csevel Posted June 25, 2022 Posted June 25, 2022 Trying to replace a ceramic cartridge on a Dura bathroom faucet in the ILOVHER ('17) I was told by Oliver that it was leaking. I haven't found water but I can see the corrosion. They wanted $250 for a new faucet and by then I was tapped out. I've gotten as far as popping off the hot/cold emblem and removing the set screw to get the handle off. How do I proceed from here to get the cartridge out? Seems in there pretty good! I imagine I need a special plumbing wrench/socket? Any help appreciated! 2020 Toyota Tundra TRD Sport 5.7L V8 2017 Oliver Legacy Elite II Hull #184 ~ "ILOVHER"
Moderators topgun2 Posted June 25, 2022 Moderators Posted June 25, 2022 Have you tried going to the Dura Faucet site (HERE) to download the owners manual? Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Rivernerd Posted June 25, 2022 Posted June 25, 2022 Have you tried to twist off the brushed chrome cap that sits on top of and around the cartridge? It may be threaded onto the housing below it. On some faucets, that cap holds the cartridge in place. Try twisting the cap counterclockwise to remove it. You may need a gripper to give your hand traction, like this: https://www.amazon.com/Regent-Multi-Purpose-Gripper-Bottle-Opener/dp/B019R5TSYW/ref=asc_df_B019R5TSYW/?tag=hyprod-20&linkCode=df0&hvadid=193124190188&hvpos=&hvnetw=g&hvrand=1108655480944362344&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9029558&hvtargid=pla-311177149643&psc=1 DF-NMK852 looks like the correct model number for the faucet you have. If you download that owners manual, the brushed chrome cap is depicted on the parts list on Page 5, with the cartridge shown right underneath it. This suggests that the cap must be removed before you can access the cartridge to replace it. Good luck! 1 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
csevel Posted June 25, 2022 Author Posted June 25, 2022 19 minutes ago, Rivernerd said: Have you tried to twist off the brushed chrome cap that sits on top of and around the cartridge? It may be threaded onto the housing below it. On some faucets, that cap holds the cartridge in place. Try twisting the cap counterclockwise to remove it. You may need a gripper to give your hand traction, like this: https://www.amazon.com/Regent-Multi-Purpose-Gripper-Bottle-Opener/dp/B019R5TSYW/ref=asc_df_B019R5TSYW/?tag=hyprod-20&linkCode=df0&hvadid=193124190188&hvpos=&hvnetw=g&hvrand=1108655480944362344&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9029558&hvtargid=pla-311177149643&psc=1 DF-NMK852 looks like the correct model number for the faucet you have. If you download that owners manual, the brushed chrome cap is depicted on the parts list on Page 5, with the cartridge shown right underneath it. This suggests that the cap must be removed before you can access the cartridge to replace it. Good luck! I'm aware that the surrounding ring must come off but it will not budge even with a rubber glove..! I sprayed some PB blaster around the lower edge of it and will leave it sit and try again tomorrow. 2020 Toyota Tundra TRD Sport 5.7L V8 2017 Oliver Legacy Elite II Hull #184 ~ "ILOVHER"
Townesw Posted June 25, 2022 Posted June 25, 2022 Don’t try it without one of these. Read my posts in this thread 5 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
Patriot Posted June 25, 2022 Posted June 25, 2022 19 minutes ago, Townesw said: Don’t try it without one of these. Read my posts in this thread Bill, excellent write up. Thank you! - Patriot 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Moderators SeaDawg Posted June 25, 2022 Moderators Posted June 25, 2022 Or, you can buy a nice faucet for far less than $250. . I also think dura has a long warranty. Check that. I've gotten warranty replacement on delta, pfister, and others. I'd try that, first. Imo. Many plumbing companies offer lifetime warranty. Your choice. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
csevel Posted June 26, 2022 Author Posted June 26, 2022 1 hour ago, SeaDawg said: Or, you can buy a nice faucet for far less than $250. . I also think dura has a long warranty. Check that. I've gotten warranty replacement on delta, pfister, and others. I'd try that, first. Imo. Many plumbing companies offer lifetime warranty. Your choice. I would, except Oliver had to fix my bath interior courtesy light and took the towel bar insert out to do it. They did such a professional job on the caulking (such I could never duplicate) that I would just like to fix the faucet myself. 😀 2 2020 Toyota Tundra TRD Sport 5.7L V8 2017 Oliver Legacy Elite II Hull #184 ~ "ILOVHER"
