Skipster Posted October 7 Posted October 7 how do I shut water off to hot water heater . bypass valve is not moving and I do not want to force it. actually the access is horrible. is there another valve I can close so no water gets into the hot water tank so I can winterize . a little aggravating skip and cyd nielsen hull #822 Elite tow vehicle 2017 jeep trailhawk v6
Golfnut Posted October 7 Posted October 7 @Skipster i see you looked at my post back in August.. in the near future i might put a more beefer valve in there. Dont know if you have the truma agua or reg 6 gal .. my 6 inch hatch makes a lot easier to access that valve..good luck.. 2022 Elite I # 1179 | 2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
Skipster Posted October 7 Author Posted October 7 (edited) thanks good idea for sure. right now I'm winterizing and can not close the valve so wondering how to go forward. six gallon regular..hopefully I won't have to put 6 gallons on antifreeze in the tank to finish winterizing the water lines Edited October 7 by Skipster skip and cyd nielsen hull #822 Elite tow vehicle 2017 jeep trailhawk v6
Moderators topgun2 Posted October 7 Moderators Posted October 7 Skipster - Given the relative newness of your Ollie - have you tried calling or emailing Service to see what they would recommend? Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Golfnut Posted October 7 Posted October 7 I think it is not good to put antifrezee in hot water heater. Maybe stronger mind’s know more .. or give OTT a call… 1 2 2022 Elite I # 1179 | 2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
Moderators Mike and Carol Posted October 7 Moderators Posted October 7 5 minutes ago, Golfnut said: I think it is not good to put antifrezee in hot water heater. Maybe stronger mind’s know more .. or give OTT a call… Agree. For winter, I drain the hot water tank. Don’t want antifreeze in there! 1 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted October 7 Posted October 7 (edited) 3 hours ago, Skipster said: bypass valve is not moving and I do not want to force it. Yes, FORCE it until it moves! First be certain of which is the correct direction to turn. Get the right hold on it with a Channel Lock pliers. You may need two tools, one to hold the valve and another to turn the handle. This is exactly what would be done if you took it somewhere for repair. In my 48 years of car repairs, I find many fail in certain repairs due to their thinking. Sometimes these kind of repairs take more time thinking it through than actually doing it. Did you try turning it seated or laying the opposite direction? Did you try it left-handed? The saying goes, "try and try again" while thinking through alternative means. Next idea, get somebody younger and stronger. I used to be able to do almost anything. Not anymore. These days if I can't do it myself, I call our son Adam the two of us together certainly WILL get 'er done! In our EII hull, OTT put the access panel about 6" OFF from the best position, go figure. I find it turns turns easier reaching through the air vent to the furnace. But you have an Elite I which is much different! Perhaps you need to add an access panel. Drill a 4" or 6" opening with a hole saw and add a marine access panel. I understand we don't like drilling into the Oliver, but keep in mind you'll need to get in there quickly twice a year! https://www.amazon.com/AOWEITOUR-Inspection-Detachable-Suitable-facilities/dp/B0CFXNMJBB/ Edited October 7 by jd1923 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Skipster Posted October 7 Author Posted October 7 That is great advice which I really appreciate. I was able to get the valve partway closed and I put the anode back in. I was able to get pink antifreeze to come out of all faucets hot and cold and outside shower. So all good for now. Next spring I will drill and cut a new access hole thankyou for the help 2 skip and cyd nielsen hull #822 Elite tow vehicle 2017 jeep trailhawk v6
Skipster Posted October 7 Author Posted October 7 (edited) I did take the anode back out and will install a new access hole thankyou and drained all fluids from the hot water tank. Edited October 7 by Skipster skip and cyd nielsen hull #822 Elite tow vehicle 2017 jeep trailhawk v6
FloraFauna Posted October 7 Posted October 7 1 hour ago, jd1923 said: Yes, FORCE it until it moves! This is my thought too as long as it being turned in the right direction as suggested. It's a brass fitting on my Oliver so not easy to break and mine is stiff but it turns. 1 1 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
Rivernerd Posted 6 hours ago Posted 6 hours ago (edited) Application of a bit of penetrating lubricant, like PB Blaster, then waiting for a day, could free up your stuck brass valve, and enable it to fully open and close. Edited 6 hours ago by Rivernerd 2 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
