ThomB87 Posted March 28, 2020 Posted March 28, 2020 (edited) Well it is Spring in the Ozarks. The birds are looking for nesting sites. I am not real pleased that a pair decided our AC cover made an excellent bird house. If you look closely you will see they also took out part of the the foam insulation. Hopefully, only a small corner removed so will not impact performance. Any ideas of how to prevent this in the future? One of those duh moments. I found when I was washing the Ollie. I finished my wash job. Then took off the cover and cleaned out the nest. Of course scattering debris all over the freshly washed roof. Sigh! Edited March 28, 2020 by ThomB87 grammar Bill Thomas 2019 Elite II Hull # 534 2020 Chevrolet Silverado HD 2500
Patriot Posted March 28, 2020 Posted March 28, 2020 (edited) A full custom made cover is what we plan to use. https://calmarkcovers.com -Patriot Edited March 28, 2020 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators topgun2 Posted March 29, 2020 Moderators Posted March 29, 2020 If you decide that a full cover is not the way you want to go - you can always purchase a cover that is for the air conditioner only - for example - https://www.amazon.com/ADCO-3021-White-Conditioner-Cover/dp/B0002F68OU/ref=sr_1_1_sspa?crid=5UKZDJJFXALN&dchild=1&keywords=rv+air+conditioner+covers&qid=1585440273&sprefix=RV+air+conditioner%2Caps%2C176&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUE1RjU3Uk9MSThOWUUmZW5jcnlwdGVkSWQ9QTA1NjQ1MDBKTjE2WTVNVUpJVjgmZW5jcnlwdGVkQWRJZD1BMDczODE3NDJPWTFES08wMEg0OUwmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl Just make sure that you get the correct size! Bill 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
AndrewK Posted March 29, 2020 Posted March 29, 2020 Topgun2, Can you leave the cover on the AC while you travel? Andrew Andrew 2019 Legacy Elite II 2018 BMW x5 35d
ThomB87 Posted March 29, 2020 Author Posted March 29, 2020 Thanks! I will look for the AC cover. Ms. Bertie is keep in a carport with sides to protect her from sun and weather. So I do not need a full cover. I was worried about insects but never thought about birds. I may cut off their food supply. Bill Thomas 2019 Elite II Hull # 534 2020 Chevrolet Silverado HD 2500
Moderators topgun2 Posted March 29, 2020 Moderators Posted March 29, 2020 AK - while I've seen ac cover that have a cinch rope at the bottom, I would not trust that to keep the cover in place while traveling down the road. ThomB87 - Probably no need to "cut off their food supply" once you get a cover. But, I did have a bird build a nest on the folded steps under my CalMark cover one year. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
BackofBeyond Posted April 1, 2020 Posted April 1, 2020 (edited) On 3/28/2020 at 3:49 PM, ThomB87 said: Must be the optimum spot - I had a bird condo in the same spot. Edited April 1, 2020 by BackofBeyond 1 1 Cindy, Russell and "Harley dog" . Winchester TN 2027 EII on the production board. "Ramble On" 2026 Chevrolet 2500 ZR2, 6.6L L8T gas V8 "Die young - As late as possible"
Patriot Posted April 2, 2020 Posted April 2, 2020 If anyone orders an AC cover would you mind posting up a link? We don’t have our Ollie yet so I don’t know the dimensions of the AC unit n order to place an order. Thanks! -Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
ThomB87 Posted April 3, 2020 Author Posted April 3, 2020 https://www.campingworld.com/elements-air-conditioner-cover-for-dometic-penguin-85006.html This is what I ordered. I will know how well it fits tomorrow or next day. 1 Bill Thomas 2019 Elite II Hull # 534 2020 Chevrolet Silverado HD 2500
Maverick Posted April 3, 2020 Posted April 3, 2020 1 hour ago, ThomB87 said: https://www.campingworld.com/elements-air-conditioner-cover-for-dometic-penguin-85006.html This is what I ordered. I will know how well it fits tomorrow or next day. This is the same cover I purchased some time ago and it fits nicely. 1 Horace & Dianne Chesapeake, Virginia 2016 Toyota Tundra Crewmax 4x4 Limited 2015 Oliver Legacy Elite II - Hull # 93
Patriot Posted April 4, 2020 Posted April 4, 2020 20 hours ago, Maverick said: This is the same cover I purchased some time ago and it fits nicely. Thank you Maverick, order placed. 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
ThomB87 Posted April 5, 2020 Author Posted April 5, 2020 Here are pictures with the cover and the product code. My trailer is a 2019 with the Dometic Penguin II AC. Note the suggestion to block the holes while waiting on the cover is a good one. The birds started rebuilding within a day of moving our Ollie back under the carport. I would not leave this on for travel only for storage. The cover should work for dirt daubers as well as birds. I am sure you could get order on other sites as well. 1 1 Bill Thomas 2019 Elite II Hull # 534 2020 Chevrolet Silverado HD 2500
Jerry Posted May 26, 2020 Posted May 26, 2020 I recently removed a birds nest. This is the solution that I am trying. ps. It is rubber
Moderators topgun2 Posted May 26, 2020 Moderators Posted May 26, 2020 My experience with rubber snakes is that they simply don't move - and - the birds eventually figure this out too.😪 Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
