Maniac-no it doesn’t work at all. We can’t get any of the buttons to engage. We took it to an RV shop and they determined that the eyebrow board was not working.
Mountainoliver- I definitely don’t want a whole fridge but might be interested in the eyebrow if we have a match.
Great . . . . another Covid supply chain issue!
Ray and Susan Huff
1UP-USA Heavy-duty bike rack
Thanks everyone for help with this issue. We just got a call from the RV shop we deal with and they finally got an eyebrow panel from Dometic. So we won't be buying Mountain Oliver's old Dometic fridge after all!
  • 2 months later...
17 hours ago, zoelakin said:
I needed help ventilating my camper fridge. Before when it reached 90 degrees or higher outside my fridge couldn't keep up.
I think this is typical . . . . I once heard that the rule of thumb is that Absorption fridges will cool down to 40 degs below ambient temperature.  One thing you can do is deploy the awning so it shades the wall where the fridge is installed.  It should also help if you can keep the cabin temperature below 80 degrees.  We have a small battery operated fridge fan that we use to circulate air, thus helping with cooling; it is also important to not pack the fridge so tightly that air can't circulate.
When we camped in our travel van, we would keep ice packs in the freezer and place them in the fridge when outside temps were extreme - basically using it as an ice box!  This was a larger Dometic model 8555, that had to be set at the highest cooling setting to keep the temperature around 40 degrees. I hated that fridge; our Oliver's Norcold seems to work much better, though we haven't camped yet where temperature got above 50.  I have high hopes for the Norcold.
Ray and Susan Huff
What brand refrigerator were you using? Are you running on propane or AC. What's the average temperature this time of year in Bac Giang, Vietnam? That may be your problem.
Edited by ScubaRx
  • 3 weeks later...
Hey Everyone-we are having ongoing issues with our Dometic fridge. We are working with a local RV repair shop who has diagnosed the issue as a faulty eyebrow circuit board, as mentioned above in the previous posts. When I wrote last, we thought the issue was resolved with Dometic sending a new board to the repair shop. Well, unfortunately, Dometic sent the wrong board and is now saying that they are not sure when they can send a new board. We are trying to figure out how to proceed, and have looked at replacing the fridge with a different brand. We are not keen on this, since the board that is faulty is only about 100 dollars and a new fridge is quite a bit more. Seems wasteful to just replace the fridge. We have: looked online, checked dinansour, looked at RV salvage yards and are simply unable at this time to locate a replacement eyebrow. We looked at the Norcold but that would require quite a bit of modifications to our Oliver. Oliver Service has been great, of course, and has helped us in trying to locate a replacement circuit board and could replace the Dometic with a Norcold, but it would be quite an expense. All of the above leads to 2 questions: in the absence of a replacemnt Circuit board, what fridge could replace the Dometic, without major modifications to our Oliver in other words is there a replacement fridge that is simple and easy to swap out? In the absence of a fridge swap, does anyone have any ideas about how to get an eybrow circuit board? For reference, we are looking for a Dometic Eyebrow Circuit board model number 4450007134. We were hoping to go ahead and replace the lower control board number 4450020612, if we can get it. Our Oliver is a 2018. Thanks in advance.
If you still have your old PCB you can reflow the solder joints to determine if the problem is a cracked or cold solder joint.
I have repaired a number of boards over the years doing this. Poor quality cold solder joints eventually crack resulting in intermittent or no continuity.
Use a solder iron (with magnification if necessary) to touch each joint. You'll see the solder melt and flow. Don't dwell but a second or two...just enough for the solder to reflow.
It's worth a try on hard to get or expensive boards.
It you attempt this, insure you touch the soldering iron to the component lead to allow the heat to transfer through the lead to melt the solder. This will result in a good bond. If you just touch the solder and not the lead you'll recreate a cold solder joint. There should be some good youtube soldering videos for reference.
  • 11 months later...
@thompsonkd, how did you resolve your issues? Just curious,  as someone with a similar date trailer is also having problems.
Thanks.
Our Dometic went out about one week after the expiration of the warranty. Dometic would not extend the warranty, nor did they have a replacement board. We looked everywhere for a replacement board. We had a local RV repair shop look as well. I was able to locate a board that was close, but never the exact one. And, because we were never able to get an upper board, we were not confident that it wasn’t the lower board, or a combination of the two since they apparently work together. We ended up having to replace the entire fridge, for lack of a $100 to $200 part(s)! We got lots of help from Oliver service, and zero from Dometic. We now have a Norcold and are happy with it. The thermistor did go out, but Norcold paid to have our local RV shop replace it under warranty. The Norcold is a better design than the Dometic; if the fridge goes bad, it has a backup mode that keeps the fridge cold right above freezing to help prevent food loss. And Norcold service is exceptional. Wait times to talk to someone are reasonable and they actually offer help. I now know why Oliver switched to Norcold away from the Dometic.
Who replaced the refigerator; you or your RV shop or Oliver?
Did modifications to the refrigerator opening need to be done or was it a simple remove the old and slide in the new?
Thanks
Maine
  • 3 years later...
On 9/7/2020 at 1:46 PM, BackofBeyond said:
Mine did that - I held the button in for a little longer - then got pissed, smacked it, tried it again, and it worked all summer.... GOFIGURE......
Another reason I love this Forum.  My Fridge would not light up. Tried pushing all the buttons. Saw someone used a butter knife and I got a Phillips and pushed all the buttons, many times. No luck. Looked at the fuses. (Why in the world does the door open the wrong way?) Then tried pushing the buttons again with the screw driver. No Luck. Then tried your “Smacked it” approach. All the lights came on and it started working. Will not tell my wife this, she might try it on me… Thanks
  • Haha 3
Gary and Anita Teaney and Ranger
2017 Oliver Elite II Hull 292
2018 Nissan Armada
Tampa, FL
In my experience,  don't get complacent.
Your 2017 probably has a dometic.  The bang it/push method may last a few months, or a year. For us, off and on, one six month camping season.
At this point, please consider what type of fridge you want as a replacement,  and do the swap off season.
Then again, you might just be lucky, and some erosion on the panel knocked off.
Just be prepared. Coolers, at ready.
Great advice, and the reason we travel with a sizable dual zone cooler; mostly intended for overflow, but on rare occasion as a backup!
2020 OLEll, Twin, 579:
