Imelda Posted 4 hours ago Posted 4 hours ago ac shore power turns on microwave and turns on outlet but not lights. i know there fuse blown somewhere but where? Imelda Donnelly, Oliver Elite 2, Hull 642 year 2020 pulled with 2022 Nissan Titan
Moderators mossemi Posted 3 hours ago Moderators Posted 3 hours ago Which year and model of Oliver are you asking about? Mossey Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Imelda Posted 3 hours ago Author Posted 3 hours ago oliver 2 year 2020 Imelda Donnelly, Oliver Elite 2, Hull 642 year 2020 pulled with 2022 Nissan Titan
Imelda Posted 3 hours ago Author Posted 3 hours ago the ac power is good microwave is working and ac outlets but no lights and refrigerator and ac not coming on Imelda Donnelly, Oliver Elite 2, Hull 642 year 2020 pulled with 2022 Nissan Titan
Hokieman Posted 3 hours ago Posted 3 hours ago (edited) 1 minute ago, Imelda said: the ac power is good microwave is working and ac outlets but no lights and refrigerator and ac not coming on My 2021 model has a 12V 60A circuit breaker under the street side bunk. Edited 3 hours ago by Hokieman Typo “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250. Former owner of 2019 Oliver Legacy Elite #431. Blairsville, GA
Imelda Posted 3 hours ago Author Posted 3 hours ago i am at a camp site. tomorrow i will look for this. Imelda Donnelly, Oliver Elite 2, Hull 642 year 2020 pulled with 2022 Nissan Titan
Imelda Posted 2 hours ago Author Posted 2 hours ago ii am at a camp site. tomorrow i will look for this. Imelda Donnelly, Oliver Elite 2, Hull 642 year 2020 pulled with 2022 Nissan Titan
Imelda Posted 2 hours ago Author Posted 2 hours ago i did find the fuse but unless the fuse is bad i flip it on and off but didnt seem to solve the DC power problem i. the trailer. i don’t have a meter to test the fuse. Imelda Donnelly, Oliver Elite 2, Hull 642 year 2020 pulled with 2022 Nissan Titan
Dean and Mary Posted 1 hour ago Posted 1 hour ago Imelda, The 60‑amp circuit breaker under the street‑side bunk also supplies power to the jacks in my trailer. Do your jacks work? If they do, then move on to the converter—located under the dinette in my unit—and check the fuses there. If the jacks don’t work, the breaker is most likely the issue. Dean TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Victron MultiPlus-II 4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC – DC charger, Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
Imelda Posted 35 minutes ago Author Posted 35 minutes ago Dean, jacks do not work. i cannot get the trailer of the truck hitch. i did flip this 60V and it did not fix the problem. i wonder if i can over ride it or maybe it needs to be replaced. i am wondering if I can manually lower the hitch jack so I can at least unhook the trailer from the truck. Imelda Donnelly, Oliver Elite 2, Hull 642 year 2020 pulled with 2022 Nissan Titan
Dean and Mary Posted 30 minutes ago Posted 30 minutes ago I should have started by asking whether you have voltage at the batteries, and then whether you have voltage at the input side of the 60‑amp breaker. A voltmeter will help immensely. It could even be something simple—like lithium batteries that were accidentally switched off. On my trailer, a 4‑gauge cable runs directly from the batteries to the 60‑amp breaker, and that circuit is independent of the heavier‑gauge cable feeding the inverter. I can double‑check in the morning, but I’m fairly sure the wire going to the converter is connected before the 60‑amp breaker, which would mean the breaker isn’t the issue. I hope this doesn’t add to the confusion. Dean TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Victron MultiPlus-II 4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC – DC charger, Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
Dean and Mary Posted 27 minutes ago Posted 27 minutes ago Electric RV jacks almost always have a manual method for raising and lowering them in the event of dead batteries. The connection point is located on top of the jack, and the trailer includes a tool designed specifically to operate it. TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Victron MultiPlus-II 4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC – DC charger, Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
