41 minutes ago, topgun2 said:
I care and applaud you for it!
Awww. Thanks.
Edit: not all in the Ollie. Another debate subject.:)
Edited by SeaDawg
  • 8 months later...
If you had thought that your map would show in the post above - it does not.
I'm having difficulty getting the webpage to come up. I keep seeing error codes, both on Firefox and on Brave web browsers. Any suggestions?
my Oliver has camped here
10 hours ago, Boonter Jeff said:
When would my map show up?
Your map should show up as soon as you've pasted it into your signature block in account settings . Then, make sure to touch the save button.
When creating your map, please select the small size.
I just created a random map, and inserted it into my signature block, to make sure instructions were still correct.
@Boudicca908, I just went into the map website using Chrome, with no issue. Maybe give that a try?
On 12/19/2021 at 8:22 AM, SeaDawg said:
Chrome
I have a mac, but maybe can use my tablet.... I'll try it. Thanks!
The maps website works well in Safari, so you might try that.  It looks like your signature is empty, so I think you just didn't get the link pasted in and saved.
This is what I see in my profile... after saving.. and the above map is what I get...    Think I'm going to give up now.
Looks like you got it, Scotty.
  • 1 year later...
Followed the instructions, but once I loaded it and went back it never shows up. I would assume I should be able to see it. I tried it 3 times and still don't see it
  • 3 months later...
Thanks for the instructions. Now that I've finally hit the road, I added a map. Apparently I have traveled and camped in 10 states on my trek to North Dakota. More states to come for this summer. What a joy it is, to see the country this way.
It is a total joy! Sometimes,  the miles drive you crazy,,but how much fun it is to wake up in a totally different environment.
  • Love 2
  • 4 months later...
Always been wondering if I'm supposed to be able to see my map on posts, or whether it is just visible to others.
Second, I would like to add some states and the Canadian Provinces map. I don't want to wipe out the existing map
Thanks
Something isn't working for you, John. We don't see your map, either. (And yes, it should be visible to you, too, unless you have viewing signatures turned off in your settings.) Sorry.
I don't see any signature for you, whatsoever.
Thanks,  I wondered. Probably going to have to have someone help me. My map is in limbo somewhere 🙃
John, getting to and updating the signature block is indeed not very easy, nor intuitive, as you can see from comments in this thread. You're not alone.
Do you work from a pc or a phone? My examples above are screenshots from my phone, but they should be pretty close to what you see on a pc.
At least this gives you an opportunity to update the "invisible map." 😞
Yup, you got it done, John! Congratulations!
Not to push the envelope, but you might want to add trailer model, year, and hull # to your signature, while you're in the zone.
  • 8 months later...
On 4/25/2018 at 9:00 AM, JWalmsley said:
If noticed some members on the forum have colored maps in their signatures. You may be asking yourself "How do you do that?".
Start by visiting this website:
http://visitedstatesmap.com
Select the states you have visited and choose the size you wish and click DRAW MAP.
*Please be considerate to others views on the forums by keeping the image around medium size*
Next you will be taken to a new page and underneath the map where it says "Copy and Paste Image URL:"
Copy the url, for example mine is:
http://visitedstatesmap.com/image/xlg.jpg - this is not your map unless you have been to zero states. This is an example.
Now go to your forum Signature to edit and put in the url:
It should now look like: example-map1.jpg.544e2f79d6872f11b1ba4ac3d463a30e.jpg
If you need help please discuss below.
Credits:
@SeaDawg, @KarenLukens
To add a state or states do I have to start completely over? I would hate to wipe everything out.
Second question, how do I add Canada?
Rather than use the web-based mapping tool, I simply found a large US map, and fill in my own states. I use a graphic application on my computer to "fill" each state (in my case one color for "camped in" and another for visited with the Oliver, but didn't camp.) I save a copy of the map with the states filled, then made a 200 pixel wide copy, and paste that into the signature file. To add a state, I simply fill in the new state on the original large file, and save a new 200 pixel wide copy. (I've found that the resolution on the small file is too low to use the "fill" tool there, which is why I do the changes on the large map.)
Here's a start for you. To add Canada, find a similar map, or, start with a blank North America map for both the US and Canada.
Edited by Steve Morris
Steve - Northern Ohio, USA
Facebook - Instagram
