40 minutes ago, Ronbrink said:
I bought this in order to use the outdoor plug. It not only allows clearance for the SL brick, but serves as a convenient power switch.
We don't have Oliver's factory solar system and inverter. When away from shore power, use a similar switch mounted in Ollie's battery box with our system. Installed two Epoch 105AH lithium batteries, using up to 2 solar suitcase panels for charging or gen-set on poor solar days. Stole @Snackchaser  ideal (Thanks Geoff) converting the TV cable inlet to the Starlink Mini power outlet using a 12V/24V to 48V step up DC to DC converter. Need to install a small interior switch so turning the system on/off can be done from inside Ollie, too.
Edited by rideandfly
Bill 2015 LE2 2024 F-350 6.8L
On 9/15/2026 at 9:10 PM, jd1923 said:
Can you make regular phone calls or using an app? The calls are likely dropping when one satellite is moving out of range and the next one is taking over.
Use any extension cord to use the outdoor outlet vs. a window open, or you could change the outlet cover.
I’ve held many work-related video calls on the Gen 3 without issues… with an open sky. One could likely play an online game too, such as World of Warcraft, but maybe not a first person shooter (FPS). The latency requirements are high and one would be getting killed a lot in the FPS game.
Chris
o-o  2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110"
o-o  2024 Ford F-250 Lariat, 7.3L Godzilla gasser
o-o  Augusta, Georgia
On 9/13/2026 at 11:37 AM, Snackchaser said:
I’ve been using Starlink in the Northwest for years, since being a beta tester for the first generation round dishy.   Iv’e found that a pole mounted dish often get better sky-view angle over trees
I’ve been kicking around doing Starlink. Next year after retirement from job 1 it can be a business expense for job 2, but I’m not really wanting to do it. Only if it makes life easier. Various long term Ytuber users have mentioned the hardware doesn’t last long, so my first concern is long term reliability - what’s your experience?
Second is convenience, ideally I don’t want to fuss with poles and whatnot. DC fridge Olivers have the outdoor table and this nifty solution from the factory, and they dropped the coax connectors that could have been converted to ethernet or whatever the mini needs (oh I guess the mini now just needs power, cool)
Back there to the left is an outlet for the induction, so I can plug the power into that. I can run an ethernet cable potentially through the walls up to my main router. The opening is 12”x7” so if I’m lucky I might be able to store the mini in there too.
So I’m wondering whats the best way to mount this? I have a fold up ladder I like to bring along, maybe just a suction cup roof mount is the way to go, how well would that work with tree cover? Thoughts/ideas welcome …
Edited by DanielBoondock
Sierra EV AT4 2026 (max range 530 mile pack)
1 hour ago, DanielBoondock said:
They hinge this opening from the factory now? If so, that's an interesting change. Mine from early 2023 is screwed in.
I added an AC outlet in the panel, plugged into that same outlet. And a DC outlet wired and fused to the fringe power. There's very little gap behind the table when folded down and latched, so I had to recess the outlets. Sue was a handy addition.
Steve - Northern Ohio, USA
Facebook - Instagram
