Recently replaced our A/C with a new unit.  The Air distribution box has a smaller footprint than the old Penguin.  So, I filled in with white caulk.  Of course, the white caulk is not as white as Donna would like it to be.
What suggestions do you have for touching up with a whiter white.   Touch up Auto paint?    These are small...  about 1/8th inch in diameter but there are eight of them.  Plus they are on the ceiling so they tend to be noticed around bedtime.   Help me get a good nights sleep... Please!  :classic_biggrin:
Scotty
Here ya go. Cheaper than touch-up paint or new caulk, and an outdoor camping experience to boot!
https://a.co/d/074EF7vg
I had these in my bedroom as a kid, and it was the first thing that came to mind. Not actually helpful, but they might be a distraction. 😉
Edited by Steve Morris
Steve - Northern Ohio, USA
Facebook - Instagram
Scotty
Would Donna be amenable to sleeping outside? That way she wouldn't notice.
Just Kidding..........
  • Haha 2
  • Wow 2
I used white plastic hole plugs similar to below when I changed out my A/C.  I actually had to enlarge the holes to get the smallest one's to fit.  You don't really notice them but if you do, they just like part of the installation.
I was concerned that if I tried to fill the holes, I wouldn't be able to reproduce the glossy finish of the gel coat and that would be more noticeable.
https://www.amazon.com/Tnisesm-Plastic-Knockout-Locking-Furniture/dp/B0C3H1J6M8
Big Texas – 2018 Elite II, Twin Bed, Hull #306
2024 RAM 2500 6.7L Cummins, Weigh Safe hitch
I think if anyone is getting kicked out it will be me.   I just re-sealed the Maxx Fan and used 3M Marine Adhesive Sealant - Fast Cure 4000 UV.  Found it very easy to work with... used painters tape about 3/16" from the edge and ran the bead very easy.  While I was doing that... I started thinking... Damn this stuff is WHITE!   I mean like BRIGHT WHITE....
Then the light bulb went off and just a little dab over the caulk in the old drill holes and it is now an acceptable level of whiteness for Donna.   So, no one has to sleep outside.
Looking forward to seeing you at the Rally.  Maybe you will give us a quick tour of the new battery system.    #145 goes in to Easton in November.
Scotty
Scotty
We will be there on Monday.
You will love the work that Easton will do for you.
Hey Scotty. Would you mind posting a few pictures of the air handler unit in the cabin after your new Chill Cube was installed, especially with holes you filled? As you mentioned above, there is a bit of difference between the Penguin and the Chill Cube inside. The Chill Cube is intriguing and seems potentially like a good choice, especially for energy management. And have you had much of a chance yet to try it out? I’d be interested in further reports. Thanks.
Scotty is camping and he might not have a pic before he filled the holes. I filled mine too but have this picture from before. You can see two holes in front and look closer to see two more on either side. The Dometic P2 was twice as big inside and out. There are two more in back 6" beyond the much smaller Chill Cube.
Notice the headroom too! Another reason it's quiet is the air handler/fan are not hanging down into the cabin interior like ALL the others!
Scotty got his installed at summer end, and he was only able to test the A/C minimally. He got the newer Heat Pump version and we hope to hear about that function soon. The link below goes directly to page 2 of my Chill Cube post which shows the installation. Pages 3-4 have some of my reporting on its efficiency. We ran ours all summer (all of 2026) and we just LOVE it!
Edited by jd1923
Thanks JD. We are weighing all of our options for replacing the Dometic. The Chill Cube is certainly getting a lot of play with people. And Inverter Service Center, the place where Steve got his electrical upgrade done, recommends the Chill Cube and may actually start installing it at some point. Thanks again!
Very happy with the chill cube.  Here is my post on Johns thread for the Furrion:
Heat Pump update
At the Oliver Rally in Lake Guntersville we had great weather.  Daytime in the mid 70's so no opportunity to test the a/c.  But at night the temps went down to mid / high 40's.   Ran the heat pump every night set at 68 degrees.  It would cycle on and off through the night...   When it first started it was louder (about 47db) then it settled down to a very quiet purr (about 38db).  I ran it up to 73-74 and it came on strong and warm still about 47db.  Easy to live with.  Can carry on a conversation even at its loudest.   Very happy with the unit.
My wife, Donna, is very sensitive to propane smell and reported a slight headache when we woke after using the propane heat.  During the rally, she said there was no headache at all and she loves the heat pump.
I am certain that after the 900ah upgrade we will be using the chill cube pretty exclusively for heat and a/c.
It does remain to be seen how the condensate issue does in the East during a hot summer.   You'll have to wait on that report.
Scotty
From JD's posts and others about this product I have to agree that this appears to be a great option.  Worth a look by many owners.
However, as I have previously stated, for those with limited headroom for storage of our OE2's, the Chill Cube's extra 5 1/2" height above what most slim line units have can be a deal killing concern.
In 2019 I saw an RV try to pass under an old railroad bridge where an asphault overlay had been done, but the posted bridge clearance had not been updated.  He cleared off several items on his roof.  At the time I thought the driver was an idiot and his mistake was sadly funny.  But when I stopped and helped him measure the actual clearance, I became a witness in his insurance report.  Not so funny after all.  With my tall telestep ladder he "rattle canned" paint sprayed out the wrong height posted.  Suspect the RR got the bill for repairs. But he had to suffer for some time without his two AC's, antenna, and exhaust fan.  What a PITA for his family.
So if increasing the height of anything on your roof, please re-adjust your bridge clearance alert as well.  My personal alert is anytime I see a posted clearance of 10 feet 0 inches (or less), I stop and slow walk the passage.  So knowing what your trailer's actual  clearance minimum is a smart idea!
PS:  Roads tend to drain towards the right side.  Hence this side typically is lower.  If you are close to the posted height, you may want to move right and maybe get a bit more clearance.
