Okay, I turned on our inverter to test it today. It seems to work microwave and TV/satellite etc. My question is is it normal for it to make noises. Ours sounds like R2D2! It is pretty loud. Is this normal??
Yvonne & Doug
Hull #223
We installed​ our own, before this was an option..
Ours isn't very noisy. But I would like to hear from the newer group
I can't comment on the noise beyond that they do whine.
Your tv and associated equipment are 12 vdc and you do not need to turn the inverter on.
It is not a hum or a low whine. It really does sound like the star wars robot. I am wondering if it could be the satellite moving and not the inverter. The last time I tested the inverter I didn't turn on anything but the inverter. I wonder if the satellite automatically comes on like the microwave when power is present. Maybe I have to flip the satellite breaker or unplug it. I will test that. Thanks for your responses.
Yvonne & Doug
Hull #223
Must be the satellite or something, our inverter is silent.
Happy Camping,
null
On our factory tour some time ago, there was a unit set up with a generator and Robert cranked it up for us so we could see how loud it was.  When he did, the inverter started making a high pitched whine that was so annoying that I had to ask him to turn it off.  Interestingly, it didn't bother my wife as much and Robert said that he couldn't hear it at all.  But to me it was like an icepick to the ear.
Our inverter doesn't make any noise.  We don't have the satellite dish so I'm not sure what that sounds like.  Mike
Thanks for all your responses. It was the satellite. I unplugged it and no more noise! That dish sure is noisy when it moves. Glad it wasn't the inverter, terrible noise ????
Yvonne
Yvonne & Doug
Hull #223
Ya it's funny, all the DC is nice and quiet, whether on generator or inverter turn on AC power and everything does a little "checking in process" I'm here, I'm here, me too.. I like the R2D2 comparison.
Randy
One Life Live It Enjoyably
2017 F350 6.7L SRW CC LB
2015 Oliver Elite II Hull #69
  • 1 year later...
We have a noise when plugged in to AC power (20A at home or 30 at campground). It comes and goes, and can get quite loud. I have had Jason look at it twice, and he couldn't get it to make noise. When we unplug for awhile, it immediately goes away, and usually won't reappear after plugging in for awhile, unless we don't give it enough time.
Anyone else have this problem? It is a buzzing noise. Tom and Carol Lamb
Probably the converter under the rearmost dinette seat. It is charging the batteries and can draw 10 to 15 amps or so initially until the batteries cycle into a lower or maintenance mode requirement. When you hear the noise check the Progressive Industries remote display. It will show you amps being drawn. The remote display should be located in a readily accessible location but unfortunately isn’t usually if factory stock.
2017 Elite II, Hull #208
2019 Chevy HD 2500 Duramax
