One of my under cabinet touch led lights comes on but is dim. Anyone else had this experience?
All the other lights (touch or switch) work properly.
Thanks! Headed to Florida for a few weeks and found this while packing. It’s certainly not going to keep us from finding warmer weather!
Dave
David and Vicky | Burns, TN | 2020 LEII #686 (RIP!)| 2024 LEII #1550 | 2017 Ford F-250 4x4 6.2L
It sounds like some of the LED's the that light's cluster have gone out. Unless you can see where they've become un-soldered you'll need to replace that light.
I guess it's like some of the street signal lights you see, the LED pattern is disrupted and the light from them looks really funny or a weird pattern. I have a flashlight that is like that and the light from it is not too bright, now where is the trashcan.
The little springs that trigger the lights on/off are problematic and can be causing current loss.
When they work, they are nice, but even Service isn’t a fan of them. I have two spares. 😉
2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570
I have one under cabinet touch light that goes from dim to on but never goes off.  And one that never goes on.  I love these lights but they seem to be sketchy.  I hope they are easy to replace.  I will try once the  weather warms up.
You might want to send a PM to Forum member Patriot since I believe that he successfully replaced at least one of his touch lights.
One of my touch lights behaved similar. I ended up discovering the cover had vibrated out of place enough to effect the touch function. Once I rotated the cover to the right position the issue disappeared.
Thanks to all. You’ve given me reason to at least try to fix it. The cover on this has not been right since it was new so I’ll start there.
