Newshoes Posted July 7, 2019 Share Posted July 7, 2019 Any suggestions for a "off season" trailer cover source? 2019 Legacy Elite #431; 2019. TV 2019 GMC Canyon Denali, crew cab, 4X4, Long bed, Duramax Diesel. Link to comment Share on other sites More sharing options...
Jitters Posted July 8, 2019 Share Posted July 8, 2019 Check these out. All I've read indicates they excellent. *** Also, they've made them for Ollies already and have all the necessary dimensions. Not inexpensive however...around $700. https://calmarkcovers.com/ Greg 3 Greg USN Retired ARS AB7R Link to comment Share on other sites More sharing options...
Newshoes Posted August 20, 2019 Author Share Posted August 20, 2019 Well I ordered a cover for my Legacy Elite from CalMark July 17 and it is supposed to arrive this Thursday August 22. Not inexpensive, but quality does not come cheap. Just wanted a cover that matched the quality of the Oliver. I'll post a report on the finished product once I have a chance to test fit it. 2019 Legacy Elite #431; 2019. TV 2019 GMC Canyon Denali, crew cab, 4X4, Long bed, Duramax Diesel. Link to comment Share on other sites More sharing options...
permit bob Posted August 20, 2019 Share Posted August 20, 2019 Newshoes, Having had fiberglass RV's in the past before owning an Ollie, I've used many different brands and types of covers. These are "semi-custom" Horse Trailer covers, made with a "sunbrella" fabric that I've now used for four and a half years with great success from National/ Estrella. So far no rips or tears. They have a five year warranty. You can order them with squared, rounded, or tri-angled front/nose. The one I ordered, I believe it was the 20'-23' model, has a two foot tri-angled front on it that fit the Ollie just fine. https://www.nationalrvcovers.com/horse-trailer-covers.html. The cost was a bit under $500.00. Well worth the price! I've been very happy with it. It's tall enough to just cover the tires and still stay off the ground. Plenty of tie-downs to keep it snug in the wind, and weighs about 40lbs. Fits well over the A/C unit, Max-fan, and my King-dome. The tri-angular front allows it to fit around the propane tanks and the front motorized jack and still stay "snug". Don't forget the spare tire in your measurements. They are a "semi-customized, stock" item, so you're not paying for a fully customized unit and the bigger bucks. So far, knock on wood, it has stood up well to the southwestern elements (wind, sun, rain, snow, etc.) where other brands have not. If you check in the "Oliver University" section of the website you'll find the detailed dimensions of your trailer. It's a good fit. Sorry, but, I haven't figured out how to send pictures yet or I would. Best, Bob 1 Link to comment Share on other sites More sharing options...
Newshoes Posted August 20, 2019 Author Share Posted August 20, 2019 Bob CalMark has a template that asks for dimensions taken from the trailer along with providing them some pics. I provided them with the dimensions and photos prior to the fabrication. They have made some previously for the Elite II but did not indicate they had done a Legacy Elite. Each one would be slightly different depending upon what is mounted to the roof. We'll see how it came out. Cost around $700 or a little over 1% of the trailer cost! Thanks, Andrew 1 2019 Legacy Elite #431; 2019. TV 2019 GMC Canyon Denali, crew cab, 4X4, Long bed, Duramax Diesel. Link to comment Share on other sites More sharing options...
BuckandConnie Posted September 4, 2019 Share Posted September 4, 2019 Regarding off-season covers; what would you do if you have the solar panels? cover them to and just let the batteries idle? Or are there options to allow the solar panels to be exposed while the rest of the rv is covered? Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted September 4, 2019 Moderators Share Posted September 4, 2019 When I purchased my CalMark cover I asked about having clear panels sewn into the top for the solar panels. They will not do that. So, I simply put the cover on, make sure that the solar and all electric is turned off in the camper and then plug a small (25 watt) solar panel into the camper to tow vehicle pigtail so that the batteries remain charged over the storage period. Bill p.s. My Calmark cover is now going into its 5th year. I've had to patch about a half dozen places over the years where I did not pad the cover and the camper wore through - i.e. the corner of the folding steps, the bumper. But, Calmark includes patching material with the cover and all you do is glue the patch to the under side of the cover - works great. 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
BuckandConnie Posted September 4, 2019 Share Posted September 4, 2019 Thanks, do you remember when you fond the 25watt solar panel with the pigtail connection? Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted September 4, 2019 Moderators Share Posted September 4, 2019 Yep - I traded another Oliver owner for it. There is a thread here on the Forum somewhere about this application. I'll try to find it but I must run at the moment. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted September 4, 2019 Moderators Share Posted September 4, 2019 Here's what it looks like in the meantime: Note that it is just a regular 25 watt panel with built in controller mounted on an old tripod with additional support legs off the front ( to get the angle of the panel adjusted better for the angle of the Winter sun) and the positive/negative wires from the panel wired into the 7 pin trailer connector. The yellow pieces of rope at the bottom of the legs are used along with 12 inch nails to secure the panel to the ground. 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
hobo Posted September 4, 2019 Share Posted September 4, 2019 Check these out. All I’ve read indicates they excellent. *** Also, they’ve made them for Ollies already and have all the necessary dimensions. Not inexpensive however…around $700. https://calmarkcovers.com/ Greg $700 is cheap. I think my cover cost about $30K and we're not done yet. 2018 Elite II, Hull #414 (the very last 2018 produced). Trailer name "2 HOBOS" . 2018 F250 4X4 Crew Cab, 6.7L diesel Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted September 4, 2019 Moderators Share Posted September 4, 2019 This is the charge controller that is on my 25 watt solar panel: https://www.ramsond.com/shld-8/ And a 7 pin pigtail like this is available in many RV shops, WalMart and here: https://www.amazon.com/NEW-SUN-Trailer-Connector-Socket/dp/B0776VRGF5/ref=sr_1_6?crid=3NPAUKAVDDK0G&keywords=7+pin+rv+connector&qid=1567636307&s=gateway&sprefix=7+pin+rv+%2Caps%2C172&sr=8-6 And, there are many sources of 25 watt solar panels like this one: https://www.amazon.com/Watts-Monocrystalline-Newpowa-Module-Marine/dp/B01M9B6RQI/ref=sr_1_3?crid=12CG071XVKAB4&keywords=25+watt+solar+panel&qid=1567636359&s=gateway&sprefix=25+watt+solar+panel%2Caps%2C170&sr=8-3 Finally, here is the 7 pin wiring diagram: 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
rideandfly Posted September 4, 2019 Share Posted September 4, 2019 Bill, here's some additional photos. Connected # 4 pin to controller's + connection and # 1 pin to controller's - connection on the bottom right side of the controller, from receptacle shown in Bill's 7 pin diagram. Purchased 7 pin receptacle from Walmart. Used a worn out camera tripod. I should have installed a 5A inline fuse between controller's + pin to #4 pin in the 7 pin receptacle, too. 2 Bill & Debbie / 2015 LE2 #75 / 2024 F-150/5.0L / North Carolina Link to comment Share on other sites More sharing options...
DavidS Posted September 4, 2019 Share Posted September 4, 2019 Regarding off-season covers; what would you do if you have the solar panels? cover them to and just let the batteries idle? I have a similar problem, as I store my Ollie under a roof. My solution is to install a battery disconnect switch. Easy to install, easy to use, and less than $20. David Stillman, Salt Lake City, Utah 2016 Oliver Elite II Hull 164 | 2017 Audi Q7 tow vehicle. Travel and Photography Blog: http://davidstravels.net Link to comment Share on other sites More sharing options...
rideandfly Posted September 4, 2019 Share Posted September 4, 2019 Here's a master switch (knife switch) like we use on Ollie's batteries to keep the batteries from discharging between camping trips, need to learn how to share a link with a few words like David: https://www.amazon.com/Wadoy-Battery-Disconnect-Terminal-Automotive/dp/B074GPSZS7/ref=sr_1_8?crid=17AONQCQ12DNV&keywords=battery+blade+switch&qid=1567651507&s=gateway&sprefix=blade+switch%2Caps%2C205&sr=8-8 Bill & Debbie / 2015 LE2 #75 / 2024 F-150/5.0L / North Carolina Link to comment Share on other sites More sharing options...
Cash Posted April 25, 2022 Share Posted April 25, 2022 I just ordered a Diamondback SE. Should be great security as well as keeping things out of the weather. They aren't cheap but, neither is my RVing gear! https://diamondbackcovers.com/ Cash - AKA Sitting Bull http://www.shot-in-texas.com Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted April 25, 2022 Moderators Share Posted April 25, 2022 11 hours ago, Cash said: I just ordered a Diamondback SE. Should be great security as well as keeping things out of the weather. They aren't cheap but, neither is my RVing gear! https://diamondbackcovers.com/ I’ve had my eye on the Diamondback for a while. We had Bakflips on our half tons and I liked them a lot. I’m not as happy with the Bakflip on my 2500, it’s harder to handle and leaks quite a bit. You’d think that with just one more section it wouldn’t be that different than the half ton model but it is. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Steph and Dud B Posted April 25, 2022 Share Posted April 25, 2022 Planning to install a Diamondback SE as soon as we return from our final trip with our fifth wheel in a few weeks. Going to add the Frontrunner racks and put the bikes up there. 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
