Collier and Joan Posted January 8, 2021 Posted January 8, 2021 This morning while winterizing, I hook up my first jug of antifreeze to the rear inlet ,went Inside and turn on the water pump. Not a sound from the water pump, dead as a door knob, Light on water pump switch was lit, check under the side table at the water pump fuse and it look fined. I put in a new one to be sure, turn on water pump switch, pump switch lite came on but still not a peep from the water pump. Any suggestions, I look at the pump and didn't see anything loose. I have a 2019 Legacy II 2019 Oliver Legacy Elite II - Delivery Date Aug 29, 2019 Ford F150 XL Supercab - 3.5 EcoBoost
Moderators SeaDawg Posted January 8, 2021 Moderators Posted January 8, 2021 I don't know about your trailer, but we have two switches for the pump. Main switch at the door. Switch in the kitchen. Don't think light would come on though, if main were off. At this point, I'd be looking for a loose connection. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Landrover Posted January 8, 2021 Posted January 8, 2021 Loose connection most likely. You are winterizing has it been very cold for a long time? Make sure the pump itself did not freeze. Check the site bowl. Good luck Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎
Collier and Joan Posted January 8, 2021 Author Posted January 8, 2021 Has not been cold, winterized it a month ago with no problems, just got back from Florida where I de-winterized. 2019 Oliver Legacy Elite II - Delivery Date Aug 29, 2019 Ford F150 XL Supercab - 3.5 EcoBoost
BackofBeyond Posted January 8, 2021 Posted January 8, 2021 Check voltage at the pump - no voltage - trace back to problem. 12v at pump - hmmm. Try to visually verify there is nothing in the pump - blocking action. With pump on - tap it a few times - a swift but gentle tap - if nothing happens, its probably a bad pump. 2 Cindy, Russell and "Harley dog" . Home is our little farm near Winchester TN 2018 Oliver Legacy Elite II - 2018 GMC 2500 Duramax "Die young - As late as possible"
Moderators mossemi Posted January 9, 2021 Moderators Posted January 9, 2021 Check the second water pump switch switch in the bath. Still nothing, check the wiring at the switch if you don’t have power at the pump. Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Cvh Posted January 9, 2021 Posted January 9, 2021 Had the same problem. I found that one of the two red wires that enter into the front of the pump (as you’re looking at it from the hatch opening) was very loose when wiggling it. The loose terminal is actually inside the unit. Jason had the company send a new end cap that contains the built in wiring terminals . Suggest you call Jason for help. 1 2
Collier and Joan Posted February 10, 2021 Author Posted February 10, 2021 Just an update, did as Cvh suggested and put on a new end cap. The water pump work perfect after replacing the end cap. 3 4 2019 Oliver Legacy Elite II - Delivery Date Aug 29, 2019 Ford F150 XL Supercab - 3.5 EcoBoost
Moderators SeaDawg Posted February 10, 2021 Moderators Posted February 10, 2021 Collier and Joan, Thanks for letting us know how your problem resolved. This will definitely help others, in the future. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Patriot Posted February 10, 2021 Posted February 10, 2021 1 hour ago, Collier and Joan said: Just an update, did as Cvh suggested and put on a new end cap. The water pump work perfect after replacing the end cap. Great work! Glad it worked out! 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
connor77 Posted February 10, 2021 Posted February 10, 2021 9 minutes ago, SeaDawg said: Collier and Joan, Thanks for letting us know how your problem resolved. This will definitely help others, in the future. Yes, agree wholeheartedly with SeaDawg. It's super helpful to others when an owner "closes the loop" on an issue that they've posted about. Sharing what actually fixed the issue is obviously very much appreciated as well. 1 2021 Elite 2 Hull # 832 "Bucket List" 2021 F250 7.3L Gas / 4.30 AR / Central Maine
