Could anyone help recommend (or post a picture) of what they carry in their Oliver as mechanical backup/replacement parts such as spare fuses, washers, shear pins, etc.?  Thanks
Fuses, you really can't have too many. I carry at least a few fuses for everything that needs one with the bulk of the collection being 10, 20 and 30 amp ATO blade type.  I also recommend a few 30 amp slo-blo glass type for the jacks.
This will tell you more that you every wanted to know about automotive fuses.
I also carry a spare water pump and an extra head for the rear jacks. These are by no means necessary but I have them so....  I lead a group of FG trailers on a trip earlier this year into the Utah back country and one of them had a water pump go out in his trailer.  He spent the best part of two days sourcing and installing it. I would have given him my extra but he had left to search for a replacement before I heard about it.
  • Thanks 4
I had a very hard time finding fuses for the jacks. I went to a bunch of auto parts stores, looked online at Amazon and others, but was unsuccessful. I finally found them here: https://www.ryderfleetproducts.com/bussmann-mdl-30/slow-blow-fuse-30-amp-p-bus-mdl30
The price says $1.62, but they sell then in lots of five, so it is $8.10 for five. And they tacked on shipping charges...
  • Thanks 5
  • 1 year later...
I think these are the equivalent fuses on ebay?  https://www.ebay.com/itm/1-LOT-Qty-5-Fuse-MDL-30A-250V-30A250V-Slow-Blow-Glass-Fuse-30-Amp-size-6X30-mm/142868147224?hash=item21439aec18:g:SHYAAOSwhkRWevOQ:sc:USPSFirstClass!30303!US!-1:rk:2:pf:0   acn anyone better versed in reading fuses confirm?
5 for $5.25 with free shipping.
Thanks
spacer.pngLEII Hull #517    |   Lincoln Navigator Reserve with Heavy Duty Trailer Tow Package
https://www.amazon.com/Bussmann-BP-MDL30-Marine-Delay/dp/B001PYSSO0/ref=sr_1_2?ie=UTF8&qid=1549996743&sr=8-2&keywords=mdl+30+amp+fuse
I believe these are same, will have to check.
Scentfreeinsc   -  I don't believe they are same, but I've been wrong before.
Ken/Judy,
May I ask how much they offered the package of fuses for?  I have several fuses in my amazon wish list but if Oliver has a package of just what I need for less, that would be a better option depending on $.
Shear pins? At home, I need them for the auger on the snowblower. I have spares for the outboard prop. Where might I need them on the Oliver? Now I am going to have to crawl all over the trailer looking at where they might be needed. Any suggestions on inventory? And what size drift punch(s)?
Shear pins?  I'm not aware of any shear pins on or in our Olivers.  I can't even think of where they might be useful.
ScentFree:
Be careful those fuses are rated for 250VAC not the 32V the other fuses are rated for. If you look close at one end of the fuse it should say 32v
1 LOT= Qty 5 Fuse MDL 30A 250V 30A250V Slow-Blow Glass Fuse 30 Amp size 6X30 mm
Harold
Sue & Harold
Oliver Elite II Twin bed,  Hull #508, Ram 2500
               ARCAIDINIAKYMIMNMOMTNENVNDOHORSDTNUTWIWY
