csevel Posted December 17, 2021 Share Posted December 17, 2021 I've hated my red satin compartment straps since the day I brought ILOVHER home. They never seemed to be on the outside of the lid! I found some of these grommet straps at my local discount outlet store for three for a buck! More robust nylon, longer and and nice grommet to hang on to. A washer and screwdriver and you're done! Here's a link to similar. https://www.amazon.com/TCH-Hardware-Nylon-Strap-Grommets/dp/B085CNGRFP 1 8 1 2020 Toyota Tundra TRD Sport 5.7L V8 2017 Oliver Legacy Elite II Hull #184 ~ "ILOVHER" Link to comment Share on other sites More sharing options...
VBistro Posted December 17, 2021 Share Posted December 17, 2021 6 hours ago, csevel said: I've hated my red satin compartment straps since the day I brought ILOVHER home. Ad I thought it was just us! 🙂 Nice solution. Will definitely put this on the list. 1 MaryBeth Boulder, CO 2022 Elite II #953 TV: 2021 Ford Expedition Max Platinum, Max Tow Package Link to comment Share on other sites More sharing options...
Landrover Posted December 18, 2021 Share Posted December 18, 2021 20 hours ago, csevel said: I've hated my red satin compartment straps since the day I brought ILOVHER home. They never seemed to be on the outside of the lid! I found some of these grommet straps at my local discount outlet store for three for a buck! More robust nylon, longer and and nice grommet to hang on to. A washer and screwdriver and you're done! Here's a link to similar. https://www.amazon.com/TCH-Hardware-Nylon-Strap-Grommets/dp/B085CNGRFP Nice job I’m also not to fond of the strap’s only because when you forget to leave them out when putting the cover down, out comes the screwdriver or butter knife. Almost like forgetting to pull the valve handle in the bath. 🤬 1 Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎 Link to comment Share on other sites More sharing options...
John E Davies Posted December 18, 2021 Share Posted December 18, 2021 Nice mod, but does the thicker material cause the hatch cover to rock any, since it is held up higher in the center? I guess you could file a recess in the edge of the lip. I have had my satin ones get trapped, but after a few times and some swearing,I learned to actually hold onto them when lowering the cover back down, and it doesn’t happen any more. I did add fender washers, like yours, because the tiny screw head is inadequate. I hope Oliver fixed that issue, that was in 2017…. https://olivertraveltrailers.com/forums/topic/2160-how-to-fix-your-inside-access-panel-straps-wrong-hardware/ John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
csevel Posted December 18, 2021 Author Share Posted December 18, 2021 3 hours ago, John E Davies said: Nice mod, but does the thicker material cause the hatch cover to rock any, since it is held up higher in the center? I guess you could file a recess in the edge of the lip. I have had my satin ones get trapped, but after a few times and some swearing,I learned to actually hold onto them when lowering the cover back down, and it doesn’t happen any more. I did add fender washers, like yours, because the tiny screw head is inadequate. I hope Oliver fixed that issue, that was in 2017…. https://olivertraveltrailers.com/forums/topic/2160-how-to-fix-your-inside-access-panel-straps-wrong-hardware/ John Davies Spokane WA There is no wobble at all. The nylon is thicker but it doesn't seem to matter. Since I tend to be a little obsessive, I even took all the stickers off the hatches that 'aren't for storage' and also removed the screws. I added some white snap caps to the screw holes and now have access to all of the compartments in the event of a mechanical need. Obviously, I'm bored. 😉 2 2020 Toyota Tundra TRD Sport 5.7L V8 2017 Oliver Legacy Elite II Hull #184 ~ "ILOVHER" Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted December 18, 2021 Moderators Share Posted December 18, 2021 36 minutes ago, csevel said: Obviously, I'm bored. 😉 I'm just guessing, but I suspect you're counting the days to the next camping trip? (And filling them with projects!) 🙃🙃🙃 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. Dc compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
John Dehne Posted December 18, 2021 Share Posted December 18, 2021 A bored mind can get very creative. Nice mod, It goes on my list also. 🎄 1 John & Chris Dehne Manchester, MD. 2021 Elite II twin Hull# 901 “Fiberbeergrass” 2021 Ram 2500 Cummins 4x4 Life is good! Link to comment Share on other sites More sharing options...
