you can adapt one of your tripods to work effectively. I do suggest eventually to get something truck mounted. The TV can often be moved some. When parking the Oliver, the level spot, sun/wind orientation, the direction of your view, are all more important than clear sky to the north. Edited Sunday at 04:35 PM by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Snackchaser Posted Sunday at 06:37 PM Posted Sunday at 06:37 PM On 9/10/2026 at 10:53 AM, 2008RN said: I was hoping to get some feed back on how this is working out. I’ve been using Starlink in the Northwest for years, since being a beta tester for the first generation round dishy. Iv’e found that a pole mounted dish often get better sky-view angle over trees. I have a simple pole mount using a 10' stick of Electrical Metallic Tubing (EMT) that I carry under the trailer frame (see Tacky Starlink Dishy Mast). It was an easy and inexpensive mod, quick to set up, and it doubles as a flagpole if you're feeling patriotic. I stopped using a tripod stand a long time ago. When not using the pole, I just lay the Mini on whatever is near by, or even on the ground. A permanent mount is not optimal in tree county. We don’t use a dedicated carry case either, we just toss it on the bed or on the back seat. I’m all for having less stuff to pack up and carry. The Mini is watertight and robust, and you would be hard pressed to damage it. I prefer running the Mini from DC power over using the inverter for AC power. It's more power-efficient, especially if you leave it on 24/7 like us. The wattage losses from converting DC to AC, then back to DC add up. So I use a Victron DC voltage booster and it’s been a popular solution that has worked flawlessly for years. See: Starlink Mini installation, cracking the 12 Vdc barrier . . . or not! It’s nice having a portable battery pack for backup at times when there is no sky-view at camp, or to share internet with your buddies. I made a bunch of the “Everlanders” designed rechargeable slim packs that last several hours, but commercial options are also available. We depend on the internet for cell service, so battery packs or inverter AC power is not a good permanent solution for us. The bargain priced Mini router is usually not needed... until it is. Keep in mind that the farther you get from the dish, the weaker the WiFi signal, and the slower the internet. Weak WiFi can be mistaken for poor satellite reception, so try the router if you're seeing the spinning wheel of frustration! These can also be powered by 12 volts DC. See: The new Starlink Mini Router, for what ails you! for power options. So anyway, that's my two cents. Have fun in BC, but watch out for cell phone roaming charges, and don’t bring any produce back! We just got detained on the USA side last week because we declared a couple ears of BC of corn. They could have just taken the corn, but instead they made us maneuver the trailer into the humiliation parking area, then kept us waiting in the detention facility for an hour while they searched our stuff and freaked out the dog! But I have to say, the lab did a nice job at de-lousing and folding our shopping bag! Cheers! Geoff 1
2008RN Posted Sunday at 10:04 PM Author Posted Sunday at 10:04 PM 4 hours ago, jd1923 said: You’ll need something like this: https://a.co/d/0boBnuD4 Ya, I like the cord is 3.2 ft (1meter). I did find 1 couple of Dewalt adapters that have Low Volt Cutoff they cut off around 15V. That might help to not torch a battery. Some adapters also have other features as SOC or voltage display, and on/off switch alarm, etc.... That might help to not torch a battery. 5 hours ago, jd1923 said: I bought two 10 Ah I just looked at prices they are little pricy, but you're paying for twice the Ah. Just read some complaint with the Dewalt 10Ah batteries shipped with their mowers. Very short life. one guy dropped back to the 6Ah batteries and liked those had a better longevity they just have to spend more time charging to get lawn mowed. 1 Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
2008RN Posted yesterday at 12:00 AM Author Posted yesterday at 12:00 AM 4 hours ago, Snackchaser said: These can also be powered by 12 volts DC. See: The new Starlink Mini Router, for what ails you! for power options. Thanks for the info to Run route off of DC. Since we are in the PNW we camp with a lot of tree cover (Canopy). Usually close to the roads/pavement will have less trees overhead. Like you said You really do not need the router.... until you do. I think you have convinced that router is a great "what if" backup. 4 hours ago, Snackchaser said: Have fun in BC, but watch out for cell phone roaming charges, and don’t bring any produce back! We just got detained on the USA side last week because we declared a couple ears of BC of corn. Thanks for the heads up, just checked my AT&T plan, and treat Canada just like the US. No roaming charges. Secondly, Crossing the border(s) with food stuff/ETOH. I know going into Canada they charge for ETOH over a very small limit, and their regulation about beef, chicken, most produce. If you have already cooked meat/vegges, is that a problem. Going back into the US we haven't looked anything up. So we not only have to travel the mainland US/Canadian borders, but we plan on going to Skagway and back by highway. that is another crossing back and forth. Then we do the AlCan Highway back and forth. Aree all 6 crossing going to be like this? Not taking produce/ meat/Etoh across the border could be a pain. We like to eat fresh fruit. Eat a fair amount of cook fresh veggies, and some meat. I would also like to pick up a bottle of wine in Washington, wine and whiskey in Canada, Spruce pine needle beer in Skagway if they got it. Have not thought about what we will buy in Alaska yet. This could really become a Pain in the..... We bought a fair amount of ETOH on our trip last year to Kentucky/Tennessee and up to the great lake and back west across highway 2. We had planned to jump across the border to the Hope BC Egg rally and then see Vancouver then back home. With all of the ETOH we accumulated seeing so many states and staying at harvest host breweries, Wineries and Distilleries we decided we would forfiet Hope and Vancouver because of the steep fees for the ETOH. If fact we still have not drank everything we bought last year crossing most of the USA. 1 Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
jd1923 Posted yesterday at 04:06 AM Posted yesterday at 04:06 AM 5 hours ago, 2008RN said: Just read some complaint with the Dewalt 10Ah batteries shipped with their mowers. Very short life.. Yeah, so far so good for us, but we also have the Dewalt leaf blower and it can empty a 5 Ah battery in 4-5 minutes big amps/blowing hard! Starlink requires a small load over a long period of time, so it should be easier on batteries. 😎 The 6 Ah Dewalts I bought 5 years ago were HD! The case could survive a shoulder height drop to a concrete floor, np but not anymore. Shop as wisely as you can. Hate to say it but the aftermarket batteries are half-decent at half price today. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted 9 hours ago Posted 9 hours ago 21 hours ago, 2008RN said: I did find a couple of Dewalt adapters that have Low Volt Cutoff they cut off around 15V. That might help to not torch a battery. Just realized this statement! That's a good idea which should protect the batteries. Please post a link if you believe you found a quality product. 19 hours ago, 2008RN said: Going back into the US we haven't looked anything up. We haven't made the trip, so no real experience. I remember reading something on our Forum regarding pets. Our Springer "Charley" is 12 years old and his health records are not exactly up-to-date! Perhaps something to look into if you travel with pets.. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
2008RN Posted 2 hours ago Author Posted 2 hours ago (edited) 7 hours ago, jd1923 said: Just realized this statement! That's a good idea which should protect the batteries. Please post a link if you believe you found a quality product. There are many on Amazon, and several on other place outside of Amazon. My problem is finding one high enough customer ratings, that has a large enough sample size to give statistical significance. Found one with 125 reviews, but I didn't like the rating number, and the comments on the reviews. I found one that had 4s and 5s on the reviews and all of the reviews were good. Problem is that there were only 24 reviews. I may take a chance and go with this one. https://www.amazon.com/dp/B0GLF9D2LD/?coliid=IHZS5CRM8MBZM&colid=27T05FXN4KH1E&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it 7 hours ago, jd1923 said: We haven't made the trip, so no real experience. I remember reading something on our Forum regarding pets. Our Springer "Charley" is 12 years old and his health records are not exactly up-to-date! Perhaps something to look into if you travel with pets.. Our dog has all of the standard shots and my wife keeps good records. We usually do NOT Border the dog, So we haven't done the Bordetella (kennel cough) vaccination. There is a large nice RV parks for the 55 and older that requires them. Going to Canada we probably would not need then But I may do The shot just to be safe. Edited 2 hours ago by 2008RN Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
