Popcorn-Billy Posted April 21, 2020 Posted April 21, 2020 (edited) All, Realistically, is the Ollie a 2-3 season camper or is it more than that? Edited April 21, 2020 by Popcorn-Billy Best regards, Bill
carnivore Posted April 21, 2020 Posted April 21, 2020 I don’t know what the technical definition is but we have camped several days with weather in the teens while utilizing the onboard water system without a freeze problem. The furnace seemed more than adequate to warm the cabin and keep the pipes above freezing.
Overland Posted April 21, 2020 Posted April 21, 2020 (edited) Joking aside, ‘realistically’, it’s 4-season. I think what you’re asking though is whether it’s ‘absolutely’ a 4-season camper. And absoluteness is an impossible bar to pass. What I mean is this - I’ve been camping in November and December with freezing weather and snow and nothing broke or froze and my wife and I were comfy and warm the whole time. That doesn’t mean we could winter in Fairbanks. (Or maybe we could, with some extra prep and common sense. Don’t know; haven’t tried.) Point being, nothing about trailer ownership is absolute. Winter or summer, you’ll have to prepare, have to do maintenance, have to make repairs, have to use common sense. I’ll be the first to say that there are things Oliver could do to make the trailer more cold-worthy. All the same, I have no problem with them calling it a 4-season trailer. But it’s true I’d much sooner take our Ollie out into nowhere in January than July. Edited April 21, 2020 by Overland 2
Moderators Mike and Carol Posted April 21, 2020 Moderators Posted April 21, 2020 9 hours ago, Overland said: 3 season. The AC noise is unbearable. There’s some truth to that! We camp in the Fall, Winter and Spring. If we go out in the summer it’s to some place cool. Like others, camping in the teens has not been an issue. It’s a four season trailer. Mike Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
John E Davies Posted April 21, 2020 Posted April 21, 2020 If you live where they spray salts on the roads, winter camping will damage your metal parts without a doubt. If you can accept that (I can’t), then cold weather camping is practical and certainly way easier than with most RVs of any type. I think the 4 season description is fine, but Oliver should warn owners about this and about the many hazards of towing over ice and packed snow. I am not sure if some RV policies have exclusions about towing in nasty winter conditions.... John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
katanapilot Posted April 21, 2020 Posted April 21, 2020 So John, how did you get an Atwood Air Command (quiet) a/c installed in your Oliver? 2020 Elite II Hull #628, Houghton Heat Pump, Victron MP2, SmartSolar, Orion, Cerbo, Lynx distributor and shunt TV - 2011 Toyota Tundra Crew Max Platinum 4WD, Magnuson Supercharger, OME suspension, Wilwood front and rear brakes
WhatDa Posted April 21, 2020 Posted April 21, 2020 For winter camping, the Oliver has a few things going for it that many others don't: small air volume and surface area (size) mean there is less to keep warm. No slides and good seals mean less air leakage. The insulation is better than any other camper I have been in, and while it could be better and some areas could use a better thermal break, we were able to keep warm with a 1200 watt heater in 11 degree weather with 40 MPH side winds when we got caught in a blizzard in South Dakota. Note that I would never camp like that by choice as going outside was pure misery. Note that was October, so I guess that is only "fall". There are a few things that can be done to make your winter experience more pleasant: dehumidifier - moisture will be an issue in any camper in cold enough temperatures, electronic drain actuator(s) - lets you dump tanks from inside - not letting freezing air into basement or you standing outside waiting for tank to drain), and a space heater for the inside (or with remote) and basement. The space heaters allow you to supplement/replace the propane heater. Propane becomes less viable at altitude/low temperature - plus if you have free electricity with your site - use that instead of paying for propane and having to stand outside to get your propane refilled. We weren't really prepared for the situation in South Dakota (forecast had been in the 30's to 40's up to a day before hand), so we used internal fresh water. For our winter trips this year we used a heated hose and punched a hole in a foam faucet cover for the RV side of the connection. I had to get some pipe insulation and heat trace to make sure the faucet side of the connection didn't freeze. 1 1 Between Olivers…
Moderators SeaDawg Posted April 21, 2020 Moderators Posted April 21, 2020 Four seasons for us, since 2008. I will say, we don't intentionally camp in the snow, but it can be beautiful. And, it does require extra precautions. I wouldn't want to overwinter in Fairbanks, either, in the Ollie. Not even in a cabin. But our 2008, with less insulation than the newer models, has been fine into the teens. Surprise overnight snow, in late October, 2008, was our unintentional introduction to winter camping in an Oliver. It was quite pretty, actually. And not terribly cold, maybe into the twenties, but we were snug and warm. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
