Oliver Elite II #748 Guts - 131 Images of the harder to see spots
Jairon
Thanks - great photos.  They'll be a useful reference for you later.
Some comments:
First thought is that the trailers are being delivered much cleaner than they used to be, which is great to see.
Some of the wiring still looks like a mess, but I'm glad to see that they're using lever nut style connectors now, which should make repairs, diagnosis, and upgrades easier.
I hate that they're still using gorilla tape to hold down wiring.  And they're not zip tying the ends of their wire wrap to prevent it from coming off.
I still see *sharp* screw ends poking inside the hull near wiring.
The new batteries are pretty cool.
It looks like they're doing a good job with the new insulation, cutting it tightly around obstacles and taping the seams.
We're happy with it and haven't found any major issues. I plan to do a full review after we complete a few trips.
I was surprised to see that too.
Some of it has already pulled off. Taping over fiberglass dust doesn't work very well. 🤪
Every unnecessary hole and screw through the fiberglass is hard to swallow (I'm picky). The vent for the furnace seems crazy so I assume some regulation is forcing them to do it that way.
I'm really happy with them so far. The bluetooth app is better than most. Lithionics is also the new supplier for Xantrex's lifepo4 battery line.
Yeah, it is pretty uniform other than to the right of the attachment point in the closet (photo below). I'm not sure if this is normal or was an oversight. I believe that is an exterior wall but it is really hard to see anything other than some exposed fiberglass.
Edited by Jairon
2019 Toyota Land Cruiser
Thanks!
Heartwarming (not!) to see that they've already replaced the battery make/model that they put in #709. Oh well, fingers crossed - hopefully  it's  just because either they got a better deal or else because they ended up having to put heating mats under the LifeBlue batteries...
Oliver Elite II hull #709
I believe Oliver is still installing both LifeBlue and Lithionics. They added Lithionics because they had more lithium orders than LifeBlue could handle.
Thanks for posting, some of the locations are a complete mystery to me. It is helpful to add an “annotation” text description in those cases. This is disheartening, I would have expected better than this Rat’s Nest. That looks just how mine did in 2017.... including way too long cables.
And this?
Does installing the black dump valve angled across the middle of the ONLY decent storage area in the front of the trailer make any sense at all? This is what mine looks like, the valve is hard up against the rear wall.
And mine came with smily faces everywhere (inspection marks)... If I had a new trailer with that black valve location and a Natures Head, removing the thing would be my very first mod.
Kinked duct means a cold bathroom:
And WTH? This is just sad - the sealant should go on the bolt shank and underneath the washer, not globbed on top after installation.
Oh well, if wishes were fishes we would all cast nets. At least there are still things to complain about, if these trailers were perfect, what would we talk about except tow vehicles, grills and campsites?😬
Agreed. I plan on doing a full review at some point with more detail and descriptions. I loved seeing photos like this when I was considering a purchase so I just wanted to dump them in an unorganized fashion for the time being.
Yeah, I was bummed when I saw this too. I'd be curious to know if all of the new ones are like this and why.
Kinked duct
Practically zero heats makes it to the bathroom even with one of the vents completely closed.
The person wielding the caulk gun should probably have their privileges revoked. It is a train wreck in almost every out of sight location. At least stuff like that can easily be resolved in the future. 😁
Edited by Jairon
Many parts show an eye to quality that most have come to expect
Match Marking / Turn of Nut
Good wire loom
Assuming good weld penetration the bead of dimes cap is better than most and only in a few spots could use some wire wheel or brush
As SeaDawg mentioned the insulation looks tight when it does not get damaged later in the build process
IMG_20210309_155014.thumb.jpg.9ac220f57ac53926e545ac721f493d6a.jpg.1eb540baec16b7ae57bf8ce0846269be.jpg
IMG_20210309_143236.thumb.jpg.abe666bd169c8fa4cdf74c6b1db2b18b.jpg.bf693dc035abdbaa7b0a3de5b2cde1ea.jpg
There is a fine line between a service loop and poor training or a short cut
Ducting and wire looms like this are not expected
IMG_20210309_160208.thumb.jpg.dc16bf33a07f6c4737c45d8b1a7708a7.jpg.370e3e579c5fe6d0c8cfc3fb621dadb0.jpg
IMG_20210309_134209.thumb.jpg.173cc2b4666a8b059939416e6e361e06.jpg.836de1cffd3ecc03507b54a40968d2e3.jpg
Overland mentioned the trailers are being delivered cleaner than before, not sure what to expect now, but there are portions of this build that look like they have quite a bit of glass shop dust and would benefit from additional attention to detail
1984236_IMG_20210309_1426012.thumb.jpg.ee09fc32e6272227c28d7f0303486ce8.jpg.099915d4c3407de4b151449819cf9b07.jpg
Overall should a buyer be concerned the demand for production is starting to compromise QA/QC?
Back In the Queue
Seadawg (me)  would say big leaps from 2008.
I'd say, get out and get camping. Drive a ton of miles.
Enjoy the heck out of your camper, as we have.
No - I don't think so.
In fact, I believe the opposite is true.  With experience and the income generated by producing more units, Oliver has instituted a number of QC measures in the past couple of years that have produced needed results.  While that effort is not yet (ever?) complete it certainly is better than it was during the period when Oliver was trying to expand rapidly.
