Hello all,
The Norcold fridge in my 2022 Elite II leaks air inside the trailer cabin.  The very cold winds are blowing directly into the vents from the outside and into the cabin.  It seems to be coming in from between the fridge frame and the fiberglass enclosure on the inside of the trailer.  Is this a common problem?  The volume of air is not horrible but is very noticeable when walking by, especially at 18 Degrees F.  I see a gap between insulation pads when I take off the cover, 1/2 to 3/4 of an inch, but Jason E. says that is by design and must not be taped over.  Any suggestions?  I may run a bead of silicone around the frame.
I observed similar air intrusion in my 2021 Elite II when parked with the curbside to windward in a breeze.
2021 Elite II #769, 2018 Toyota Tundra
This is not the first time lately that I've heard a new owner complain about air entering the cabin around the refrigerator. Take off the upper outside cover and see if there is a gap in the insulation or the metal tape used to seal everything. Cover any holes with duct tap until you can get something better. I would start a service ticket also.
There is no reason air needs to pass around the fridge into the cabin. In fact, it shouldn't. That's a propane burning appliance. The rear of the fridge should be exposed to the exterior vents but the front of the fridge should be isolated from that service area. Take photos and start a service ticket.
Thanks,
I contacted OTT and was told to not cover the openings.  It will void the warranty.  Here are some pictures.
Probably why my alarms went off!
Thanks,
From https://askthervengineer.com/the-essential-guide-to-your-rv-absorption-refrigerator-and-why-it-doesnt-work-in-the-mountains/: "All that heat from your fridge’s interior has to go somewhere! And when burning propane, the fridge releases toxic exhaust gases, too. You don’t want either of those things inside your RV. That’s why your RV is installed inside a sealed compartment and the hot gases are exhausted through your fridge vents."
I can't understand why OTT says that gap should remain. Is there another seal behind that gap?
If I felt a draft, I would seal around the fridge opening inside the trailer. Duct tape is fine, wherever you feel a draft.
I wouldn't mess with outside venting.
As others have said. Open a service ticket.
In addition to cold air, plan on mosquitoes too.   I was up late one night trying to find where they were coming in when I noticed one fly out from behind the refrigerator face trim plate.  I taped up the opening inside, swatted the rest of her buddies, then went back to bed.  Next day I pulled the outside refrigerator cover off and found a bunch of the foil tape had come off in the heat.  It’s not only cold air that can blow in through the openings.  Bugs will be attracted to the heat and refrigerator combustion gases and eventually end up inside with you too.
2013 Toyota Land Cruiser 200
2018 Twin Bed Elite II #351
1 hour ago, johnwen said:
Thanks,
...I contacted OTT and was told to not cover the openings.  It will void the warranty....
I think there was a mis communication between you and Oliver. I think that they thought you were suggesting covering the inside of the vent covers or the hole (openings) that they fit into. I think that you were referring to any gaps in the insulation (as I was) that seal the refrigerator to the hull.
I don't know either.  I've contacted Norcold/Thetford and hope to hear back from them soon.  Will post what I find out.
Actually I did send pictures to OTT they confirmed warranty problems if I covered up the gaps.  I have a call into Norcold/Thetford and expect to hear back from them.  Will post what they say.
Thanks for the heads-up on the mosquitoes 🙂
  • 3 years later...
Reviving this thread. Now that we're doing more shoulder season camping and using the Oliver more while closed up we're getting more frequent propane/CO alarms from the sensor below the dinette. Like @johnwen above I can feel cold air entering around the top of the fridge and we have the same large gap above the fridge behind the top service vent that he has. I can look straight in and see the back of the fridge control panel from outside the trailer. I'm convinced we're getting exhaust gasses blown in that way and intend to seal it up with aluminum tape unless anyone can give me a good reason air should be allowed to flow through there.
That's what we did Dudley.  I sent you a PM.  2 years later and the fridge still works fine.  I would do again!
First, PLEASE replace your CO alarm if you have any doubts.  Especially for a trailer that has an ammonia absorption refer
For these class of machines, the front of the refer cabinet must be sealed from the cabin, regardless of the brand.  Aluminum foil tape is what I would use.
I personally believe that running a condenser fan 24/7 to help scavenge air from the back of the refer and out the top outside vent is a good idea.  It will tend to draw in good air at the bottom and exhaust whatever is in there out the top.  In the process it may put this area under a slight negative pressure... further helping keep the family safe inside the trailer.
