russ4512 Posted September 30, 2018 Share Posted September 30, 2018 We just returned from a 4 week trip and in the last 2 weeks, every time I disconnected the trailer from the shore power, the trailer tripped a "master" switch under the drivers side bed and there is no DC power available in the trailer. I am able to reset the switch by pressing a small lever on the switch. I had the same problem last year but a local RV shop could not find anything wrong with the system. I am not an electrician but it seems that the AC to DC converter is not working. Has anyone else had this or a similar problem, and if so, how did you fix it? Link to comment Share on other sites More sharing options...
Overland Posted September 30, 2018 Share Posted September 30, 2018 I’m not sure if I understand exactly what’s going on. Sounds like you’re saying that if you’re plugged in, then DC works. When you unplug, it throws the breaker, but if you reset it then it works again. Is that correct? Are your batteries charging when plugged in? If so, then your converter is working. My initial guess is that your fridge is switching to DC when you disconnect, and somehow that’s throwing the breaker. Maybe try pulling the fridge fuse (or breaker if your trailer has a DC breaker panel) and then disconnect to see if that does it. Otherwise, I’m at a loss. Link to comment Share on other sites More sharing options...
russ4512 Posted September 30, 2018 Author Share Posted September 30, 2018 My apologies for not being clear. When I am plugged into shore power the trailer is running on AC. When I unplug from the shore power and the trailer is supposed to automatically convert the system (including the refrigerator) to DC, this "master" switch is tripped and there is no power until I reset the switch under the bed. I don't know how to tell if my batteries are charging when plugged in. I have been suspecting the refrigerator so I have turned the refrig off before unplugging from shore - this worked (didn't trip the switch) for the first few weeks but then it failed as described above. 1 Link to comment Share on other sites More sharing options...
Overland Posted September 30, 2018 Share Posted September 30, 2018 Thanks for the clarification. The way to tell if your charger is working is by checking the voltage on the battery monitor. If it goes up when you plug in, then it’s working. It will read 14.4 or something close to that when you first plug in, and usually 13 something when you unplug. Just for clarity, your DC circuit is always DC even when you’re plugged in. What happens is that when you’re on shore power, the charger converts some of the 120 power to 12 volt and adds that to the 12 v ‘pool’. Part of that power will go to the batteries to charge them and part will be used by your lights, etc. So, in other words, your charger is converting when you’re plugged rather than when you’re not, and there isn’t really a ‘switch’ that changes you from 120 to 12 v. I still think that the fridge is the most likely culprit, since there isn’t anything else that would ask for more power when you unplug. And if your breaker is tripping immediately, then it has to be a pretty big surge of power that’s doing it. Otherwise, it would take a bit for it to trip. I guess another thought is that the breaker is bad, and maybe vibrating open when you’re traveling. If the problem is repeatable in your driveway, then that’s probably not the case though. Do you have an inverter? If so, I guess that’s another possibility and you might try unplugging that before you disconnect. 2 Link to comment Share on other sites More sharing options...
russ4512 Posted September 30, 2018 Author Share Posted September 30, 2018 Thanks Overland. I will look at the items you mentioned tomorrow and let you know what I find. Link to comment Share on other sites More sharing options...
Townesw Posted September 30, 2018 Share Posted September 30, 2018 Just to be clear is this the breaker under the street side bunk that trips when you unplug from shore power? Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax Link to comment Share on other sites More sharing options...
russ4512 Posted September 30, 2018 Author Share Posted September 30, 2018 It is under the curb side bunk and doesn't look like the photo you posted. Tomorrow I will take a photo of the switch and post it. Link to comment Share on other sites More sharing options...
Townesw Posted September 30, 2018 Share Posted September 30, 2018 Do you have an LE or LEII and what year is it? Bill 1 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted September 30, 2018 Moderators Share Posted September 30, 2018 What else happens after you unplug? Do you raise the stabilizer Jack's, before or after, you unplug? Try changing the fridge to gas before unplugging, or, just turn it off. The DC draw on a 3way is pretty high... As overland asked, is the inverter off? Ac and heat off, or could you be trying to run electric heat or ac from the inverter? I'd be trying to hunt down any large electrical draw. Then, hint down a weakened breaker... Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted September 30, 2018 Moderator+ Share Posted September 30, 2018 The refrigerator does not "automatically" switch to DC unless there is no propane. When the Auto button is activated, the fridge will auto change between 120VAC and propane. As a last resort, if you are out of gas (or for some reason the valves are off) it would go to DC . From our standpoint, our gas is always on and we never run the fridge in the very power hungry and inefficient DC mode. Steve, Tali and our dog Rocky plus our beloved Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
russ4512 Posted September 30, 2018 Author Share Posted September 30, 2018 I appreciate all your comments and questions. Our trailer is a 2015 LE II. I turned the refrig off before unplugging and the breaker/switch still tripped. A/C and heat were always off before unplugging. I never turn on my inverter so that shouldn't be drawing any power. And the only time I run the refrig on DC is when we are towing the trailer. Link to comment Share on other sites More sharing options...
STEVEnBETTY Posted September 30, 2018 Share Posted September 30, 2018 Just to be clear, on your first post you stated the switch was under the street side bed, subsequent post you stated curb side. The switch that townsew posted is a "sail switch" when it trips a yellow flag pops up, you push it down to reset, it's under the street side bed on the elite 2 with twin beds. I've never had what you describe happen, but I can imagine if you have the inverter on while you're plugged in and your water heater on the ac setting, or any additional devices drawing ac current, when you unplug and your transfer switch switches over to D.C. It overloads the D.C. side and it trips your "sail switch". steve STEVEnBETTY Link to comment Share on other sites More sharing options...
STEVEnBETTY Posted September 30, 2018 Share Posted September 30, 2018 Sorry, I was typing, ( hunt and poke) when you posted about your inverter being off. Steve STEVEnBETTY Link to comment Share on other sites More sharing options...
russ4512 Posted September 30, 2018 Author Share Posted September 30, 2018 The switch is on the street side (driver's side). I erred in saying it was the curb side. Your description of the "sail switch" sounds like what I have. Mine doesn't seem to look like the photo from Townesw but I will check it out tomorrow. From what I can tell, all appliances are off when I unplug from shore power. But just in the last few days the hydraulic lift in the front seems to not be as fast in raising/lowering and it is almost always used in DC mode. Link to comment Share on other sites More sharing options...
russ4512 Posted October 1, 2018 Author Share Posted October 1, 2018 This is the breaker under the street side bunk that trips when I unplug from shore power. I noticed that mine is 40 amps and the one shown by Townesw is 60. When I plug into shore power, the voltage on the battery meter reads about 13.6, sometimes 14+. Link to comment Share on other sites More sharing options...
Townesw Posted October 1, 2018 Share Posted October 1, 2018 But just in the last few days the hydraulic lift in the front seems to not be as fast in raising/lowering and it is almost always used in DC mode. The jacks are electric not hydraulic and they only operate on 12VDC. Could the tripping of the breaker coincide with the use of the jacks? That breaker is a “thermally responsive Bi-metallic blade” type circuit breaker. It could be that you are performing a sequence of events that heats that breaker up to the point it trips and this could be aggravated by it being a weak breaker. Regarding your front jack: make sure the dimple in the tube on the bottom of the jack is riding in the groove on the extension tube. Bill 2 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax Link to comment Share on other sites More sharing options...
Townesw Posted October 2, 2018 Share Posted October 2, 2018 See if the wire from your battery is attached to the BAT lug on the breaker. I think your picture is upside down and it is throwing me a curve. Bill Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax Link to comment Share on other sites More sharing options...
russ4512 Posted October 3, 2018 Author Share Posted October 3, 2018 My photo is backwards. I don't know how that happened since the photo on my computer is the appropriate direction. Link to comment Share on other sites More sharing options...
russ4512 Posted October 3, 2018 Author Share Posted October 3, 2018 I noticed from your photo at least 3 wires attached to the breaker while mine appears to have only 2 wires. Because I am not an electrician I don't know how to tell whether my battery is attached to the BAT lug on the breaker. Link to comment Share on other sites More sharing options...
Townesw Posted October 3, 2018 Share Posted October 3, 2018 I believe if I were you I would locate a knowledgeable and reputable RV repair person and demonstrate to them what is happening and let them troubleshoot the situation and make the repair. Maybe if you gave your general location someone on this forum could recommend a good local RV repair service. Bill Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax Link to comment Share on other sites More sharing options...
russ4512 Posted October 3, 2018 Author Share Posted October 3, 2018 Bill, thank you for your time and knowledge in trying to solve my problem. At the beginning of this season I took our trailer to a known RV shop and they couldn't replicate the problem, so there was nothing to fix. I live in the Minneapolis MN area and gladly welcome all recommendations for a good RV repair shop. Link to comment Share on other sites More sharing options...
KenB Posted October 3, 2018 Share Posted October 3, 2018 I live in the Minneapolis MN area and gladly welcome all recommendations for a good RV repair shop. Try Mike’s LP and RV in Maplewood, MN. It’s a family run small business. Don’t expect anything corporate about them. Father and son do the repairs. Mother keeps the books. Grand kids running around. It’s nice to see them make it work. I teach high school in the area and two of their boys spent a considerable amount of time in my shop. Great people. Mike’s replaced the refrigerator on my EII when Oliver sold it to me with a unit that was dead on initial delivery. Oliver wanted (and got) a full day for issue diagnosis from me, plus they wanted me to stay at least another two days to get the replacement unit installed. I called Mikes LP from the parking lot in Hohenwald, made an appointment, and hit the road back to Minnesota without a working refrigerator on my brand new travel trailer. I had places to be and was so ticked off at Oliver for delivering a unit with a totally dead refrigerator, killing two days at a hotel in Hohenwald was unacceptable. How could the both factory QC checks and delivery prep miss that the refrigerator was DOA? Mikes is an authorized service center for just about everything in the RV industry. Mine was the second Oliver they’d worked on. And the refrigerator replacement only took one day at Mike’s. HTH, Ken 2 2013 Toyota Land Cruiser 200 2018 Twin Bed Elite II #351 Link to comment Share on other sites More sharing options...
russ4512 Posted November 4, 2018 Author Share Posted November 4, 2018 Bill, You hit the nail on the head!. I took the trailer to the RV repair shop suggested by KenB and after testing and probing, the owner said the wire connecting to the BAT terminal on the switch was extremely loose and not connecting all the time, thus causing my electrical problems. I won't be able to test it with a long trip until late spring 2019 but I feel much better about it now. Thank you for all your guidance. Russ 1 Link to comment Share on other sites More sharing options...
russ4512 Posted November 4, 2018 Author Share Posted November 4, 2018 Ken, I took my Oliver to Mike's LP, and Wayne and his business were just as you described. He found and fixed the problem. He also fixed the technical bulletin problem (faulty ground on the inverter) that some of the Oliver trailers had. Thank you again for the referral. I recommend Mike's LP to everyone with an Oliver or other travel trailer in the Minneapolis/St. Paul area. Russ Link to comment Share on other sites More sharing options...
KenB Posted November 11, 2018 Share Posted November 11, 2018 Hi Russ, Glad it worked out for everyone. Wayne and family at Mike’s LP are good, hard working people. They are easy to recommend. 2013 Toyota Land Cruiser 200 2018 Twin Bed Elite II #351 Link to comment Share on other sites More sharing options...
