Picked up our Apex two weeks ago and have been in it every night - so far, so good. We planned to spend 3 weeks straight to learn and work out any bugs (very minimal issues so far)
Pros - A dream to tow & bike mount has been solid/Eco flow display easier to learn that anticipated/battery re-charge amazingly fast/Houghton AC quiet and have ran all appliances (simultaneously) and some “faux” boondocking on the 48 volt DC system w/ no issues. It has been wonderful to arrive at the campsite with 98% battery every time. Overall love the attention to detail and quality of the design. Dinette cushions (backs) could be improved and wished they would have included the solar suitcase connection.
Cons: Black/Gray tank indicators don't really warn you of a full tank, but the toilet gurgling and the shower backing up are sure indicators 🙂 I haven’t attempted filling the fresh water tank yet (to be honest I am intimidated by the multiple valves under the bed - wish they were labeled but thankful for the poster size diagrams on the compartment cover.
Our background: Previous tent camper, then a Casita circa 2000s, and Airstream owner. So far impressed with the Oliver overall operation (Airstream could learn from Hohenwald orientation and pick up) and while tempted by the new Casita double axle trailer (significant price difference)  the Apex is a well designed trailer and we have no regrets.
Edited by Sentry62
  • Like 7
Great to hear the initial "break in" is going well. Honestly, it does take a little trial and error to get comfortable with the valve configurations. Interesting choice on the reg toilet, vs the composting toilet, as the APEX is skewed towards the non-facilities spots. Took a real hard look at the Apex, and really like the blacked-out style, although I don't understand the tire choice, it is a great looking rig overall. Seems the II is a better fit for our future RV needs. Hope your journey continues to be all that you imagianed.
2027 EII on the board.
Assuming its the same as the 2026 its super easy, just remember there's basically two modes you use the majority of the time.
Pump or city: For the back ports you either fill the tank directly (streetside) and use the onboard pump, or you get pressurized city water (curbside) with the pump off.
Boondock fill: If you want to fill unpressurized from a container, use curbside, with all the valves reversed. Including the one that's far at the back of the trailer in the T. Reverse all the valves again to use the pump normally.
That's it. The third configuration is for maintenance; winterize, sanitize or descale
I (and others) only use the onboard pump and fill the tank with softened water. I have a small RV softener installed under the twin bedside table used during filling. I also have a few small inline bullet hose softeners I might use sometime for pressurized water, who knows.
Edited by DanielBoondock
Sierra EV AT4 2026 (max range 530 mile pack)
Hello Apex #2 from Apex #1, Hull #1738, 2Dreamin👋
Totally agree on the dinette cushion backs, it was annoying every time we got up from the dinette so I see a solution in our future.
City water connection is on the curbside and Fresh water tank fill is on the street side.
We got the compost toilet and are very happy with our decision, this was after months of contemplating it, then deciding not to do it and then changing our minds after talking with the Whitaker's at Denali National Park in Alaska earlier this summer.
We did fill the fresh water tank to test out the pump and also testing out the pressure of the pump for the tankless hot water heater (THWH) and that worked great.  To set our preferred THWH temperature, I hopped in the shower, turned on the faucet hot water only while DH was setting the temp to 107 which worked great for both of us actually.  Using only the hot water side of the faucet eliminates cold spots with the tankless.  The only time we experienced any issues was while at a campground that had 'low' water pressure which reduced how hot the water came out, the tankless also works on water pressure, this is where the fresh water pump came in handy.
We find the EcoFlow to be a dream to manage, so much easier than our Airstream Interstate set-up, even after we had all the wiring ripped out, soft solar panels ripped off and an entire new battery system, inverter, etc and solar panels installed.  We love the ease of operation with the EcoFlow.
Enjoy your new Apex!!!!!
Are you going to the rally?
We are in site F20
Apex X23
Hull #1738
2Dreamin
2026 Ford F350 SD, 7.3 Godzilla, Bedslide, Leer Cap, GenY Torsion Hitch, Rockstar Flaps
http://www.youtube.com/@SlowDownandTurnHere
Subscribe & click the 'notification bell'  Come along with us and let's go on an adventure with our Apex X23!!!
Our 2022 is new to us this year, and I shared the same initial confusion when looking at the water‑valve diagram. While it’s a great feature to have the valve positions shown based on the function you want, I also wanted to understand the actual start and end points of each line.
So, I enhanced the diagram and placed a laminated copy under the bed next to the water pump. Below is that updated drawing. Please let me know if you spot any errors in it.
TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package.
Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires.
After market: Victron MultiPlus-II 12/4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC-DC charger 12/12V 50A 700W, Cerbo GX MK2 with GX Touch 70 Display.
Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
Thanks DB - great overview and it helps.
Thanks 2D, we can’t make the rally this year but hoping for next year. We are from Texas and currently in central Florida in a holding pattern due to the hurricane (but hoping to get home next week but I-10 and I-12 are going to be problematic) so we will see. We may crash the party 🙂  Yes on the Rec Pro water heater, use the hot water side to control the overall temp - same lesson we learned and I have also been removing our water pressure regulator to get the all important pressure for the water heater - that made a big difference as you stated.
Thanks D&M for the notes - those are helpful in understanding what valve does what.
My wife’s solution to the dinette cushion
YMMV
YMMV
This was standard and provided by Oliver in 2016.
Scotty
We did the same thing years ago. Has worked great. So well I forget it was an issue.
Todd & Kat
YMMV
We placed rug gripper pads under the cushions, but they still slide off. We're going to try a different brand and hope we have better luck.
Prior owner left us a roll of this and more of it was under the cushions. This stuff works, Con-Tact Brand Grip Premium by KITTRICH Corp.
I never thought about this - great idea. I will try out - soon.
We went through the same process. It saves water not having to make adjustments once you're in the shower. I like 105, and Deb likes 108. To further save water, we added a diverter valve to return  water to the fresh tank until it gets hot. This saves anywhere from a quart to more than half gallon.
Edited by Steve Morris
Steve - Northern Ohio, USA
Facebook - Instagram
@larcat @Sentry62
Congrats on your delivery date!!!!
We asked Oliver about the external folding solar panel connection which is on the 2027 Elite II and were told it was deleted on the Apex X23 since it had the 48V system.  There were 3 Apex's next to each other at the rally and Patrick Industries came to our Apex to go over some of the features of the system and answer any questions that each owner had.  On the way home from the rally we cracker docked 2 nights and one night at an RV Overnights Host.  We did not get the solar awning, not for certain how many opportunities we would have to use the awning.  Did you opt for the solar awning?
Apex X23
Hull #1738
2Dreamin
55 minutes ago, FirstApex said:
@larcat @Sentry62
Nope, didn't go with the solar awning. Hoping to use a 400w folder for supplemental.
The external plug isn't necessary --- just need a way to route back to the EcoFlow for a folding panel. Is there any sort of external cable routing at all? Nothing for starlink or similar? If not that seems like a pretty fundamental design flaw.
The Apex is powered by 48V system and was designed to add 1-2 solar awnings. You could ask OTT for a schematic showing your electrical system (with integration of the awning panels). The solar charger (SC) you install should have 48V output but for some reason OTT advertises the 400W rooftop solar on the Apex is 24V. New panels must be on an independent SC.
I would trace everything down and create your own system drawing. In our older hull, I had to pull every wire to fully learn the system (not good when under warranty)! 🤣
In the Elite we have 12VDC and 120VAC systems. The Apex has 48VDC and 120VAC systems and it must have a 48|12 DC-DC converter. The 48V system must be stepped down to 12V to run lights and other 12V accessories. You should locate this step-down converter for general purposes.
I would start at the batteries. See how many wires are connected there, follow them into the hull to see where they are connected and where is your main fuse. A new solar charger must connect to +/- battery somewhere. The other active Apex thread shows many pictures and some show unused terminals labeled "battery."
I would encourage you in that adding our Solar Suitcase was the easiest major electrical upgrade I've made to our Oliver. I've attached my upgrade link here for example. Of course, you have a 48V system so system components may differ but the basics are the same.
Re Starlink, there are some complex installations and some who just plug it into an outlet and lay it on the ground! 🤣 From the HOME page of the Forum, search for "Starlink" for many discussions.
Edited by jd1923
